I just finished two ETA 2824-2 watches (Stowa & Sinn)...no problems.
I'm working on a third (Stowa) that was manhandled. There was a broken blued screw top and a complete screw loose in the watch. I'm not done going through the watch yet but the watch had an additional problem with keyless works. At position 1 (fully in) the winding wasn't catching well. At position 2 the winding was engaged (was supposed to be calendar set). I've removed and reinstalled all components and I cannot see a problem. The keyless works is isolated except with a connection to the barrel. I don't think I tested the previous two in this manner but I can't see how the isolation should make a difference. Before I fully clean and install all the components I was wondering what I am missing that is surely obvious.
I have pics in the three stages of the stem settings attached.
Thanks for your help.
OK. I was watching TV and I started thinking about the problem when it suddenly hit me. I was playing back what I could recall and I remembered dropping the clutch one time. If you look at the pictures you can see that the clutch was placed upside down. Somehow I thought I picked it up correctly and popped it back in without thinking.
Fatigue...
Good work on mentally backtracking and figuring out what you did wrong. Most of the mistakes and slips I've made have been late at night or when I'm rushing to finish a project. Its best to step back and cover everything up for another time if fatigued.
J
  • 2 years later...
I thought surely this must be a worn out sliding or winding pinion. That happens on these movements as these parts are made of brass and really can’t take too much abuse. Anyway, looking at the first picture it was obvious the clutch wheel (or sliding pinion) was mounted in the wrong direction.
Yes, old post but interesting!
The winding and and sliding pinions are definitely steel on these (and every other watch I've seen). But the overall system of levers in the 2824 is delicate- if one thing gets just a little bit tweeked, it can be totally invisible what's wrong but it just won't go into setting position correctly. Replace parts with visually identical new ones and it works great. If I get another one with this issue I'll put the parts on the profile projector and see exactly what's up.
  • Thanks 2
Funny this thread should get refreshed today...I was working on a 2824 yesterday.  I think this is the second one I have serviced.
What I noticed last time and this time is that replacing the stem once the watch has been re cased, is problematic.  Twice, while replacing the stem, the clutch jumped out from under the yoke.  I had to remove the hands and dial, calendar, and reset it. GRRRRR!!  Then, observing how this movement works, I can see that the setting lever jumper spring pushes the yoke toward the "setting position" so more often than not, if you set the stem in "winding" position, upon removal, it tends to want to move to "setting" position and then you are screwed.  So the LAST attempt, I put the stem in "setting" position before removal and all was well.  This is DAMN tricky!!
Seems like I read somewhere...the guidance in general is to put the watch in "setting" position before removing the stem.
Thoughts?  I am all ears.
BTW, other than this issue, I like this movement.  I see that it has been copied several times.
Thanks for the correction! I read something about these ETA 2824 parts (winding and sliding pinion) being weak and that’s also my personal experience. So, I wrongly assumed they were made of brass. Anyway, I’m writing this sitting on a train so I’ll have get back about what I read and my experience.
You confirmed the conclusion I was hesitant to make,  If the crown hits the ground when watch is dropped, keyless gets messed up,  usually damges the  return bar whose end section doesn't wana get in the  grove peacefully.
So, I found the article misleading me to believe the winding pinion and sliding pinion were made of brass:
"Additionally, brass components within the manual winding system, which were common failure points in the ETA, have been replaced with hardened steel." ~Damasko Quietly Reveals New In-House Caliber A26 (search the article for "brass")
Now that I've reviewed my ETA 2824-2 and ETA 2836-2 service pictures it sure looks like these parts are made of steel. Although likely not hardened steel as in the A26 calibre.
I bought a cheap used Hamilton Khaki watch on eBay housing an ETA 2824-2 which couldn't be wound manually properly, and it was quite a mystery to me until I realized the "cogs" on the sliding pinion and the winding pinion hooking into one another were worn out causing it (and other nasty things). The previous owner likely didn't trust the automatic winding. Full story from about here.
So, not brass, but not the best type of steel either, it would seem!?
