Hello from Philippines!
Jheric
Glad to be here. I'm new in watch repairing, about 1/2 year of flying springs across the room and scratching bridges and also a lot of hairspring distortion. :)
~ a lot of hours finding tiny objects on the floor.
I'm match in control now.
Getting used of my tools.
 Thank you WRT
Regards, Jheric
Thank you guys!
20 hours ago, watchweasol said:
Hi Jheric welcome to the forum, Checkout a site [email protected]  A watch school run by Israel Angeles in Manilla  a very knowledgeable man in the horological world has some useful tools for quartz watch repairs.
Thank you for the information, Will add that on my manila tour.
@watchweasol May I ask, do you know where to buy staking tool, dumont tweezers, cleaning solution and etc. in manila ?
Hi Jheric,  Most  use EBAY to source tools and parts,  but Iam sure if you have a look on the web there will be suppliers in The Phillipines. Threr are a few in America, Jules Borel, Esslinger both used by our American cousins ou Cousins.uk , AG Thomas,HSWalsh,Meadows and Passmore (clock  parts)  Gleave & Co in England. Hope you find this info useful.
  • 4 years later...
    • What this extra disk next to the pinion? Thats not part of the assembly
    • It looks like the canon pinion function is part of this great wheel. The pinion nearest the clip runs the minute wheel on the dual side. The pinion nearest the wheel is driven by a small wheel from under the setting lever cover plate that engages in hand setting position.    So when assembled the crown was driving the whole great train. Does this mean the pinions are too tight? Should I attempt to disassemble this great wheel and lubricants?
    • Picking up this side-tracked post again as I just removed a balance staff of a 1920's Omega (35,5L-T1) I was impressed by the way @Delgetti had his setup when he had to change out a balance-staff (https://www.watchrepairtalk.com/topic/28854-new-balance-staff-not-riveting-to-balance/page/2/#comment-244054 Not only that, but also the idea of removing the seat first before punching the staff out from the seat-side, avoiding the whole discussion of the rivet yes/no enlarging the hole. I didn't have the fancy clamps & tools Delgetti has, so I used my screw-head polishing tool. Initially I used #1500 grit diamond paste on the steel wheel, which kinda worked, but very slow. I changed to #800 grit diamond paste, which worked better, but still slow. Then I glued #240 sanding paper to the steel disk; That worked and the disk was hand-driven. Once close to the balance wheel, I took the sanding paper off and continued with #800 diamond paste. One can only do this when the balance wheel sits true on the staff and has no "wobble". I went on grinding until I saw some diamond paste on the rim of the balance wheel. This was as far as I could grind and it seemed that there wasn't much left of the seat. Carefully, with my staking set, I knocked the staff from the seat-side out. Turns out that the thickness of the seat left, now a small ring, was only 0.1mm. The balance wheel hole is in perfect shape and no damage done to the wheel at all. Of course, if the wheel has a "wobble" or isn't seated true on the balance staff, you can't get as close and there will be more left of the seat. In my case, it worked perfect 🙂 I'm very happy how this method worked out ! 😊
    • As is tradition, one step forward, two steps back. Got the board populated and soldered into place without any issues.   But no hum. So I started testing the coils with an ohmmeter. I got 5.84k ohms across D1 (from red to red in the picture below), which is as expected. But I'm getting an open circuit for the other drive coil and feedback coil, D2 and F1 (from green to each of the two yellows).   Since the movement was working with my breadboard setup, it implies I somehow broke the connection between the coils and the solder lugs. They're all the way at the bottom of the lugs, but maybe the heat migrated down and broke the connections? I guess it's possible it happened while cleaning the flux off, but I used a soft artist's brush and isopropyl alcohol. I did a lot of high magnification examination, and I don't see any issues, but let me know if you see anything I missed or if you can think of anything else I should check.
