Re-bushing an FHF 15 cm movement
Joseph111
I have just stripped down an old FHF (old Hermle) clock movement and have noticed that there is a lot of wear on both the front and back plates from the pivots and I an fairly sure it needs new bushings fitting.
I have never had to do this before and was hoping for some general advice on how to do it, as well as what tools to potentially use. I am still working on dismantling the chiming mechanism which seemed to be jamming the main clock train every 15 minutes.
Sorry about the delayed responce, I hadn't set up email notifications.
Here are two pictures of a couple of the worn bearings, I couldn't get a proper picture of the full plate as my phone wouldn't focus properly.
Thank you for your help. I should say that the clock did work (although the chimes are a problem) but I wanted to try and replace the bushings before they got any worse.
Hi   The top pic the bearing is badly worn  the bottom one looks circular but that's not to say there is wear, in bothe cases check the pivots running in the bearing. once everything is ready and waiting then do the rebush, Moose had a similar problem and with help made a grand job of the bushing, so its not an impossible job and can be done by hand.  It takes care and a steady hand
I will have access to a pillar drill when I do the repair so that may help.
As for the punch marks, I have no idea where it has come from but before I first had a look at it a year ago, it hadn't worked in around 40 years and before that I don't know how often it was serviced.
Thank you for all the suggestions and help. I will get on with it when we are all allowed out again.
Make sure you drill where the centre of the whole used to be, rather than where the drill bit wants to take you, or if it is a small hole, try reaming it out with a jewelling tool, or a clock reaming tool if bigger. There will be a greater degree of control, because everything is slower
Like John says  use a broach to cut the hole, I have used a pillar drill Necked down with a pin chuck but use a s short a bit as you can it stops it wandering. If you file out the hole fron the unworn side to even it up it helps to keep the drill/broach in the center . have a look at the link fir guidence                 https://www.davewestclocks.co.uk/Bushing.clock.plates.htm.
    • Mark keeps a close eye on his forum. I'm sure if you asked him he will reply, he might not do it right away but you will receive his answer.
    • I kind of think the same, the surface under the oil is the same as the surface around the oil. Can epilame both repel and attract , that doesn't quite make sense in simple terms, but is it more complicated than that. When cohesive forces within a liquid are stronger than the adhesive forces of a surface then surface tension is high causing the liquid to bead up. So  an applied epilame coating reduces the adhesive force of a surface inhibiting a fluid to wet the surface. So i guess no epilame cannot both repel and attract . If something is keeping the oil in place on top of an epilamed surface then there must be another reason for that.
    • I agree with @JohnR725. Oil on an epilamed surface is essentially the same as water on a waxed surface. The same physical properties are at work (surface tension vs. adhesion).
    • I think we all get a lot out of this group, and it has been pivotal in my development by the sharing of knowledge, experience and learning from more seasoned experts such as @JohnR725 and others (you know who you are!) as well as fellow novices. I think that having a backup communication plan in reserve so that if there is a future problem just makes good sense. I don't think anyone is trying to undermine the forum, but if something unthinkable happens, like the Ranfft website for example, then it would be good if those who are willing can still keep in contact. Speaking personally, and I know I risk a charge of heresy, it would be good if Mark could be a little more visible in this forum, and maybe give any insight from time to time on the future/progress of forum and instructional videos etc. even if its just to confirm the status quo. I appreciate he is a busy man with a full time job, but so are most of the rest of us and to post a few lines every now and then shouldn't be too much to ask to reassure the restless villagers. Best outcome for me would be a message saying something along the lines of: "Hi guys, all good, no planned changes... enjoy the forum, will message again next month!" Just my two cents.
    • A nice looking watch !! Did you try 9010, instead of the 9415, on the pallet jewels / escape wheel? And if you did, did you notice a difference?
