Lip r 148 movement.
markr
Knowing nothing of quartz watches when my Waltham diver died I got a running donor watch with the correct R 148 movement.  It came running but two weeks later when I went to swap movements the donor stopped.  Yes I did checked and replace batteries.  When I pull on the donor movements crown the balance spins 4 or 5 times then stops. Push in the crown and balance turns once or twice and stops.  What should be my next move?
I may be wrong here but I don't think this is a quartz watch.
52 minutes ago, Nucejoe said:
Isn't this electric?
I think the battery is probably a clue that it's an electric watch.
Do you have any electrical test equipment as this is A electric watch it be nice to have a power supply and some way to measure current and even resistance?
Then we really need a service manual for this one. Some balance wheel electric watches had a hack or a method of stopping the balance wheel. Then when you push the crown in a given to push so it take off and run and that's what you may be seeing right now when you're playing with the stem of the crown. Because otherwise to get a clue we need some electronic test.
Electric watches are fickle and often need a good shake to get them going.
If a good shake gets it running and it then stops again it's time for a service.
A bodge alternative to a service is to spray a degreaser on all the pivots and contacts........and you might get lucky.
Looking at the photo of the balance again I would say the beat arm needs to move clockwise by 15 to 20 degrees comparing it to other Lip r 148's on the web. Or pushing the rate arm anticlockwise to get it in the middle before the bend in the hair spring. This may help.
Edited by Melt
  Its electric, Mark says he knows nothing of quartz watches.
I know nothing of either one, but I can repair em.
Mark;  How freely does the balance wheel oscilate as you shake the watch, nudge the balance wheel to turn it, if at some point it kicks and shows any sign of life, its likely to be out of beat so bring the beat adjustor arm=( stud carrier arm) to the position that makes it kick. The sucker should kick and run.?
Regs
Joe
Just a thought.  Are you sure the battery has 100% full voltage. It looks a bit domed (it should be flat) which is an indication that it is at the end of life and may not be giving enough voltage output.  Did you check voltage with a meter, it should be as near as possible to 1.5v, most new cells are about 1.56v. Below 1.4v and it needs changing.  Even 'new' batteries may have degraded in storage, so ensure it is a fresh new battery not one from old stock.
As you check the battery before why don't you take it out now and check it again?  It sometimes comes up in quartz watches  the shape of the negative contact  doesn't always have the desired effect if it's not shaped correctly. So I look at the pictures the insulator isn't very big it's possible your battery is shorting itself out if the insulator isn't covering everything. Ill be easy to test for you take the battery out and see what its current voltage is if it's down considerably you know you have a problem otherwise it's probably fine.
50 minutes ago, markr said:
The tab on the balance seams to be attracted to the tab on the coil.  A puff of air will swing the balance a few times and then the two tabs act like magnets.
Lip was working with Elgin who had a very interesting idea for basically enhancing the magnetic field.. Lip is using the same technology you're right the tabs are magnets but electromagnets. One end of the coil with its tab is one poll.. The other end of the coil is magnetically coupled only around under the balance wheel up through the balance wheel  to the other tab.. Then  alignment of things is critical  because when the balance wheel is in the right position  it engages the contact which turns on the electromagnet  which attracts the balance wheel tab to the stationary end of the coil. Just before  contact opens in the balance wheel swings past.. So if you start pushing things around just because you're going to have to put them back exactly where there supposed to be or the watches never going to run at all..
Then the contacts and the stuff that can move around shouldn't move around by itself so I would go back and look at  whether the battery is actually supplying power to the watch Or whether it somehow shorted itself out..
Its supposed to, so to set the oscilator in motion, however, as balance turns at certain angle electric current is to get switched off which switches  the magnetic field off, so that oscilator would be free of reaches its max amplitude and turns back to completes a full oscilation, where the current gets switched back on again.
John well covered all there is , the electric circuit doesn't switch off or it does so way out of beat ( correct angular position of balance).
Try demagin the hairspring, if it is sticking it will keep the balance out of beat.
or its a short circuit somewhere.
Good luck.
4 hours ago, markr said:
Do I need to remove hairspring to demag or can I do the whole movement?
You very definitely do not want to demagnetized the entire movement. Typically with electric watches balance wheel type there will be permanent magnets. There's usually one to hold the escape wheel or whatever it's called in place and this watch has one of those. Then the other problem would be here inducing up rather strong magnetic field with a watch that has a coil and at its going to generate energy that conceivably could burn the diode out may be. The diode's there to protecting its back EMF from its own the coil and a very strong magnetic field conceivably would be worse in the field its own coil could generate. Then personally I would doubt that the hairspring would get magnetized because it should be a nonmagnetic hairspring.
