checking in
Thank you for your introduction and welcome to this friendly forum.
I think that is the briefest introduction I have seen on this forum.:D It would be nice to tell us a little about yourself. What is your interest in watches/clocks.
Haha. Okay, I'm a late 40s dude with a military background and also a financial planners work history. I've been in financial services for 15 years and wanted to make a change given the circumstances in the world. I've been a mechanic since I was a pup and the last time enlisted in the army, I worked on Apache helicopters (D models). It's been a hell of a road over my life. I really wanted to immerse myself in a craft that is as precision as aircraft maintenance without the physical requirements, since I had some major surgery caused by my last enlistment. What I really want to accomplish one day is to create a watch from scratch and to make it a custom piece; I saw a watch that was made entirely from wood (except the mainspring and hairspring) and I just fell in love. I feel I have enough creativity and ingenuity to pull it off and most importantly, I love this kind of work! I look forward to my career in watchmaking.
    • Hi everyone, I put together a Venus 178 recently, but found that the hour counter "creeps" ie. runs when the chrono is disengaged. This is the similar type of setup as the Omega 861, where the hour counter is driven off the mainspring barrel, but stopped when the chrono is disengaged by a friction spring.  Am I correct in assuming that the friction spring for the hour counter driving pinion should be dry? I am guessing that the issue will be either the spring or the driving pinion, but while the driving pinion has some wear the spring looks decent.  I've attached a couple of photos in case anyone has any tips. Thanks in advance!
    • Thanks everyone for the replies. It seems setting the hand is a bit of a guessing game, and I thought there would be a very specific way to do it. Since the reserve indicator hand moves clockwise as the spring is wound, I tried setting it right at the start of the black side. But setting it there doesn't really make sense, because by the time the spring is halfway wound, the hand is only at the end of the red side... In my head halfway wound shouldn't mean the hand is still "in the red."
    • Lovely part of the country! I spend most of my days driving along the A64 for work in and around York. I'll be sure to drop plenty of questions soon! I've actually got a couple of watches on the way that I'm pretty sure I'll need some help with! They look pretty beat up from the pics but I love a challenge and an excuse to buy more tools 🤣
    • I have two of these in my home. You need to remove the movement from the case, take off the hands and remove the dial and take a few good photos of the front plate so I can see what the problem is. The round nut unscrews and the hands pull off pull them off from the center and not the tips as you could break them.
    • I asked the question of one of the sellers. Its for removing the pins and making the holes in motorbike drive belts. God knows why they were both in two seperate joblots of watchmaking tool, thats bizarre. I haven't posted your setting lever steel yet mike, been busy with my mum past few days and had a locked myself in at home lazy watch repair day today 🙂 but I'm out tomorrow so i will get it off to you then.
