Initial greetings
RoyC
Hi. My name is Roy and I'm an amateur horologist aspiring to be less amateur. I'm in my 70s, groan.
I've collected (ie accumulated) modestly for decades. Nothing very exotic because my income has always been distinctly non-exotic. Though one of my closest friends I've also acquired a vast quantity of unsold parts, movements and complete watches. For the last few years I've been working through them, selling off the immediately usable items and gradually working my way though them, repairing at various levels of complexity  and difficulty. Lots of crippled  watches in my wake but it's getting smaller. Like most things in life you have to start out being very bad at difficult tasks, passing though the slightly less bad and approaching the not too bad if time permits - which at my age is a constant consideration. I wish I'd started on this path earlier however "if i knew then what I know now.... etc" is a refrain that most of us start singing if we live long enough.
I'm fortunate in that I have a good relationship with a horologist who does the more demanding work for me. We're also friendly so it's better than a purely commercial relationship. I try not to pester him too much for advice. I'm always in need of advice.
Mark's tutorials are simply outstanding - there's nothing else that I've seen on YT that even compares where this subject's concerned.
Roy
PS Anyone got a spare good LIP T18 balance kicking around that they don't need?  I have a good HS. Well, you gotta ask.......
    • yes the things we read in the universe I did see some where it was either difficult to clean off or it contaminated the cleaning fluid there was some issue with cleaning. I was trying to remember something about grease where as opposed to a substance of a specific consistency they were suggesting it had a base oil with something to thicken it. That conceivably could indicate that the two could separate and that would be an issue. But there is something else going on here that I had remembered so I have a link below and the description of the 9501 notice the word that I highlighted? Notice that word appears quite a bit on this particular page like 9415 has that property all so they 8200 mainspring grease and that definitely has to be mixed up when you go to use it because it definitely separates. just in case you didn't remember that nifty word there is a Wikipedia entry. https://en.wikipedia.org/wiki/Thixotropy   https://www.moebius-lubricants.ch/en/products/greases I wonder if what you're seeing is the boron nitride left behind after cleaning. In other words it's the high-pressure part of the grease and it's probably embedding itself into the metal which is why it doesn't clean off and shouldn't be a problem?
    • Hi not found one either yet,  close relative is the 436 and 4361 according to ranff.db.   It gives quire a lot of detail but not as good as the old site.      RANFF.DB.
    • No problem to replace the setting with the staking set. Press the new setting from inside, use flat face punch with hole. The punch must be wider than the setting, the hole to be as not to press at the stone, but only on the bush. Press by hand until the setting gets flush with the plate surface, so the punch must rest on it.
    • Yes, the arbor usually makes about 3 to 3.5 turns. But usually spring takes 2/3 to 3/4 of the free space in barrel, not 1/2, so take it for the calcullations. This way the change in torque is smaller. I have a picture for You, this one is little older, but no mater
