How to Open this Hamilton Electronic?
Of course it has a case back. Please get proper tools to work on this nice watch. There are blade type tools to easily open snap type case backs without the risk of damage to the piece or injury to yourself. It is also very possible that you will need a press to close it. Without these it's better to bring it to a good watch shop.
I can't see the pic from where I am, but I have a Hamilton electric that I have to pull out the stem (there is a couple that disconnects) and from there take off the crystal and the movement pops out. I believe there is probably a lot of information about taking movements out through the front that is around in a more general sense.
Cheers
Cheers
I was thinking this is a front loader.  There is literally no seem anywhere on the back.  So the crown has to come off and then the movement will come out.
This is a hamilton "Electronic" . From whagt I understand, it is later then the "Electric" . but finding info is hard because google always wants to give me results for "electric"
Actually one can see a small round notch at 9h, there must be a reason for that?
And assuming it's a front loader, then the crystal must be removed using a lifter (do you have one?) something that may leave some marks on the sides, can you see if there is any? The alternative could be a syringe.
Edited by jdm
I think it's a 2 piece case like vintage rotarys and some tissot.
You press down the crystal and the front should separate from the back (case  back, movement, dial, crystal, etc.).
Maybe more pictures would be nice from both sides.
EDIT: it quite possibly is a front loader as has been said so you might have to remove the stem but also crystal and the rest.
Edited by Chopin
this site has a similar (caseback) Hamilton for sale and the description mentiones 'monocoque case" ie movement comes out the front.
This site also has one (sold) and mentions a 'solid caseback'.
So it could be a one piece case with a split stem. If the crystal has a bezel then try to remove that, failing which just remove the crystal. Then see if the movement will drop out while rotating the crow, sometimes the split-stem will disengage when the slot is 90 degrees to the case.
Good luck.
Anilv
26 minutes ago, clockboy said:
For tight ones I use one of these which I have found this tool  invaluable.
Same principle, full metal, copy of now discontinued Elma :
Edited by jdm
1 hour ago, standarsh said:
“683” was stamped on the movement. Is ESA9154 a different movement?  I’m new to this
Just as many many brands put their name on calibers made by a different maker today so they did in the past. Up to the end of the 60s Hamilton made their own stuff, then moved operations to Switzerland, then by the mid 70s were bought by the company that became Swatch Group. So this movement was made by ESA (basically ETA), and they put the Hamilton name on it and a new caliber number.
Here's a link to the Ranfft page on this caliber http://www.ranfft.de/cgi-bin/bidfun-db.cgi?10&ranfft&0&2uswk&ETA-ESA_9154
Quote
    i have a"683"   as i recall,  there  were 2 mvt.'s.   my case and dial were bad.  when i got it out of the case (you don't want to know how i got it out - via a cross threaded back).   the mvt. ran with the batt. mentioned above.   i'll try to find it.   vin
Got it thanks. Just want to make sure I buy the correct battery in my break today so I can get it home and get it running then see what if anything else I will need to do to it.
is there a faster way to set the time other than spinning the clock 24hrs?  It’s set to 21 right now I don’t want to spin it through a month or wait til tomorrow to put battery in.
thanks again
    • I read that same article last night  H.  I think epilame is too much headache for me, sources aren't always accurate, some conflicting. Such is the GRAVITY of this situation, Is it ok if i just STICK  to a thixotropic oil 🤣
    • Not sure I follow along. As I stated in one of my previous posts, the epilame will remain intact between rubbing parts as long as the surface is lubricated by oil or grease. Maybe it's just a coincidence, but note how the epilame-treated surface is illustrated in @Waggy's post. It looks like the oil is exposed to a binder (epilame!) so that it can't move sideways.
    • The epilame under the oil will also be removed  Unless the oil makes a barrier between the epilame and the escape teeth 😅 I think i need two strong coffees now 🤣
    • If we use the rub-off epilame method of pallet stones (run dry for a few minutes before applying the epilame) where will the oil go/be transported when it is pushed away from the impulse surface by the escape wheel teeth? Onto the epilame-treated sections of the pallet! Once the oil has been applied/transported to the epilame-treated sections of the pallet where will it then go? Nowhere as the oil will remain on the epilame. So, perhaps the run-dry method defeats its intended purpose leaving the pallet impulse surfaces dry!? If, on the other hand, we do not remove the epilame from the pallet stones where the escape wheel teeth come in contact with them I'd expect more oil to remain where we want it and need it. Yes, I agree, that is the question, and my gut feeling tells me that is exactly the case. Epilame was created to have an adhesive trait and the oleophobic property is just a side effect.
    • Might that be the viscous nature of oil resisting gravity H  ,  we have been comparing water and hydrophobic surfaces which are similar in principle but water is much less viscous than oil. I guess what we trying to discover is if epilame also has an adhesive trait as well as being oleophobic. Plus the oil dropet has very little mass for gravity to work on, like watching tiny water beads that can grip onto vertical glass until they are connected together to increase their mass then run down. Gravity isn't the only factor at play when oil is placed on pallet stones. The oil receives a lot of bashing that may push it out of position ? Thinking about it if the oil stays in position for 10 minutes enough time for the escape wheel to scrape off the epilame , then  a walled in lubrication has been achieved,  the epilame is no longer beneath the oil ( possibly mixed into the oil )
