I came across a Nivada with an AS 1130 caliber inside. When I started to dismantle it I saw that there was some sort of end cap jewel on one of the jewels in the train bridge and not one that I would  expect from looking at the pictures on ranfft.de were the end cap jewel is fitted into a metal plate that is then screwed to the bridge. This seems to be some sort of metal fitting keeping the jewel in place. My questions are what kind is it and how can I disassemble it and assemble it again for cleaning and lubrication ?
Hi  It is feaseably possible its some ones repair to the plate due to not having the correct jewel or the plate being damaged in some way and required drilling out and a jewel in a setting fitted. the tech sheets dont show it as standard, so I should treat it as jewel. Others may have a different opinion on this.  Attached sheets for AS1130
2448_AS 1130.pdf
I could be wrong but it looks like some rubbed in jewels have been fitted. Providing they are working OK just clean and lubricate in situ.
On  ranfft he makes the comment that there were several different bridge configurations. There's also a variant 1130N which doesn't have the metal plate on the escape wheel jewel. It's hard to see from the pic if it's just a plain jewel.
Perhaps you guys are correct and in that case it sure seems to be nicely done. The movement "worked" (as far as I can tell) when I disassembled it and I just wanted to give it a good clean and lubricate it. What do you mean with "in situ" ?
Def a repair.  Have seen this many times esp on old 7 jewel movements where someone added a jewel for the escape pivots or even the sub second wheel pivots. In this case the jewel was set In using a vintage tool set pictured below, this tool is used to remove and install jewels. Essentially they are openers and closers. The one half of the set (openers) spreads the metal out away from the jewel to allow for removal. The other half (closers) push the metal back over the jewel keeping it in place. This tool is especially used when adding a jewel that was not there in the first place and needing to use the metal of the bridge or plate to retain the jewel, rather than screws or setting. so in order to remove the cap jewel you will need to get one of these. You can lubricate this jewel by going from the bottom and using an auto oiler to insert the oil into the pivot hole deep enough to reach the cap, but if you don’t have one then you will have to use something thin enough to get in there and not make a mess which rodico alone wont be able to clean up, thus requiring you to re-clean and oil. I find that have a very small set of round smoothing broaches, like ,005-.015 work pretty well for this. You can essentially use them as an oiler, they hold oil pretty well. Not the best way to oil but when there is no other way you have to do the next best thing, its better than no oil esp on the escape wheel.
Edited by saswatch88
I think this is original. It's not uncommon at all to have one or two cap jewels at the escape wheel. In many cases we see this in higher end watches but also in common grades. The jewel count of 17 was sort of a magic number and consumers wanted to see at least that to know the watch was of a certain quality. I think you'll find you have exactly 17 jewels in this piece, including the cap jewel on the escape wheel. Almost certainly there isn't a plate jewel for the center wheel.
I can't really see from the photo but there's a good chance the retaining spring is removeable. In some cases they aren't; in those, if the maker was thoughtful there will be openings around the jewel usually on the underside to allow cleaning fluids to get in and out. Not the best design, but it works.
I was unable to remove the end cap jewel without risking breaking something real bad and I don't have an automatic oiler so I did as good as I could with cleaning and lubricating. The jewel had almost like a cup on the other side of the plate so I put some oil there after pegging. I'm pleased with the results I got from the watch timing machine so I will let it be for now.
I think it is a nice looking watch !
    • You're asking a pretty broad question and you didn't specify the machine but yes it's simple especially if you have the right machine. The question has problems but I'll take it as it is. Is it really that simple yes especially if you have the right machine. So in the video below he's making a screw and yes it really is that simple but pay attention to the machine it is not simple at all probably wasn't cheap but it is small it will probably fit in your garage. Unfortunately wouldn't fit in my garage as it's far too cluttered up with things. In the video he talks about making a screw and pay attention to the machine. The machine has lots and lots and lots of cutters and lots of things to do lots of machining all-in-one machine conceivably one step after another all programmable. If you look at his channel lots of CNC's stuff and there are several other videos related to this machine. He goes to the factory where they talk about it and show all the other machines they make in Switzerland.  I did look up the specifications the machine I don't recall the price it's not going to cut wheels I think it has a maximum diameter around 11 mm basically it's really good for making small diameter watch parts. Then in one of the other videos he goes to a factory that used to make parts with waterpowered machinery been in business for 100 years and everything they now make is made with CNC machines including this one. What was interesting with the factory photo was that when they make some parts they can put them on a optical comparator comparator compares with whatever the reference is and the machine can be programmed to adjust its cutting to make sure everything is actually being made to specifications. Oh and then somewhere in all of this there was at least one picture of a balance staff can't have a CNC Swiss machine without making balance staffs.   It would be really nice if we had pictures of the machine. Then yes if you look at the page for wheel cutting you can enter parameters and it will generate a G code but he left out things? Notice he has a picture of a complete wheel but the G code isn't making a complete wheel it's only cutting the gear teeth I don't see whereas the program for crossing out the spokes? Typically when you see people cutting gears once the teeth are cut most the time the spokes are cut by hand. Occasionally someone will mill them out but typically not with the program which seems strange if you have CNC capability for instance one of my friends fill it used to design assembly line equipment or things to make things. So his hobby was to continue to make tools to make things like clocks. Very interesting and clever clocks but his true fund was making the machines to make the clocks. Then machine is not controlled by G code like we would typically find today as the stepping motor controller he has was made a long time ago and the individual controllers used a textbased program. So the company had a editor you could write a program to cause each the stepping motors to do something. So basically once you figure out how to cut a gear he would just change the parameters for different size gears so here's an example of a gear as you can see we have the teeth and the spokes. Then we have a picture the machine which sucks because it would've been so much nicer if I could've taken a picture when it was cutting a gears so we can see things better. Then yes there is a worm gear stepping motor indexing this is a mini lathe and the indexing is at the end of the lathe head hiding. The basic operation of this machine would be brass sheet not cut to a specific diameter size not even round mounted on the machine. Then it turns and a milling cutter will cut the diameter. Then the gear would be cut with a gear cutter. The same mill cutter for the diameter although conceivably change the size I don't know but basically the same milling for cutting the outer diameter would be used to cut the spokes. I really can't remember how he did the center hole but whatever it was was very precise.
