Main spring slipps
The stem was already broken when I got the watch, so there was a piece already left in the movement, so I don’t what the setting was at when it broke! There’s still a broken piece left in the crown which i can’t get out! I just removed the broken piece left by the detent button as normal!
How did you remove the stem and what was the reason for removing it.
The hole in the glass has to be central as it's for the Barometer pointer.
Hi guys! I’m trying to put stem back into the movement but it doesn’t want to go back in! Any ideas please!
