 Is it just me or does anyone else have a problem with Lemon Pledge?
Lemon Pledge seemed like a godsend. You could bring back the shine to dull furniture with just a quick wipe down. My last cleaning lady got her hands on a can of it and literally Lemon Pledged every wooden thing in my house.
But when you stop using it after a few years, the wood looks worse than it first started. I've tried cleaning it with detergent, Old English Oil, other brands of wood polish, even wd40. But the white, dried out look reappears after a short while. The only thing that restores the shine for a few more year is Lemon Pledge again.
It was the same with Armor All.
I hate to be forced to continue using a product for the rest of my life.
Try googling silicone oil in wood finishes as I suspect that that is the culprit.
It is what produces that instant glossy shine so easily on just about any surface but from what I understand it can cause problem if it gets through the original finish and into the wood and then you get this effect.
You may be able to break the tie to Pledge just by finding another furniture polish with silicone oil in it, but if you want break the tie with silicone oil then you will probably have to refinish the wood.
A wax polish is best if you want a more permanent finish on your furniture. You also need to consider the type of wood you are going to polish. Wax needs to build up, so you won't see good results  right away. Pledge and alike is only good on modern furniture
For restoration, I use Briwax applied with 0000 wire wool. Stinks to high heaven but the results are worth it. (Best after a light rub over with white spirit.)
Sent from my moto g(6) play using Tapatalk
You might also try a little heat. Sometimes the issue is that moisture gets sealed in behind the finish because the silicone acts as an impermeable barrier. Gently heating with an iron on a cotton cloth (don't use synthetic material) may drive out the moisture. Alternatively, you can try alcohol. Be very careful that you don't make things worse.
Finally, try to avoid silicone based polish/cleaners, they are a pain. Stick with beeswax if you can.   They take more work, but they are far more forgiving and easier to fix when you get problems.
Edited by AndyHull
What is going on depends on what the finish is that's doing it. Most furniture built since probably the 70s is going to have a polyurethane finish on it. It's essentially a coating of plastic, and when plastic breaks down it gets chalky like that. Plastics, as we all know, don't like oils, lemon Pledge has lemon oil, bam! Chalky. Unfortunately, there's not a ton you can actually do. All of the poly on that wood has been subjected to the same treatment. If you were to brush off the chalkiness with a stiff bristle brush and put something over it, the rest will continue to chalk up underneath before you know it. Refinishing is about your only option for a real repair.
Short of that, assuming you don't want to go through the hassle or expense, brush off what you can of the chalkiness with a stiff nylon brush. The wax suggested above will help, but it's not permanent. Wax is soft, stays soft, and will come off with wear, which is why it needs to be constantly reapplied. Traditionally, "wax" is something like 25% beeswax 75% oil, so you have that oil problem again. Still, you're already hooped, and it'll look reasonably nice for a while, so...
Another option to consider may be a drying oil. A light coat of boiled linseed oil might seal things up in a lower maintenance fashion. Wipe on, wipe off; you want the barest, thinnest coat since it'll likely only adhere very well to the rough stuff. It's oil still, but it quickly polymerizes and hardens. It'll still chalk up underneath over time, and maybe even quicker than it would with the wax since you wouldn't be rubbing off the chalkiness with subsequent applications, but it's one and done.
Finally, the watchmaker's favorite, shellac. Shellac will go over just about anything. It'll seal things up nicely, if you use the blonde stuff it won't affect the color, and just a light coat or two will just barely up the gloss. It'll still chalk underneath, but that's kinda what you're stuck with at this point.
Thank you very much for all your answers. But resistance was futile. I went back to using Pledge because I still have a large can of it.
I bought the can while restoring an antique longcase clock. The owner must have used Pledge in the past. Whatever I  used, furniture polish, furniture wax, etc, just wouldn't work. It may look good right after I polished the wood but a few days later the white, moldy appearance returns.
I found that Pledge was the only product that that could give a lasting shine. It appears that once an item has been Pledged, nothing else can fix it. So.... NEVER apply Pledge to wood if it has never been Pledged before.
  • 4 years later...
I had the same experience with Lemon Pledge on my garden furniture. It worked great at first, bringing back the shine and making everything look pristine, but after a while, the furniture started looking even worse than before. It's like it left this weird dried-out white residue that just never seemed to go away, no matter what I tried.
I even used Old English Oil and some other wood care products, but nothing worked as well as Lemon Pledge—until it wore off again. It feels like I'm stuck in this cycle of needing it forever!  source: just my own frustrating experience! It’s frustrating to rely on something that makes you feel like you're just patching it up.
    • A helpful way in aid of assembly is to place all the wheels in their respective places, place to plate on the top and fit a couple of the nuts onto the pillars. This stops all the wheels wobbling about as they are lightly held by the plate, you can manoeuvre the pivots into their holes, using a tool , usually home made or can be bought on eBay. I made my own. As the pivots align and fall into place screw the nuts down a bit to keep up the tension on the plate untill all wheels are in place then tighten down sufficiently to keep the plate in place whilst checking the end shake on ALL wheels and their location when all is good only then tighten down the plate.
    • I'd say my Pultra 10 lathe. It is just so well made and everything fits so tightly together.
    • Yes, the specific old tools do exist, but may be having one is not needed as they are not cheap, and also You will be able to do without it well enough. My advice will be to use regular depthing tool and adjust it for the exact distance between pallet fork and escape wheel bearings from the watch. Then remove the shellac from the pallet that now doesn't pass the ew teeth and move this pallet in. Then put the pallet fork and ew on the depthing tool and check how they lock. They should not lock when the pallet is in, but You will little by little move the pallet out and locking will appear. Then move just an idea out for reliable work and apply shellac, then check if things are still the same. You have to observe where the teeth fall on the pallets - it must be just a little below the edge between impulse and rest planes. Then You must check how everything behaves in the movement This Potence tool is so ingenious, but actually, the traditional way to do the things is much more simple. Arrange the parts not on the pillar plate, but on the cover plate. Only the central wheel will remain on the pillar plate, secured by the cannon pinion.
    • There is a tool that was made for setting up and adjusting escapements of full plate watches.  There were two styles, the picture below shows both of them.  The lower tool held a movement plate and the vertical pointed rods were adjusted to hold the unsupported pivots of the lever and escape wheel.  There was also a version of this tool that had 3 adjustable safety centres so that the balance pivot could be supported by the tool :  The other version I’m aware of is the Boynton’s Escapement Matching and Examining Tool came as a set of two or three clamps that gripped the watch plate and held the safety centres for the pivots : These do turn up on eBay from time to time.  For some escapement work, you can set up the parts in a regular depthing tool, with the centres set according to the distance between the corresponding pivot holes on the movement.  I hope this helps, Mark