3 hours ago, LittleWatchShop said:
sliding pinion
I believe Americans call it a clutch and Europeans a sliding pinion. And perhaps that's your point?!
Well, when it comes to keyless works, I often have to refer to a diagram to get the terms correct.  In my head (from what my dad taught me) I call it a clutch, but I see others call it a sliding pinion.  Just trying to be as accurate with my terminology as possible!
I can only imagine that they've put hardened steel washers on wear points where the flat pinions ride.
I'm no megafan of ETA, but one thing they know is metallurgy. I've worked on enough of their old stuff, and the ETA (Valjoux) 7750 is a benchmark piece for other various brands for "aging", and I've spoken to the test guys, ETA has their alloys and heat treatment honed. I have also "outside" bored the post that takes the flat pinion after the sliding (clutch) pinion and sleeved it with steel for numerous watches- but not ETA so far.
As they say: "dear child has many names". As you and your dad are Texans it strengthens my theory. That is, "clutch" in the US and "sliding pinion" in Europe/England.
I've been meaning to compile a list of the various names used for the same parts, but never got around to it. For example, I believe the term "dial train" is used in the US and "motion works" in Europe. I do prefer "dial train". Also, "return bar" in the US(?) and "yoke" in Europe, etc.
Could it be that ETA saved on the modern (current) automatic movements with the rationale that no one will wind them manually much anyway? I wouldn't be surprised if the steel used in the mechanical ETA 2804 (for example) is of a much better quality (hardened steel) than in the ETA 2824. As ETA are making millions of movements, that could possibly save them quite a bit of money, especially as I would expect the modern automatic movements to be about a hundred or even a thousand times more popular than the mechanical versions.
Anyway, JM2C!
Edited by VWatchie
I got stung the other day in the clock group on this forum.  Did not know what an "anchor" was.  I always called it a "verge" but now I am thinking that "verge" is the term specifically for that asymetric shape whereas "anchor" is quite symmetrical.
In my professional life, I am a patent consultant, serving as an expert witness.  In the world of patents, understanding and interpreting lexicography is the sine qua non of success.  Metaphorically, "anchor" wins the case and "verge" loses it (broadly speaking).
    • This was what I was afraid of. The movement is not one of the generic black square modules. Remove the movement from the clock and try prying it open very carefully, without breaking the plastic tabs. The plastic might be brittle from age. Clean the wheels and check the battery contacts for corrosion. Check the PCB for bad solder joints. Take plenty of photos along the way.
    • One of the problems with trying to Photograph Phils things are that his enjoyment was building these things so they tended to E falls on what will see if I can find some earlier pictures or any pictures I wasn't even sure because I was looking for that specific picture for somebody else and even it got the last version and that would have been the last version. You will note that he put the indexing on something that he could unscrew it or whatever and it can slide back out of the way so the rest of the lathe can be used as a lathe. With the lathe cut are actually coming down from the top I was there once where he demonstrated how to cut a pivot with the setup it was really beautiful. Older set up if I remember it's not a worm gear assembly in the thing in between the stepping motor and the holding block I believe this particular one was like a 100 to 1 gear ratio. Earlier version with watchmaker's lathe. Even looks like he is the watchmakers bed and then switch to something he made. Then I do have other pictures and things of the rotary stage in use. In the raw so if you tube videos here is an example of one were somebody's mounting a three jaw chuck. At one time there were available on eBay they were not cheap but if you're patient like I was I found one cheap on eBay. After you watch the video it look at his other videos he is a whole bunch of other examples of the same rotary stage. That I do know there are other pictures examples and possibly videos you just have to track them down. One of the minor issues of finding this particular tech sheet for the unit is I believe it was a custom manufacturer and the company change their name but I remember the new name here's a link to the company https://www.ondrivesus.com/rino-mechanical-components
