Machine cleaning with or without cap jewels?
By watchweasol · Posted
Hi and welcome to the forum.. I take it you have held the opposite end tight and the business end is just turning , yes. If so sounds much like stripped threads, the screws might need cutting out and a new bar and screw fitting . But as clockboy said pictures please it makes life just that bit easier. -
Hello and welcome to the forum. Attached a little reading TZIllustratedGlossary.pdf -
Cousins don't stock it any more, but this is from their site Then put the size and features in to their search function https://www.cousinsuk.com/category/filter/watch-movement-search-match-by-ligne-size you may be able to find a matching movement
