Hello everybody,
I am working on an orient 46941 movement but when I opened it I found that the click is broken looks like the "professional" that my father took his watch to broke it some how because it was running and now the watch is swimming in oil as well, I tried a click from a Seiko but it's too long it didn't work and I looke online but found nothing about clicks what so ever.
is there any thing that I can do because I really love this watch and my father is looking forward to using it again.
thank you, eBay doesn't work in Turkey but I messaged the seller and hopefully we can figure something out, I looked on eBay but I couldn't find the click thank you again
1 minute ago, oldhippy said:
orient 46941 looks like a seiko movement. aac58 has found the part for you. Again it looks like a seiko part.
I tried a Seiko click it was a bit too long, I
You might be able to source spares from one of the many Orient approved service centers, and there is one in Turkey.
https://orient-watch.com/service-network
Also, while the movements look similar to many Seikos, and Orient is (or perhaps was, since I think they are not currently in production) a Seiko brand, from my limited experience of them, they are subtly different, so parts from one most probably will not work on  the other.
Your best bet might therefore be to try to source a donor movement somehow. Sadly I have nothing suitable in my spares.
One final point, whoever the "professional" was who looked at that watch, should stick to arable farming, that thing looks dirty enough to grow potatoes in. :wacko:
The first thing a real professional would do is strip and clean the movement before they even attempted to fix it. Then again, a true professional would "own" any problem they caused, for example if the broke something in the watch.
In my professional electronics repair career many years ago, we would always ensure that customer's equipment was returned in the same or better condition than when we received it, even it repairs were uneconomical. All dirt, and grubby paw prints removed, and the item packaged securely is the minimum you should strive for.
Orient is quietly owned by Seiko, and they are lively on the market having many aficionados. Check US website, much more enjoyable than the JDM one.
https://www.orientwatchusa.com/
Depending on how much longer the seiko click is, a few strategic bends will reduce the effective length.
Visualise a 'v' bend with the point of the 'v' point to the edge of the movement. Avoid sharp bends and you only have one or two shots at bending before it breaks. Also check for clearance with the barrel/train bridge.
Its a bodge but if you cant get a correct one and have a few Seiko clicks to spare why not?
Good luck
Anilv
Well I was able to get a click from a guy here in Turkey but unfortunately the movement is so far gone the mainspring is broken and the automatic isn't working so I put it aside until I find another movement.
this movement is really close to Seiko movements as mentioned by @jdm but it's smaller so I can't use any parts from a Seiko, I don't know if Orient include some Seiko parts in their movements but as far as I know Orient make their movements in house.
On 9/23/2019 at 1:22 PM, aac58 said:
Did you get an answer from the seller?
yup it's not worth it I can't pay with pay pal it deesn't work here and the bank transfer is too expensive, I found the part at a shop here thank you though ^_^
I actually contacted Orient service in Turkey a while ago and the told me that they don't have parts for old movements.
people open a couple of watches and call their selves professionals and start ruining other people's watches, my mother has a vintage quartz Orient (yes we love Orient) that stopped working she sent it to the same "professional" but this time he just ganged the battery  without even looking at the watch obviously it didn't run so I had a look at it (although I don't know much about quartz watches) and there was a break in the circuit.
Good luck
Anilv
I wouldn't try this because I am not confident in my ability I'm pretty sure that I would just break the click, I would love to see a video on it so I can learn though, thank you
I'm glad you got it!
    • isn't it nice to have a decent case open or when the case doesn't want to be opened? In the case of a Rolex watch that supposed to pass specific water resistant testing you probably do need to tighten the back down. But they shouldn't be tightened so much that they risk stripping the threads out. Then the other problem that comes up is the gaskets can start to disintegrate and then getting the back off can be quite a challenge unless you have a really good tool and perhaps some penetrating oil to loosen things up. Yes really nice case marking. When I was in school we were taught to mark the cases and  the American watch and clockmakers Institute even had a? So if you joined at one time they would give you an identification number. They were explaining or giving an example of if the watches ever found in you have a unique number they can perhaps figure out the history of the watch or identify the body it's attached to for instance not that that probably comes up that often. So you got a unique number and even made a special metal stamp that you can purchase. It wasn't a super big aggressive stamp but still it left a mark in the back of the case. Then I heard from people at work on Rolex watches they were using a felt pen indelible but later on they decided that was bad because apparently the ink could release  chemicals although it seems like once it's dry that shouldn't be an issue. Then of course today was nice is you can keep computer records sealed have to mark anything at all I personally find it's best to leave no reference behind that you were even there. Especially when you have a beautiful watch that has no markings at all and now it has your scribbling all over it not good typically if there is a typical and watch repair?  a lot of minor repairs you don't need to do a complete servicing. But beyond a certain point you're going to have to take apart a lot of stuff you're going to disrupt the lubrication even if it looks perfect right now and yes you might as well just go ahead the service the whole thing. also in a watch like this where a lot of things seem to be going on the complete service would be better then you'll know exactly where you stand versus dealing with unknown mysteries for prior repair.
