Watch Hand Metal?
dpn
So, I'm looking for an inexpensive supply of steel hands to practice heat bluing with.
Looking at esslinger.com, there are lots of "silver" hands available for a reasonable price. E.g.: 114 Piece White Multi-Style Watch Hands, White Dauphine Style Hour and Minute Hands, etc.
There are also, of course, a myriad of cheap silver Chinese hands available on eBay.
Does anyone know what metal inexpensive "silver" hands are typically made out of? I'm very, very new to this, and honestly don't know whether hands are typically steel, anodized aluminum, or whatever ...
Thanks in advance for any tips and advice!
Steel is what you want. Preferably stainless. Get a magnet- good quality 304, 306, 316 stainless alloy will be non magnetic. Try ofrei and kas-ker. otherwise vintage NOS is always good but like we talked about-can get spendy.
Otherwise some can be cheap tin or aluminium. Even plastic.
Stainless steel won't blue; I don't know of any watch hands being made of it either.
If the supplier doesn't state or know the material check them with a magnet. Hands can be almost any material from gold to plastic but brass and steel are the most common.
Yeah, they're out there. All modern day stuff. Micro brands.   Depending what grade and carbon content they contain  they will turn color tho. Manufcrs. don't list the grades tho lol. Just keep my trusty magnet handy. melted a plastic set once..
I've got my propane torch, my IR thermometer, my brass scarf, my brass heating box, and my polishing stuff all either here or on the way.
I honestly didn't think that finding steel hands was going to be the hard part! *grin*
I can practice a lot with screws and old blued hands, but if I want to actually make usable hands I'm going to need to figure out a supplier.
Interestingly, Esslinger has been super quick to reply to my parts inquiries. My inquiry about what makes up their "silver" hands has been met with silence, so I agree they're likely to be some kind of mystery anodized or coated base metal.
This has been, and will continue to be, a fascinating exercise. I'm going to be cross-posting on the NAWCC forums, since there's a lot of good heat-bluing info there. Maybe someone will have a good supplier they'll be willing to share.
The better the quality of the steel and with practice the better the bluing will be, you should have an even blue colour all the same. I always quenched clock hands and screws in oil, it would give a shine look and not a dull finish.
Where did you find the swarf and heat tray?
Do you every get the black tar-like crud on them when you do this? Ever had and luck with just air cool down?
If its screws after they have be cleaned and polished, I would put them in an old watch cleaning machine to make sure all dirt got completely removed, crud can be caused by bluing something that still has dirt or grease on it. Hands would be washed in soft soap and warm water and dried in a lint free cloth before bluing.
    • Following on from my question about identifying screws in the AS2063 movement that basically fell out of the case in bits, I’m pleased to report that I’ve got it all back together, and the movement is running pretty well.    But… There’s something wrong with the keyless works and hand setting. It’s fine in winding and quickset date position - these work - but in hand setting position winding the crown turns the whole gear train.  I don’t really understand how it’s meant to work. It doesn’t have a traditional friction fit cannon pinion.  The second wheel is unusual with a pair of smaller pinions on it, which seem to interact with the barrel and the motion works.    Could this be the problem? I must admit I just cleaned it and popped it in place when reassembling the gear train. I’ve lubricated the pivots but didn’t do anything to the extra bits on the second wheel.    Does this make sense and is anyone able to figure out what I’m doing wrong? Thanks in advance, as always.
    • You're thinking metal to jewel in general I guess. Maybe it would be a good idea to peg the pallet staff jewel hole on the main plate after the epilame treatment. I think that could work as it is my impression that the epilame doesn't sit very hard, but I could be wrong about that so feel free to educate me. I didn't remember that 9501 was thixotropic (thanks for the link). That would mean it's even runnier during impact (lower viscosity) so perhaps it's time I get some fresh grease as mine seems a bit too runny. What I have seen is a whitish surface after washing but it goes away if I scrub the surface with a brush in a degreaser (Horosolv). I don't think it embeds itself in the metal but sticks very hard to the metal. I don't worry too much about the cleaning solution. I just want perfectly clean parts and my solution can be replaced for little money (ELMA RED 1:9). Anyway, I quite often need "to strip back and rebuild" and scrubbing parts by hand isn't exactly the most stimulating part of a service. Just got confirmation that Moebius 9501 has a lower viscosity (68 at 20° C) than 9504 (305 at 20°). The viscosity of Molykote DX is 285-315 at -25° to +125° C.
    • I’ve had a couple movements where it is clear the previous watchmaker was diligent with lubrication but the old epilam had turned to a fine white powder covering the pallet fork and keyless parts, which can’t be good for parts. I’m spare with epi since I don’t know how long it takes to degrade to that state…
    • I have read some suggestions that it can cause wear , particularly on the fork horns of a fully treated pallet fork. I've had half a kilo of steriac acid powder on a shelf for almost a year now, might have a little play today with a heater and a jar.  I think its because it gets into their cleaning solutions Mike. Theirs or anyone else's that services the watch next time, or if they need to strip back and rebuild. Could preclean but thats all time for a pro. I thought the idea was for the epilame to create a barrier, a wall between the lubrication and anything else, so the lube cant spread.
    • As I'm only cleaning watches in small numbers at home, I pre-clean any significant deposits of old grease and oil before using the cleaning solutions. I scrape off deposits with pegwood and Rodico, and if really dirty, wash parts in naphtha with a brush.  So I'm happy using DX, but can understand why it's avoided by the pros.
