Rolex Air King 3130 - not able to set time
So the crown should be a 0.9mm thread as you've ordered. How do you know the thread size is wrong if you've not removed the broken stem yet?
You'll need to be extra careful with the Citizen as Information along with Parts and Donors are pretty much none existing. You'll probably end up having to use a stem extender, that's hoping there's enough stem left in the movement.
By Embezelled · Posted
Thank you! That's immensely helpful. I appreciate the trouble you've taken. The initial hiccup aside, I do hope to treat this watch with great care and respect. I've certainly learned one thing not to do, and also just the general need to start out very slowly and very carefully. -
166.128 is the case reference number and the Omega logo is on the crown. This is the watch.
By TimepieceTinkerer · Posted
Hi all, I recently bought a pre-owned Elma Super Elite watch parts cleaner. The baskets had some rust, which I cleaned about 90% without damaging them. But recently I’ve noticed more rust appearing. I have two questions: Could this rust affect watch parts during the cleaning process? If I replace the baskets with new original ones, is rust likely to return in the future? Any advice or experience would be much appreciated! Thanks! TT
