Station Clock?
Warren
Hi everyone
I have had this clock for years and would like to  know the type where it was made and approximate value
It has a double face and I brought it from an antique shop in New Zealand
The face is 480mm and the clock overall is 620mm
thanks
Warren
Its an 8 day fusee on chain timepiece, looks like an anchor excepment, job to tell by the photos. Pillars are suspect  no shape to them, look modern. Until I see the back plate I can't comment on the movement. There could be info stamped on the plate which might help.
There where  quite a few suppliers of public clocks to the government H.Williamsons, Smiths, Gillett and Johnston, Elliott and Stockall and Marples.
The clock is not a Gillett and Johnston the pillars are too plain, H.Williamson and Stockall and Elliott used plain pillars you should look for stamps on the case which would consist of the maker, year and Royal cipher the backplate of the clock would also be stamped with these markings.
The following is a Stockall:
https://www.sellingantiques.co.uk/648154/rare-edward-viii-mahogany-double-sided-clock-stockall-marples-1936/#
The problem with these Fusee clocks is that they have been widely faked in India but I have never seen a double faced fake, but there are also things about this clock that point to it not being quite right, the placement of the hinge for the bezel on the top does not conform to what one would expect which is usually hinged to the right.
The only way to confirm would be to remove the movement from the clock, to do this you would have to remove the hands from the side of the clock without the winding hole, remove the two screws on the base board (another thing that I've never seen on one of these clocks)the side with the winding hole will have screws around the edge of the dial remove these and the face and movement should lift out.
    • Yea a have given it a full service this movement is chinese 2813 whats the left angle for this movement does anyone knows  and how  do a remove the default  of 52 degrees on my timegrapher?
    • Sure! Some very accomplished repairers never use epilame! I have often wondered if it is worth the trouble. Not using epilame will shorten the service intervals though, but that could be better perhaps both for the owner and the repairer!? Speaking of oiling, I just read this: After WWII in the 1950s the first Synthetic Oils came on the market. Most watchmakers did not rush to use these oils since they were bad for business now that the watch serviced with Synthetic oil would not come back to him for service for another 5-7 years he would lose a lot of income. ~Ofrei.com   Anyway, I wouldn't be surprised if it would be more correct to think of epilame as a binder rather than a repellant. Until convinced otherwise that's how I will think of epilame.
    • I read that same article last night  H.  I think epilame is too much headache for me, sources aren't always accurate, some conflicting. Such is the GRAVITY of this situation, Is it ok if i just STICK  to a thixotropic oil 🤣
    • Not sure I follow along. As I stated in one of my previous posts, the epilame will remain intact between rubbing parts as long as the surface is lubricated by oil or grease. Maybe it's just a coincidence, but note how the epilame-treated surface is illustrated in @Waggy's post. It looks like the oil is exposed to a binder (epilame!) so that it can't move sideways.
    • The epilame under the oil will also be removed  Unless the oil makes a barrier between the epilame and the escape teeth 😅 I think i need two strong coffees now 🤣