    • Ive never used epilame H only information i have read and mentally stored about it mostly from Nicklesilver here and elsewhere ( the fork horns thing ), maybe the residue powder that is removed has some grinding effect ? So probably a good idea to limit its application areas to only the absolute necessary. Yes as far as i know epilame rubs off relatively easy, the technique of running the watch to make a groove through it first in the pallet stones where the lubrication is then placed. This i understand creates the barrier for the lube to sit up to. If i can find a good balance of pros and cons of its use then thats one process i can avoid by using a thixotropic lube on the stones. The epilame i would say allows for a more fluid lubrication to be used that would increase amplitude on low beat movements. The stearic acid powder is extremely cheap, the problem is the fuming process to coat parts, is not selective , the whole part has to treated in this method. If epilame residue can cause wear then thats not good, if I remember the conclusion was not proved entirely just a general assumption between watchmakers. The thread is out there somewhere, the same discussion is also old on a facebook group. Ive never used epilame H only information i have read and mentally stored about it mostly from Nicklesilver here and elsewhere ( the fork horns thing ), maybe the residue powder that is removed has some grinding effect ? So probably a good idea to limit its application areas to only the absolute necessary. Yes as far as i know epilame rubs off relatively easy, the technique of running the watch to make a groove through it first in the pallet stones where the lubrication is then placed. This i understand creates the barrier for the lube to sit up to. If i can find a good balance of pros and cons of its use then thats one process i can avoid by using a thixotropic lube on the stones. The epilame i would say allows for a more fluid lubrication to be used that would increase amplitude on low beat movements. The stearic acid powder is extremely cheap, the problem is the fuming process to coat parts, is not selective , the whole part has to treated in this method. If epilame residue can cause wear then thats not good, if I remember the conclusion was not proved entirely just a general assumption between watchmakers. The thread is out there somewhere, the same discussion is also old on a facebook group.
    • Following on from my question about identifying screws in the AS2063 movement that basically fell out of the case in bits, I’m pleased to report that I’ve got it all back together, and the movement is running pretty well.    But… There’s something wrong with the keyless works and hand setting. It’s fine in winding and quickset date position - these work - but in hand setting position winding the crown turns the whole gear train.  I don’t really understand how it’s meant to work. It doesn’t have a traditional friction fit cannon pinion.  The second wheel is unusual with a pair of smaller pinions on it, which seem to interact with the barrel and the motion works.    Could this be the problem? I must admit I just cleaned it and popped it in place when reassembling the gear train. I’ve lubricated the pivots but didn’t do anything to the extra bits on the second wheel.    Does this make sense and is anyone able to figure out what I’m doing wrong? Thanks in advance, as always.    ETA - the parts list calls it the Great Wheel, not second wheel.
    • You're thinking metal to jewel in general I guess. Maybe it would be a good idea to peg the pallet staff jewel hole on the main plate after the epilame treatment. I think that could work as it is my impression that the epilame doesn't sit very hard, but I could be wrong about that so feel free to educate me. I didn't remember that 9501 was thixotropic (thanks for the link). That would mean it's even runnier during impact (lower viscosity) so perhaps it's time I get some fresh grease as mine seems a bit too runny. What I have seen is a whitish surface after washing but it goes away if I scrub the surface with a brush in a degreaser (Horosolv). I don't think it embeds itself in the metal but sticks very hard to the metal. I don't worry too much about the cleaning solution. I just want perfectly clean parts and my solution can be replaced for little money (ELMA RED 1:9). Anyway, I quite often need "to strip back and rebuild" and scrubbing parts by hand isn't exactly the most stimulating part of a service. Just got confirmation that Moebius 9501 has a lower viscosity (68 cSt at 20° C) than 9504 (305 cSt at 20°). The viscosity of Molykote DX is 285-315 cSt at -25° to +125° C. I was surprised to see that the viscosity of Moebius 9010 (thin oil!) is higher (150 cSt at 20°) than my 9501 grease!
    • I’ve had a couple movements where it is clear the previous watchmaker was diligent with lubrication but the old epilam had turned to a fine white powder covering the pallet fork and keyless parts, which can’t be good for parts. I’m spare with epi since I don’t know how long it takes to degrade to that state…
    • I have read some suggestions that it can cause wear , particularly on the fork horns of a fully treated pallet fork. I've had half a kilo of steriac acid powder on a shelf for almost a year now, might have a little play today with a heater and a jar.  I think its because it gets into their cleaning solutions Mike. Theirs or anyone else's that services the watch next time, or if they need to strip back and rebuild. Could preclean but thats all time for a pro. I thought the idea was for the epilame to create a barrier, a wall between the lubrication and anything else, so the lube cant spread.
