IWC Calibre 52 regulation
I love these. I just got my first, a 5M42 0E39 (picked up on eBay) with the grey dial. I was keen to get the original band but alas, it came with an all stainless aftermarket. Where can I get an original band? I do hear about the rubber parts are usually pretty deteriorated. If you get an original can you re-use the metal bits and add them to a new rubber strap?
Given more time and more practice it'll become easier once you get the feel for it.
Dimensions stated were accurate, and exactly matched that of the old crystal. Regretfully i didn't measure the final dimensions of the new crystal after i had removed material as was sanding and then testing against the case until it went in.
So how did the dimensions stated as 30.1 x 25.3 compare with what you received and how do those figures compare with the original.
Sorry, had to leave for work, will post photo when I finish.
