I have been interested in mechanical watches for several years and have always wanted to know things work, probably to a fault. I have only recently become interested in repairing watches and clocks after first fixing a pendulum clock (learning to be very careful with mainsprings) and then trying to repair an old pocket watch (learning to always be careful with hairsprings and escape wheels).
With only limited equipment and time, I try to find the simplest ways of solving problems with the fewest possible tools.
