Hi All, new joiner here and looking for a quick bit of advice.
I've recently had my Omega Seamaster (15yrs old) serviced, but when I got it back, the timing wasn't the best (about -30secs per day). I'd always fancied tweaking the timing myself and after plenty of reading up I made the adjustments to the regulating screw the other day and I've brought it to around -10s/day now. I've also got a Speedmaster which could do with regulating so I may do that next.
My question, more for the future, is how the regulating lever and regulating screw are connected. For example, can the lever still be manually adjusted with a toothpick etc. on this CAL1120 movement with the screw still in place or are they somehow connected / geared together? I may in the future buy a timegrapher and use it to keep my other watches in check so thought I'd ask this here.
Many thanks for any help.
Out of curiosity as the watch just got serviced why didn't you send it back?
Just takes me an hour or so to drive to drop it off and another hour to go pick it up again and I'd always wanted to try regulating anyway. Guess the guy servicing it was just rushing it or something.
22 minutes ago, clockboy said:
I have serviced an Omega but the screw fine adjuster should be adequate.
I think I'm right in saying though that once the screw hits the position in my photo, that's as far advanced as you can go without using the lever? If you turn the screw any further anticlockwise then it starts reversing the action?
The problem is if somebody rushed the service then you have to wonder what else they did wrong?
Then if you want to regulate the watch I would really would recommend getting a timing machine. It's really easy when you start moving the levers to take the watch out of beat and without a timing machine you're not going to notice that unless you go extreme. Even just to regulate the watch a timing machine would really be helpful.
Yeah I might do that,  but back to the original question, can the lever and screw be moved independently of each other?
After a bit of research using the adjusting screw of an Omega allows for +/- 15 secs per day which should be ample adjustment.
Yeah, its given me 15s per day at full extent,  but my question isnt about that, its about whether I can go further than this using the lever or is the lever locked to the range of +/- 15s when the screw is in place?
The fine adjust screw will move only so far. The "screw" is an eccentric, so you are correct, once it gets to a certain point it will reverse the adjustment if you keep turning it 360°. Put the screw in the center position (the slot inline with the balance pivot) then CAREFULLY move the lever a fraction of a mm clockwise to make it slower or counter-clockwise to make it run faster. Once you are with 15 seconds +/- then you can use the fine adjustment screw to get it closer.
It's going to be rather a long process without a timegrapher, and we are all assuming that the beat error is within spec's.
Hello NJD1977, and welcome to the forum. Unfortunately your question is a bit more complicated than it may seem. I can show you the underside of the balance cock. I will take some pictures when i get home and post them here, but I do believe there is a gear under there. In addition to that, the 1120 movement utilizes the "etachron" system for regulation. The "stud" that you drew the line over actually has two posts that come straight down where the hairspring will go through. That can be adjusted to limit the space on either side of the hair spring to decrease it's deviation in the different positions and also help to regulate the timing. In addition, you can adjust the beat error by moving another lever, and then on top of that you have the fine adjustment screw. In order to make an adjustment to the "etachron" you'll need a special "etachron" key (they're about $40). All of this will require a timegrapher as you'd be making very small adjustments and then checking the timing. You'll also need to look at the timing in the different positions. I hope this helps. I would still recommend taking the watch back to the repair place as they may be better equipped to handle these adjustments.
Like I said...I'll post some pics of everything I'm talking about later tonight when I get home from work.
Great, thanks mate. Is the etachron key to allow loosening and tightening of the brass element? I presume if you don't want to loosen that part, you just move the lever without an etachron key?
Yes that's exactly what it's for. It will move the two posts hanging down closer or farther apart. The idea being that you want to get as close to the hairspring as possible without completely restricting it. My concern would be that I don't know what adjustments the previous repair included. I wouldn't want to assume that that was adjusted correctly but the find adjustment was not. It's all symbiotic, if you know what I'm saying. That would be my concern.
The reason I'm more familiar with this is because I happen to be working on my own Seamaster with an 1120 movement. I've done a lot of research and  homework before beginning this project and am taking it very slow. There's just so much to know!
As I understand it from my research, the brass element is like a locking element that creates a slight nip in the hairspring to hold its length at a certain position.
