Homage build: Dirty dozen
toptime810
Just finished a vintage build with correct working seconds at the six position. Hard to find a good reissue so I made my own with a aftermarket case and a dial made by me from scratch. logo is also my logo. Looks very professional maybe I could get some opinions from you guys. I have 25 more dials with different designs from single sub seconds to 2 and 3 eye chronographs. Its hard to find the cases I want. I guess I will settle with aftermarket cases for now and modify them.
  • Like 5
Nice work ! I have always loved the "dirty dozen" type watch , I have been considering doing such a thing .I  have several several elgin sportsmans which use the elgin 723 which I believe is a jeambrun ps32, a half way decent caliber. Kudos on your creation.
Printing white on black is a bit tricky, how did you manage that,  or is this actually black print on a white substrate?
I did find a source of white laser toner at one stage, but I haven't had a chance to experiment with it.
Another possibility would be screen printing, but the issue with that would be resolution. Screen printing is a bit limited in that regard.
I also looked at using a pen plotter with white ink, but also haven't had a chance to try that out.
Either way its a pretty slick build. The case is also impressive. I have a bunch of HMT steel cases in a similar style. The problem with them is that there is no consistent source, and they don't have a display back.
 A true military  watch would  not have a display  back.
2 minutes ago, AndyHull said:
A fair point, and it could also be argued that HMT did produce military watches, however anything I produce would be a homage, so I guess I can take a few liberties.
Absolutely! You pay your money  you make your choices.
Nice job, I also have been looking to build one and have bought a hmt  36mm case and fits a Chinese sub dial movement. I have done some printing and found better results with a white background with black print for numbers and markings and when finished invert the colours so black becomes white and white becomes black, copy layers twice , flatten and sharpen to the max without going too far as to distort image, then print in black and white in high definition text.  It took a while to get the thickness of the rail tracks but it is achievable
11 hours ago, toptime810 said:
My dials are not paper
Generally dials are metal, with some form of printing or transfer on them. There are many different methods of producing dials, but I can't say I have ever seen a paper one, so I wouldn't have assumed they were.
How did you produce those results? Are you using laser toner transfer, water slide decals? Curious minds want to know.
Edited by AndyHull
  • Similar Content
    • Thanks Rich, its really not that difficult to make them, simple ones anyway. Cousins didn't have the part though i could find it on ebay at 6.50. I figure i earned about £1.50/ hr . It paid for the diamond files i bought.
    • If you look at this thread, you can see I had exactly the same problems with balance springs with 2 prongs on a Smiths 627. The slots in the chaton were not big enough to get the ends of the spring out. I had to bend them to get them out and back in. Not ideal. I don't fancy having to do it again as they could easily break, and where would you find replacements? I didn't come across the 3 prong type.
    • I visited the Breguet Exhibition today. https://www.sciencemuseum.org.uk/about-us/press-office/rare-timepieces-unveiled-new-display-science-museum The Science Museum now holds the collection of "The Worshipful Company of Clockmakers" - "The collection includes more than 600 watches, 90 clocks, 30 marine chronometers and a number of fine sundials and examples of hand engraving, mapping the history of innovation in watch and clock making in London from 1600 to the present day." It's well worth a visit. They have some amazing pieces by the likes of Harrison, Breguet, Tompion etc . I've visited twice before but decided to go and see the Breguet Exhibition. Maybe I was expecting too much, as on reflection, "More than 20 extraordinary timepieces designed by inventor and watchmaker Abraham-Louis Breguet " isn't going to take up that much space. In reality, it's just one cabinet. But, Oh those watches, stunning 🤩 , e.g. (No 1297 was made for George III and is valued about £1m)   I tried a couple of pics, but with subdued lighting and taking through glass, they aren't good. I like thin hands on a watch - how about these (I think this is a split second chrono)   And this one, with all it's complications, is only 10mm thick !   What I found very interesting were a few very old machines for making watch parts, like this 17th Century gear cutter. The disc below has concentric rings with holes in, so that is can be set to cut varying teeth numbers.
    • Firstly sorry for poor image quality I only have an iPhone for photos.    Im working on a 512 movement and I’ve had some trouble with the “jewels”. I’ve got the metal one out, but when I tried to put it back the three sides of the spring seem to need pressing all at once to fit it as there are three “holes”. I get two corners in but as I go for the third the first two pop out! Constantly I’ve lost the spring. I’ve done the similar ones on seiko movements without trouble. Assuming I find it/a replacement, what am I missing!   on the other side with the only ruby in the movement is a setting with no “gap”at all. How do I get the spring out, and of course get it back in!    What am I missing!    thanks in advance.    Rob
    • Links like that are the reason I routinely donate to the Internet Archive - they are the last safe house for a tremendous amount of useful info that is otherwise lost.
