INGERSOLL SEALION 1977 ... REBIRTH
After working on it for a few months I've think it's time to create a specific thread about the Ingersoll Sealion that @Johnnie offered me on that thread here.
I already had made a custom bezel for it, as neither Johnnie nor me ever found anyone available on the web, but I had made it a little too "aged" and to "orange" so it didn't really matched the color and condition of the dial.
So yesterday I've decided to redo that bezel and, while there, do some more renovation work.
So I've dismantled it once again, polished the case, crown and caseback a little more, used some toothpaste and polywatch to get a nice clear and shiny plexi.
After polishing the caseback I took a close picture and saw that it certainly had, at a time, some brushing on the flat part which is engraved ... so I've decided to try to redo that brushing and here is the result ...
CASEBACK AFTER POLISHING
CASEBACK REBRUSHED
After casing the movement and before putting the caseback on, I've took some pictures of the Ronda 1217-21 movement ...
RONDA 1217-21
INGERSOLL ENGRAVING
1217-21 MODEL ENGRAVING
SWIIS ENGRAVING ... so that movement is definitely Swiss
And the nice Ronda star with RL inside ... probably meaning "Ronda Lausen"
And now today's wristchecks ... showing the "finished" watch with it's new bezel, less aged and more reddish ...
Maybe some day I'll dismantle it again to redo the lume, which is almost "dead" ... of course if I do that I'll take care to make the lume really low, as it should be on a 43 years old watch ...
Very nice. A quick "How to" on making that bezel would be greatly appreciated, it really hits the mark.
Thanks ...
I didn't took pics while making the bezel but I can ain the method, which is sort of basic.
For the bezel ring I've modified a spare one that was on my drawers and whose exterior diameter fitted the watch ... I've just sanded the inside diameter until it can turn easily around the plexi, with a gap of about 1/4mm ... so you just have to work slowly as if you go to far then the bezel ring is loose ...
For the paperclip spring is used ... a paperclip ... I just sanded it to make it thinner so that it can fit to the inner groove of the bezel ring ...
The "printing" and "applying" is the only tricky part ...
I first drew the design on Illustrator at 2400ppi then up to 4000ppi on Photoshop ... it took me hours as I didn't found any font matching the original one so I had to design every letter and number ... one by one ...
Then I printed the design, reversed, on sunnyscopa film-free decal paper ... I first made many test on glossy photo paper to get the "right" red colour ... of course I've used a laser printer as film-free decals need toner and not ink ...
Then I applied the decal on the prepared bezel (sanded 2000 grit) ...
You have to gain some experience to achieve that :
- Glue and applying :
Let the glue cure too much and you can't positionate the decal properly ... let it cure not enough and the decal slips while heating ... when properly applied you need let that cure about 5 mns, remove all bubbles, then let cure again about 1/4 hour before heating ...
- Heating :
Heat too much or to closely and the film will shrink ... not enough and the toner won't adhere to the metal ... I heat with a hair dryer for about 2mns at medium heat, gently press to make the toner adhere, leat the metal cool, heat for 3mns again at high heat, gently press again, let the metal cool again then gently remove the film ... of course time and heating depends on the temperature in the room you work ...
- Remove the film :
Tat's when you know if you worked properly, or not, while going and and heating and there's no way back ...
If the result is bad you just have to remove the toner with nail varnish remover and start everything again ...
If the result is OK you wash the bezel with cold water to remove all the remains of glue ... you can rub with your fingers as the toner is already hard ...
Then you heat again at high heat for about 5mns to make the toner melt again and when cooled it becomes incredibly scratchproof ... really amazing how hard it becomes ...
You also can do the last heating in a kitchen oven but some metal becomes yellowish if heated too much so you have to take care to heat less than 180/200°C ... and if there is any glue remaining it will become yellow too ...
So all that's why I wrote about gaining experience ... when I begun using film-free decal papers the score was 10 trials/1 success ... now it's about 2/1 only ...
  • 3 years later...
Hi Manodeoro,  Great Job !  Your post has motivated me to have my watch, which is identical to yours, profesionally restored. Mine was a 18th birthday gift in 1972. I can not remember what the original watch strap looked like as it had a wide leather one since the late 70s. Is the steel strap you have used the original style ? saying that, yours may be different if its a 1977 watch, I have written to Ingersoll but had not reply. Many Thanks.
    • It looks like the canon pinion function is part of this great wheel. The pinion nearest the clip runs the minute wheel on the dual side. The pinion nearest the wheel is driven by a small wheel from under the setting lever cover plate that engages in hand setting position.    So when assembled the crown was driving the whole great train. Does this mean the pinions are too tight? Should I attempt to disassemble this great wheel and lubricants?
    • Picking up this side-tracked post again as I just removed a balance staff of a 1920's Omega (35,5L-T1) I was impressed by the way @Delgetti had his setup when he had to change out a balance-staff (https://www.watchrepairtalk.com/topic/28854-new-balance-staff-not-riveting-to-balance/page/2/#comment-244054 Not only that, but also the idea of removing the seat first before punching the staff out from the seat-side, avoiding the whole discussion of the rivet yes/no enlarging the hole. I didn't have the fancy clamps & tools Delgetti has, so I used my screw-head polishing tool. Initially I used #1500 grit diamond paste on the steel wheel, which kinda worked, but very slow. I changed to #800 grit diamond paste, which worked better, but still slow. Then I glued #240 sanding paper to the steel disk; That worked and the disk was hand-driven. Once close to the balance wheel, I took the sanding paper off and continued with #800 diamond paste. One can only do this when the balance wheel sits true on the staff and has no "wobble". I went on grinding until I saw some diamond paste on the rim of the balance wheel. This was as far as I could grind and it seemed that there wasn't much left of the seat. Carefully, with my staking set, I knocked the staff from the seat-side out. Turns out that the thickness of the seat left, now a small ring, was only 0.1mm. The balance wheel hole is in perfect shape and no damage done to the wheel at all. Of course, if the wheel has a "wobble" or isn't seated true on the balance staff, you can't get as close and there will be more left of the seat. In my case, it all worked perfect 🙂 I'm very happy how this worked for me 😊
    • As is tradition, one step forward, two steps back. Got the board populated and soldered into place without any issues.   But no hum. So I started testing the coils with an ohmmeter. I got 5.84k ohms across D1 (from red to red in the picture below), which is as expected. But I'm getting an open circuit for the other drive coil and feedback coil, D2 and F1 (from green to each of the two yellows).   Since the movement was working with my breadboard setup, it implies I somehow broke the connection between the coils and the solder lugs. They're all the way at the bottom of the lugs, but maybe the heat migrated down and broke the connections? I guess it's possible it happened while cleaning the flux off, but I used a soft artist's brush and isopropyl alcohol. I did a lot of high magnification examination, and I don't see any issues, but let me know if you see anything I missed or if you can think of anything else I should check.
    • 1947 NOS Ambassador 'C'. Actually, the case came without the movement so the movement isn't NOS, but she sure is pretty.
    • Hi attached is the AS 20XX. Service sheet although there is no 2063 mentioned it may be of some use to you AS_AS 2060,1,2,6,4,6.pdf