Kinda. Don't go turning at the brass element if you don't know what you're doing. You can kink the hairspring if u turned it too far.
Anyways I don't know why it took this many long winded replies but, here you go. The answer is: yes.
So when a watchmaker is rebuilding a watch, how do they regulate the watch if it's limited to +/-15s per day? Do they only fit the micro adjuster after they've already set using the lever?
The idea is they would center the screw and then use the lever to get it within a few seconds of +/- 0 and then sort out the rest of those seconds with the fine adjustment screw. It's really difficult to regulate with precision of down to the second with just the lever so the fine adjustment is there to help with that.
Edited by CaptCalvin
Great, I think you've answered my question then. So you can just make the gross regulation with the lever and once its within 20s or so, you can tweak using the screw?
According to the manual, there doesnt look to be any sort of gearing between the screw element and the lever element (303/5). Maybe just friction.
Yes. Just friction. Gross adjustments using lever. Fine adjustments using screw. I would get it a lot tighter than 20 seconds before using the screw however. Using the lever to regulate with precision of +/- 5 isnt hard at all. It's when you start going for tighter than that is when the screw comes in handy.
    • You're asking a pretty broad question and you didn't specify the machine but yes it's simple especially if you have the right machine. The question has problems but I'll take it as it is. Is it really that simple yes especially if you have the right machine. So in the video below he's making a screw and yes it really is that simple but pay attention to the machine it is not simple at all probably wasn't cheap but it is small it will probably fit in your garage. Unfortunately wouldn't fit in my garage as it's far too cluttered up with things. In the video he talks about making a screw and pay attention to the machine. The machine has lots and lots and lots of cutters and lots of things to do lots of machining all-in-one machine conceivably one step after another all programmable. If you look at his channel lots of CNC's stuff and there are several other videos related to this machine. He goes to the factory where they talk about it and show all the other machines they make in Switzerland.  I did look up the specifications the machine I don't recall the price it's not going to cut wheels I think it has a maximum diameter around 11 mm basically it's really good for making small diameter watch parts. Then in one of the other videos he goes to a factory that used to make parts with waterpowered machinery been in business for 100 years and everything they now make is made with CNC machines including this one. What was interesting with the factory photo was that when they make some parts they can put them on a optical comparator comparator compares with whatever the reference is and the machine can be programmed to adjust its cutting to make sure everything is actually being made to specifications. Oh and then somewhere in all of this there was at least one picture of a balance staff can't have a CNC Swiss machine without making balance staffs.   It would be really nice if we had pictures of the machine. Then yes if you look at the page for wheel cutting you can enter parameters and it will generate a G code but he left out things? Notice he has a picture of a complete wheel but the G code isn't making a complete wheel it's only cutting the gear teeth I don't see whereas the program for crossing out the spokes? Typically when you see people cutting gears once the teeth are cut most the time the spokes are cut by hand. Occasionally someone will mill them out but typically not with the program which seems strange if you have CNC capability for instance one of my friends fill it used to design assembly line equipment or things to make things. So his hobby was to continue to make tools to make things like clocks. Very interesting and clever clocks but his true fund was making the machines to make the clocks. Then machine is not controlled by G code like we would typically find today as the stepping motor controller he has was made a long time ago and the individual controllers used a textbased program. So the company had a editor you could write a program to cause each the stepping motors to do something. So basically once you figure out how to cut a gear he would just change the parameters for different size gears so here's an example of a gear as you can see we have the teeth and the spokes. Then we have a picture the machine which sucks because it would've been so much nicer if I could've taken a picture when it was cutting a gears so we can see things better. Then yes there is a worm gear stepping motor indexing this is a mini lathe and the indexing is at the end of the lathe head hiding. The basic operation of this machine would be brass sheet not cut to a specific diameter size not even round mounted on the machine. Then it turns and a milling cutter will cut the diameter. Then the gear would be cut with a gear cutter. The same mill cutter for the diameter although conceivably change the size I don't know but basically the same milling for cutting the outer diameter would be used to cut the spokes. I really can't remember how he did the center hole but whatever it was was very precise.
