Timex Camper Restoration
JerseyMo
2 hours ago, yankeedog said:
Looking at your photos, I see no glaring obvious defect.It seems to me that your greatest chance for errant friction would be where the center wheel shaft goes through the main plate.
yep, will have to go a process of illumination approach.  One part at a time to see where she stops.  Would be interesting if indeed it is the center pinon because I think that is the one part that makes this movement unique from its closest relative.  ( the 106)
  • 1 year later...
I was wondering If you could help me trouble shoot a problem I'm having. So bought a 91 Timex camper. I am fixing it up at the moment.
However it doesn't want to stay wound. I found that if I wound the watch and held the crown (so it wouldn't back spin/unwind) the watch ran and all was well. Is it possible that the, " click spring on the barrel winder" as AndyHull referred to it, is worn out and no longer able to resist the wound tension?
Thank you for any insight you maybe able to give on the subject.
that does very much sound like the click spring is worn down.  When new the tip of the click is a v shaped fork. Over time the bottom section wears down so no winding gears just slips. short of a replacement there is no other correction that will hold up.
  • 3 years later...
On 3/12/2019 at 3:04 PM, AndyHull said:
Is the click spring on the barrel winder (highlighted below) available as a spare part?
If so, where would I source them?
I need this exact part, too.  I feel like there ought to be a way to fabricate a replacement with a stiff piece of wire.  Anyone tried it?  --Chris
it is very thin spring steel maybe try a piece of mainspring or a dentent spring.
    • It looks like the canon pinion function is part of this great wheel. The pinion nearest the clip runs the minute wheel on the dual side. The pinion nearest the wheel is driven by a small wheel from under the setting lever cover plate that engages in hand setting position.    So when assembled the crown was driving the whole great train. Does this mean the pinions are too tight? Should I attempt to disassemble this great wheel and lubricants?
    • Picking up this side-tracked post again as I just removed a balance staff of a 1920's Omega (35,5L-T1) I was impressed by the way @Delgetti had his setup when he had to change out a balance-staff (https://www.watchrepairtalk.com/topic/28854-new-balance-staff-not-riveting-to-balance/page/2/#comment-244054 Not only that, but also the idea of removing the seat first before punching the staff out from the seat-side, avoiding the whole discussion of the rivet yes/no enlarging the hole. I didn't have the fancy clamps & tools Delgetti has, so I used my screw-head polishing tool. Initially I used #1500 grit diamond paste on the steel wheel, which kinda worked, but very slow. I changed to #800 grit diamond paste, which worked better, but still slow. Then I glued #240 sanding paper to the steel disk; That worked and the disk was hand-driven. Once close to the balance wheel, I took the sanding paper off and continued with #800 diamond paste. One can only do this when the balance wheel sits true on the staff and has no "wobble". I went on grinding until I saw some diamond paste on the rim of the balance wheel. This was as far as I could grind and it seemed that there wasn't much left of the seat. Carefully, with my staking set, I knocked the staff from the seat-side out. Turns out that the thickness of the seat left, now a small ring, was only 0.1mm. The balance wheel hole is in perfect shape and no damage done to the wheel at all. Of course, if the wheel has a "wobble" or isn't seated true on the balance staff, you can't get as close and there will be more left of the seat. In my case, it worked perfect 🙂 I'm very happy how this method worked out ! 😊
    • As is tradition, one step forward, two steps back. Got the board populated and soldered into place without any issues.   But no hum. So I started testing the coils with an ohmmeter. I got 5.84k ohms across D1 (from red to red in the picture below), which is as expected. But I'm getting an open circuit for the other drive coil and feedback coil, D2 and F1 (from green to each of the two yellows).   Since the movement was working with my breadboard setup, it implies I somehow broke the connection between the coils and the solder lugs. They're all the way at the bottom of the lugs, but maybe the heat migrated down and broke the connections? I guess it's possible it happened while cleaning the flux off, but I used a soft artist's brush and isopropyl alcohol. I did a lot of high magnification examination, and I don't see any issues, but let me know if you see anything I missed or if you can think of anything else I should check.
    • 1947 NOS Ambassador 'C'. Actually, the case came without the movement so the movement isn't NOS, but she sure is pretty.
    • Hi attached is the AS 20XX. Service sheet although there is no 2063 mentioned it may be of some use to you AS_AS 2060,1,2,6,4,6.pdf
