Lubricants to use with Rolex 3135
Would the below list of lubricants be suitable for the Rolex cal.3135 (clone) movement?
For the grease (cannon pinion, keyless) would you prefer to use 9501 or 9504 the moebius chart recommends either.
This is from my post a few years ago (2015). If I remember correctly I used all of my suggested lubricants and the watch worked great. However after approx. six months the auto part stopped working efficiently. I re cleaned treated the wheels with epilame (fixodrop) and lubed with HP 500. Since then it has not been off my wrist part from bath time.
The epilame is really key, you have to do it. It's a weird quirk of an otherwise bulletproof movement. I think you could use pretty much any synthetic lube and it'd survive as long as you epilame the reversers.
Thanks nick I will look into it. It’s not something I’ve done before
On 3/15/2019 at 12:44 AM, matabog said:
Lubetta V105 on the reversers instead of Epilame?
Reversers are interesting for lubrication. Some of them you can use the Lubetta V105 Which is basically an oil like 9010 dissolved in a solvent. But Rolex in their tech sheet shows that lubrication only wants to be in a very specific location and nowhere else. So that's why the recommending the surface treatment to keep the oil from spreading.
On 3/17/2019 at 3:04 PM, matabog said:
I might have been wrong. I had the ETA reversers in my had. I think the rolex ones can be 'dismantled'. So after Epilame, where would you oil those reversers? And with what?
Lubetta V105 was developed I believe by ETA. The Rolex reverse wheels are of a different design. Lubetta I think is  lubricant. Most odd the Rolex reverse wheels have not lubrication.
  • 9 months later...
@JohnR725 So are the reverser wheels oiled on there edges or not ? The diagram shows 'do not oil', in which case what's the point of the epilame?
I notice that Mark applies a drop of something to the edge of the wheel ( 7min  50s) :
https://www.youtube.com/watch?v=J8WNrtahT4Q
My understanding is that the clicks or whatever they're called in the reversers have to be absolutely free to move and lubrication would Interfere with that. So epilame treatment is applied to keep lubrication away.  Notice they're using HP 1000 on the center part and there would be a likelihood without surface treatment of that spreading out.
Then you're absolutely correct in the video Mark applies a drop of lubrication on the reverser wheels which by theory would spread to the little clicks and interfere with how they work. But this is lubrication in horology everyone has a different idea if it works for Mark and long term it works for Mark then?
The reverser wheels MUST be treated with " Epilame" if not after a while the auto stops functioning correctly. I speak from experience. PS I used HP500 for the reverser parts with no issues the watch has not been off my wrist (apart from bath time) for 4 years now.
@clockboy do you know how long Epilame lasts? And what will dissolve it. Naptha, isopropanol?
I'm about to service a friends 2230 movement which has never been serviced :thumbsd:
And I'm not planning on buying any Epilame just for that!
(I wonder if there are any cheaper alternatives to Epilame. Mobile phone screens use an oleophobic coating which can be renewed with a wipe on liquid)
Edited by mikepilk
11 hours ago, nickelsilver said:
12 hours ago, mikepilk said:
I wondered if i clean in naptha then isopropanol it will remove the epilame
It might. It's really critical that they are epilamed, so try to get some. You can't really over epilame, but on these Rolexes you can definitely under epilame.
You have convinced me. I managed to buy just 5ml
    • I did that also for a few movements - well, mainly in/around the train jewels. I made big efforts to epilame the mainplate WITHOUT getting Epilame into the Pallet fork jewels (where it's not supposed to be, right?). I made litte barriers with Rodico around that jewel and used drops from a syringe to apply on the rest.  However, I've now stopped doing this. For three reasons: 1. It's a hassle and consumes more of this liquid gold. 2. I didn't see the need when using HP1000/HP1300 lubricants and grease for most part. The two places where I'd use 9010 (i.e. escape wheel and balance) receive Epilame in specific places... or the cap-jewel-setting of the balance suspends the oil sufficiently be capillary action (see my "conflict" about using Epilame on the balance jewels).  3. Lastly, and here I really wonder about yours and others' experiences: I felt that applying Epliame to the train jewels left them looking hazy (borderline dirty) compared to the (painstakingly achieved) sparkly clean results of my cleaning process. I just can't help but think that the Epilame residuals would mix with the oil and cause more friction/wear. I don't know.    simple: it'll stay there. It won't move any further. That's exactly what is happening if you epilame a cap stone. You end up placing the 9010 right on top of the epilame and the oil will sit nicely on that spot.
    • There are some parts on Ebay for the seiko 6020A, it may just be a waiting game for someone to strip one down, NOS will be more scarce . K would strip your movement down to the module then start looking at other seiko movement to see if that coil is used, then seek out a seiko part dealer. Also Retrowatches youtube owner Mike may give you some advice try him on his site . He also hangs around amateur watchmaking groups.
    • I would agree, in order to work harden something you need to exceed it's yield strength when it moves from the elastic zone to the plastic zone and you get permanent deformation and work hardening which is fairly close to its failure point, relatively speaking and dependent on the material/alloy of course. In theory you can load something constantly within its elastic range and not suffer work hardening issues.
    • Probably easier to get a complete new movement - but CousinsUK list it as discontinued. Maybe someone on here knows a substitute movement ?
    • Any other thoughts on how I can get a replacement coil? Any “hidden” or unknown physical shops (in Australia or elsewhere) that might have them in stock (but not always online)?
