Good Morning - Mark from UK
Emsworthian
Morning all,
I'm a complete novice when it comes to watches, but have certainly caught the bug over the past couple of months.  Started with a 'Build your own watch from eBay parts' (with help from the excellent YouTube videos), and now I've moved on to the servicing/repair of a Seiko 5 with 7009 movement.  I have three observations from my initial foray:
  1. If there is an opportunity for anything to spring from the desk, it will
  2. Chances of finding something that has left the desk is about 10%
  3. It is going to take a while to become proficient with tweezers
My passion is repairing and restoring anything vintage, the last project was a 1963 Land Rover - sadly very little crossover in tooling!  For me, the process of restoration is almost more important than the end result.
I would like to find a few more Seiko 5's for repair and would welcome any guidance about sourcing watches for repair.  eBay is the obvious place to look but I'd welcome alternatives, thanks.
Mark.
Hi Mark,
Ohh nooo another competitor on ebay!!! :) Welcome to the forum. :) Watch Mark's videos and read books, its an amazing an exciting territory of life I just recently discovered. Watch your seating position and have a good light. Basically follow the advice is given by Mark or by the books. I was planning to buy a rolltop desk which would catch some of the parts flying, but could not find a place for it yet in the house. I am still rather screwing up watches rather than servicing them and everything takes a long time to master. :) Things which are 5 mins for Mark I can sometime spend 2-3 hours or a few days, beeing on my knees looking for parts, braking them and trying to find another part in my pile, trying to make something but I fail to do so, forgetting something to put in, scratching the movement/dial, ohh and the hairsping is beating even Freddy Krueger. Still its worth it.
lui
Welcome to the forum Mark I see you have already found some of the problems of watch repair.  I doing somthing trickey and there is a possibility of an escaper like clicks and click springs etc, work in a large plastic bag,       Not you        the watch it limits the distance the bit travel
    • When faced with say a pocket watch bridge which is cracked, silver soldering to repair is often the only option (hopefully someone wasn't there before hand with soft solder). I can generally do this succesfully and tidily with a small torch and miniscule pieces of silver solder, but on parts which were mercury amalgam gilded the heat can have have a deleterious effect on the finish.   I keep wondering if there's a good way to refinish these - and despite having the needful items would rather avoid using the mercury process.   In the past for electronic work I've gold plated PCBs but this involved gold potassium cyanide solution, which also doesn't realy belong at home. I've read that there are now safer alternatives but couldn't find more detail (and importantly how similar are the results to amalgam gilding, since I wouldn't want to refinish the whole watch). Pointers would be very welcome (and yes, I know solutions containing gold won't be cheap!) Alan
    • The first one is an Unruh max stake for pushing out staffs
    • Ok so with the great answers for my previous question may I ask what these two attachments are used for. The one with the red knob is I assume used for hand setting the seconds hand? Jon
    • According to Cousins site I need to look at document G22 as I think I need an ATGB at 304 but I cant find this size in G22 doc. The last thing I want to do is order the wrong one😳  Unless I cant see the wood for the trees 😆 I could be looking at the wrong style, I assume its classed as Round plastic Armed  https://www.cousinsuk.com/product/wide-ring-gold-atgb
    • When building a new Watch I have tended to use a file to remove the remnants of dial feet that are not needed as many dials come with four feet to accomodate different movements, but this can be a bit messy so now I use this with a great deal more precision as you can use an appropriate bit for the job and keep it very localised.
