Need some Help, Spanner head screwdriver.
gill1967
I have just purchased my first pocket/fob watch and I am desperate to 'get a look under the bonnet' but the crown wheel has a spanner head screw which I need a screwdriver that fits to remove it. I had some modern spanner head bits but they are a no go.
I have looked on a number of websites...including Cousins and I am struggling to find spanner head screwdrivers for this type of watch screw.
Does anyone have any suggestions. Picture of movement attached.
Regards
Paul
There were tools made for this, and barrel arbors too (in many old watches the hook was on a female threaded ring that screwed to the integral arbor/ratchet). Somewhere in a drawer I have some. But I've always used blunt nickel tweezers. That nut is usually not all that tight.
There are small round jawed jewelers pliers that can fit with a little modification of the tip too.
If you have a pair of very thin round nosed pliers that will do it. Cut down an old pair of tweezers to a snub nose. I had a tool for this which was like a two pronged screwdriver which I could adjust the width to the holes. Never seen one in years.
That movement is known as a five bar movement. It is a cylinder so there are no pallets; you have to let all power off before removing the balance. I expect it is Swiss made.
Could you not simply modify a flat bladed screwdriver with a file or fretsaw blade to put a slot in it, something like these hex bits, only presumably a little smaller.
Alternatively if you want something more like OH describes, look on ebay for small circlip pliers, they typically have interchangeable bits with round tips. One final suggestion, superglue (or epoxy) two pins or sewing needles to a piece of hardwood or rigid plastic at the correct distance apart, then file the points flat to avoid scratching the wheel below with them.
Edited by AndyHull
These cylinder movement sometimes can be a bit temperamental and maybe not the best to  start of with but mostly they are a great fun.
That kind of nut was very popular with makers like Remontoir. The movements usually is in a good shape but the watch cases often seen better days since back in the days everyone was a "Watch maker" and tried to service the watch by over oiling things.
Here is a picture to clarify how to remove it with a pair of tweezers. It mostly comes of like a normal right threaded nut.
Just slightly push downwards while turning it.
You will see another thread on this question here https://www.watchrepairtalk.com/topic/6499-pig-nose-or-snake-eyes-or-spanner-driver-help/#comment-96309
If this is your first cylinder movement, then one word of warning: make sure you have definitely let down all the power from the mainspring before removing the balance, otherwise the train will spin away and you may cause bad things to happen
Enjoy!
    • Just got these good quality diamond files from the bay for Just a fiver, we all love a bargain dont we. Brand names are J.K.Smit  and Triefus, two old diamond tool makers so not cheap crap.
    • Its a touch under ive just remeasured it and added a wrist shot. Unbelievably it was £13  plus 3 postage. You dont find watches that nice for that money every day of the week. Maybe removing the epilame in the oil region improves the purpose of it. We may know very soon as i emailed Episurf 4 hours ago to ask that exact question. 🤞they are happy to provide an answer for us. How do you fancy trying a stearic acid vapour treatment experiment  H .  Shall i have a go this afternoon ?
    • That's the size of my grandfather's Ernest Borel watch. Definitely not a lady's watch! 👍
    • Thanks H It does have a big crown for the watch , it could be considered a ladies watch these days i guess, it measures 33mm case 36mm with that large crown 18mm lug space. A tad small for a guy of today, but still very wearable. The photo was deceptive so here it is adorning my 7 1/4 " wrist. It need some love to make it run better. The hair coils are touching so running a bit fast at the moment,  not caused by magnetism, and maybe just a clean and a service. The dtal is in fantastic shape.
    • That's one beautiful timepiece! Love the big crown in proportion to the case. Perhaps a ladies' watch, but I don't think so. I have a "modern Ingersoll" watch, but it has nothing to do with the original brand (Miyota 9015 movement). Interesting synonym for synthetic oils! 😆 There is, of course, a limit to how large a volume of oil epilame can bind and hold in place. If the oleophobic effect is too strong then it can become a problem. I'm not sure where I heard or read it, but as I understand it, the active ingredient in a bottle of epilame is extremely small and more than 99% of the contents of the bottle is just a transfer agent. If the active ingredient becomes too concentrated, which it can become over time, or if the product is of poor quality, the oleophobic effect is amplified. This in turn causes the applied oil to look like a gummed-up ball on the surface of the treated part. If that happens, we know that the active ingredient has become too concentrated. What we want is for the oil to bind but not to the point where it is formed into an excessively round ball on the surface. The highlighted text in the patent that you refer to describes well the problem that can arise with too high a concentration of the active ingredient. However, I would be extremely surprised if the entire amount of oil leaves the treated surface as water on wax would. At present, I am convinced that the analogy between wax and water on the one hand and epilame and oil on the other is incorrect. Epilame is described as binding and that is also my absolute experience. Epilame probably has some repelling effect but that is not its main purpose and that is not how epilame is designed and works. The method of abrading the epilame treatment from the section of the pallet stones coming in contact with the escape wheel teeth seems after even more research to be well established, but if it actually works, if so how and why is beyond what I can currently understand. Perhaps it is just to do and trust that it is based on well-established experience. I am, after all, inclined to think so.
