Vintage one day wind clock,cannot time it
chriseames168
Hi,hope someone can help me please.have a old vintage air spring one day wind up clock and cannot time it, the adjustment on the air spring is not doing anything,and the clock just running away and time is not any issues on the hands,how can you resolve this problem.been trying to adjust spring but beat goes out and stops.
I would say it could have had a different spring fitted and its to strong or it has the wrong hairspring. My guess its the main spring. Try a weaker spring. I cant tell by the photo but the movement looks like a 2 inch movement, if so it should be replaceable. Do you know the size?
Looking at today's clock part suppliers, it looks as if they only supply Quirts movements , no longer do they have the old 30 hour ones. So I don't know what you would like to do, look at suppliers and get a Quirts or try a weaker spring.
Hairsprings coil, should be flat, level and concentric.
It looks unlevel and  not concentric in the picture, likely to touch the main plate.
Luckily, It looks undamaged though, perhaps the regulator are in pushed down causing the coil to sit oblique.
Check what is causing the hairsprings to sit unlevel, it will time fine once hairsprings is sorted out.
Perhaps the picture did not open for OH.
Edited by Nucejoe
Correction Regulator arm is pushed down.
How do you get the regulator arm back up then please,if pushed down,
On 3/9/2020 at 10:04 PM, chriseames168 said:
Hairsprings coil clearly touches the regulator pin.as the coil expands in every oscillation, effectively shortening the active length of hairspring,  the coil is also not concentric and unlebel unlevel.  Therefore, runs fast.
The issue with the main spring OH is helping with, is totally another issue.
Hi   Has this clock been dismantled and cleaned,  and the balance re fitted because as Nucejoe explained the spring is not concentric and bearing on the regulator.  I would un pin the balancespring and remove the balance and check the concentricity of the spring and its flatness. Having done that re fit the balance .and refit the spring through the regulator slot and re pin lightly maintaining the flat profile and getting the balance in beat   you should be able to  move the regulator aroung the arc of the outer coil without it moving the coil, If that happens then the spring will require adjustment to achieve that aim. Without that timing the clock will be a lottery.
11 minutes ago, chriseames168 said:
Ok thank you,how do you stop the pin touching coil without it going out of beat.
Manipulate the hairspring to get all circles concentric. Mark teaches it in one of his lessons. Start by pushing on the free end of hairspring ( between reg pin and the stud)
I feel I must apologies for the remarks I have given about the problem with this clock. My eyes are not good these days, it wasn’t until a member mentioned that the hairspring wasn’t right that I magnified the photos to take a look. I could then see what the problem was. Well done members for sorting this out. I will now sit in the corner.
To our much beloved master watchmaker moderator  OH :bow::bow::bow: .
1 hour ago, oldhippy said:
If you have let the hairspring out as far as it will go and it is good between the regulator in all positions. I'm assuming the balance has a good action.  Then you need to try as I previously said a weaker mainspring.
Hi OH, Am I right to think, a mainspring partially wound, correspondingly delivers less torque. If so, for instance,  OP can wind a third of full, thence get less torque, in effect as if using  a weaker spring.
Hi Chris, will you mark on the pic the part you think a gear should be mounted on.
Hi  What sort of a rate error do you have, is is gaining substansialy,  You say the balance is running too fast, from that I deduce that it is gaining in time. If you could quantify it   e.g.   10min   per Hour.  and as Old Hippy said is the balance spring pinned at its limit and is the beat ok.     There is an app on the apple store (CLOCKMASTER ) which is handy for tuning clocks . I use it as a mobile device . There are others available but I personally found this one the best.              Cheers
    • Hi to Blackminou29–am a collector/ caretaker—good luck to you following your repair course—with hindsight I wish I’d pursued a career in both watchmaker/ jeweler fields—good luck with whatever career passion you engage.   Thank you Watchweasol for posting the amazing TZIllustratedGlossary! Best wishes, Mike
    • yes I noticed the new site and I miss the old site. It's the unfortunate problem of the Internet here today gone tomorrow sometimes some of the stuff gets backed up and sometimes well it does not then the problem with the early Seiko's were there were not necessarily designed for distribution across the planet and as such there is no customer support for them. So trying to find early stuff like technical information or sometimes even parts list for older Seiko is is problematic. But I did find you a you tube video. A quick look he seems to take a heck of a lot of time to actually get to the service single I did not watch all that but it does look like he did disassemble or started to say there's a tiny bit here
    • RichardHarris123: Hello and welcome from Leeds, England.  I have family all over Australia, went as £10 poms Thanks Richard. Hope you’re able to visit your family here and that they’ve all done well 🙂 My relatives arrived from England in the 1790s transported on the ‘Second & Third Fleets’—a story of timber sailing ships, of convicts and doing well in this huge Country of Australia. When I visited the UK in the 1980s, I was too young to comprehend the depth and breadth of its history…  Best wishes, Mike William Chapman, my 4th great Grandad’s charges, at age 23 read at the Old Bailey; sentenced to 7 years of transportation to Sydney.
    • The whole process and the progress are closely observed, it's hand-driven and very controlled. I can't see the "danger", unless you are watching the TV while doing it. As you could have read, and in this quote "wheel" is the balance-wheel.
