Capped 3rd wheel pivot jewels
For movements with capped 3rd and escape wheel pivot jewels like Seikos Orients Rolex etc, which oil should the one for 3rd wheel be lubricated with? Only documentation I can find/have access to for such scenario comes from Seiko and they specify oiling the capped pivot with thin oil, but the uncapped dial side pivot with thick oil. Then again they also specify oiling the pallet pivots so I'm a bit unsure how religiously I want to follow their instructions. What is the commonly accepted practice here? Thin oil or thick oil?
In my mind the type of lubrication you use is depending of which kind of force the part is exposed for and its construction.
Thats why I guess you mostly can see thick lubrications in the drive train area where the force is relativly high and the pivots are thicker, while in the escapement the lubrication gets thinner because the force are relativly low and the pivots are mostly thinner.
You could ofcourse use a thin lubrication everywere but it would just be harder to apply and you probably have to service the movement more often since a thinner lubrication is more volatile.
I don't think the use of end caps in the drivetrain makes any difference in the choise of lubrication.
I don't know, but hopefully, someone here knows what the commonly accepted practice is. I can see that the suggestion to oil the pallet pivots bring doubt to your confidence in the documentation. The only context in which I've heard this being suggested is to combat re-banking by introducing a bit of drag.
Anyway, I'd suggest thin oil, but purely on a gut feeling!
3 hours ago, rduckwor said:
I use thicker oil on the center wheel pivots and thin oil elsewhere - capped or not.  Pallet pivots get no oil per general consensus.
Good Luck,
RMD
I thought thick oil is also used on 3rd wheel pivots in most cases?
I'm not sure how up to date that guide is. Pretty much every service manual I come across lubes 4th and escape with thin oil but 3rd with thick oil. Even Seiko agrees, showing thick oil being applied to the uncapped side of the 3rd wheel.
Just noticed that Mark Lovick uses thin oil (Moebius 9010) for the 3rd wheel in his ETA 2824-2 service video (@8:58). This goes against the recommendation of the ETA technical sheet for the 2824-2, but I believe he does so for a reason. If you read this Mark your comment would be appreciated!
While on the topic; what would the effect of using a thick oil be when applied to a pivot where we'd usually apply a thin oil, such as the escape wheel?
I would imagine decreased amplitude if applied to fourth or escape wheel, but i noticed hardly any difference with the 3rd wheel in most cases so i think thick oil would be the proper lubrication here in most cases. My question is  why would Seiko make the distinction between capped and uncapped jewels? Why on the same wheel apply thick oil on the uncapped end and thin oil on the capped end? Is there some rule against applying thick oil to capped jewels that I haven't heard about?
As you said I would't worry too much about what Seiko indicates when it contrasts with professional's best practices. Beside the aforementioned pallet pivots they show to oil one spring finger that contacts plastic, but not another that does the same? Better to spend time in other ways.
The thing is I don't know what the best practices are in this scenario. Do I apply thick oil to both ends? Do I apply thin oil? Or do what Seiko says and apply thick oil on uncapped end and thin oil on capped end?
Plenty of good and detailed advice above, including some from watchmaking school.
I'm going to roll with applying thin oil to both ends of the 3rd wheel then. But most technical manuals (that I've come across) show use of thick oil on 3rd wheel. Thoughts?
Edited by CaptCalvin
I second your decision. There's probably no absolute truth here. My first and so far only ETA 2824-2 that I've serviced ended up with too low amplitude. The reason for this is still under investigation. However, I'm now servicing my second ETA 2824-2 and this time around, unlike the first time, I'm going to use thin oil for the 3rd wheel following the example in the ETA 2824-2 service video that I linked to.
You're welcome to try though I doubt that's the problem however. I've always used hp1300 on 2824 3rd wheels and never had a problem.
I did just find an Orient service manual for similar but different caliber than the one I'm currently working on and it specifies thin oil for both capped and uncapped 3rd wheel pivots, although I do find these to have markedly lower torque than their Swiss higher beat counterparts so it might indeed be the best choice here.
I don't doubt that it didn't made a problem but the attached service sheet indicates 9010 for the third wheel.
As a general rule HP (High Pressure, is not even really an oil) is used to parts that are driven from turning the crown, or directly by the barrel. All the rest get fine oil.
_C_T_CT_2824-2_FDE_481688_24.pdf
Geez you had me questioning myself there for a moment... but look again:
Good, thanks. I got confused by the use of same color drops with or without circles. Other sheets use circles to indicate quantity, not type.
I wasn't expecting thin oil for the 3rd on the ETA 2824-2 to make any difference for the amplitude but I found it interesting that thin oil was used in the service video by a seasoned watch repairer, and that's what made me decide to go for thin oil. As I stated in a previous post and as can be seen in your pictures, ETA recommends HP-1300 for the 3rd wheel. The problem with the amplitude was related to the hairspring, hairspring stud and the regulator pins (Thanks @HSL!) , but that is a different topic.
I'm curious; how can you tell and compare wheel torques?
Edited by VWatchie
Nothing scientific: severity of blistering in fingers when trying to wind the mainspring through ratchet wheel screw.  Can even feel it by winding through the crown. You would expect higher beat movements to have higher torque anyway.
    • The plate is OK, thanks. It seems the answer to my question is that this is a 'hack' & for me another reminder that in general, one won't be the first person to be tinkering with an old timepiece!. As you day, I've been fortunate to have gotten some good advice and, just as important, encouragement. I've been lucky then not to have the balance spring break as a result of my novice 'ministrations' - but I did remember to 'stroke' rather than bend per se. The clock is of sentimental value to the owner so I'm relieved to have now got it running to time with the support & encourage of forum members like yourself.
    • Thanks ww, its maybe not as much of a bodge trick that i thought it was.
    • Thank you for your introduction and welcome to this friendly forum. We all look forward to your contributions and continued involvement.  It would be nice if you told us a little about yourself.
    • Thank you for your introduction and welcome to this friendly forum. We all look forward to your contributions and continued involvement.  Can we help with what you are trying to  figure out?
    • In think you are effectively shortening the coil by shorting out damaged tracks. In my case as long as the continuity was good and the resistance not too greatly affected it should be ok .  One was on an era  movement,