    • Escapement adjusting always interesting and depending upon the reference always confusing. Okay maybe it's not always confusing but it does lead to confusion. I have a PDF below it's actually a whole bunch of separate stuff including a hand out that came from a lecture that's on you tube. Then from that we get this image Consequences of doing things especially if you do things out of order or you do things for the wrong reason. Oh and even if the watches working I made the mistake one so showing my boss how tweaking the banking pins on a full plate on the timing machine made the amplitude get better and now he thinks that's what they're for and I don't think a fully grasped exactly what horn clearance means. Consequence of doing things. Notice what it says about opening and closing the banking pins and total lock? So yes I've had that on a full plate where it won't unlock at all and that's the banking pins or a combination of things basically. So banking pins unfortunately get moved. One of the ways to tell if it's been moved is the look straight down at the end of the fork with the balance wheel removed. Power on the fork push at the one side look at it push it to the other side also look at it and compare anything with the center reference the balance jewel and see if both sides of the same. No guarantee after the same there in the right place but at least are the same typically when people play with things one side will be way off from the other because they had no idea what they were doing at all because of course it's a full plate and you really have to paying attention and even then there's still hard to do. Then the other thing that comes up like it shows below is people often adjust the banking pins to do all those other things as opposed to horn clearance which is all that it's therefore and maybe bonus Guard pin clearance although you're supposed to deal with the guard pin is a separate thing like single roller gets bent in Or out or sometimes physically gets moved in and out. Some full plates older escapement's typically pallet forks held together with screws and you can actually unscrew and move the entire assembly in Or out more complications to deal with.     Escapement handout wostep nscc.pdf
    • If he was much younger and some sort of sports player it wouldn't be a problem. They would be in there and doing surgery and he'd be back on the field in no time. Unfortunately when you get older little things are bad and big things can be really bad so not good at all.
    • Where I work everything incoming watches whatever detailed descriptions are taken entered into a computer program and photograph of each item. Then ideally although it depends on who's doing the paperwork detailed descriptions can be quite good other times there lacking. Like I really like it with pocket watches if they would record the serial number it avoids confusion later on. Then when watch repairs are completed that is also entered in. It's one of the amusements I learned when I was in school instructor had a shop and commented about the important aspect of keeping detailed records of repairs. Because oftentimes a customer who got a new crystal will come back later on when the watch doesn't work and expect you to fix the entire watch for free. Then you can remind them that they just got a crystal. Strangely enough that keeps coming up or occasionally comes up where I work now. One of the problems of using the service marks on the case is that in the case of pocket watches oftentimes that's not the original case. Then case marks? What I was doing warranty work for a company I used to describe a code number in the back of the case and it would tell me the next time I see the watch that basically what I did I made no attempt at keeping track of customers because we had literally thousands of them I think they sold 30,000 of these watches and they would come back by the hundreds because they had a lifetime warranty. Yes that's a story all of itself but I would put a code number that would reference what was done to the watch the last time and think I had a date in there somehow so it did tell a story if you knew the code. Another shop I once worked out the number would reference the page in the book. So other than knowing we had been in there you would have no idea what happened because you have to go look at the page in the book to see what happened. Then the problem of how you examine a watch you should examine the watch in detail every single time to avoid complications. Although on vintage watches and this is a of amusement I have at work when people ask something and I say of the watches done when it leaves. This is because on vintage oftentimes problems won't show up until the watches much farther into the repair like it's now running and you discover things that you can't discover before because it wasn't running to discover them that also become sometimes difficult to have exact rigid prices are estimates of repairs or in the case of a pocket watch you may not find out if a casing problem to later on when you case it up in the watches running. I was just thinking for all those people that would like to leave a mark maybe you should learn to do what some of the past watchmakers did? Leave a mark but leave it in such a way that no one will ever find it? Typically not done for repair purposes but done for other reasons like identifying it's legit. I have a friend with a Gruen watch and one of the Roman numbers the bottom line that just looks like a line under extreme magnification actually says Gruen watch company or something equivalent. So here's a link showing how to mark your watch without being seen although that's not the actual title. So if you can learn micro engraving you can engrave the watch someplace probably just about any place you just have to remember where you put it. https://cnaluxury.channelnewsasia.com/obsessions/how-to-prove-if-watches-are-authentic-secret-signatures-182516
