AS 1194 Accuracy
Well recently serviced a Louis branded watch. It has a 1950's AS 1194 movement.
It was running about almost dead on for the first few days, now it's running about 20 sec slow. I do not have a time grapher yet. Doing it the old fashioned way. Anyway what kind of accuracy can I expect out of this movement? Or may be too much oil on the pallet stones? Any advice?
Thanks
Sent from my SAMSUNG-SM-G890A using Tapatalk
I'm 99% sure that oldhippy is saying to use very little oil on the actual pallet stones on the pallet fork itself. You don't oil the pivots on smaller watches, which most vintage wrist-watches fall into. On larger pocket watches, oiling the pivots is OK, and probably advisable. I don't remember the exact size cut-off for oiling vs non-oiling. I had a few watches that were giving me grief until I found this out and corrected the situation. Good luck.
Edited by MrRoundel
Never oil the pallet fork.
Ok think that maybe my problem. Still learning. So I oiled the pallet fork pivots and probably put too much on the stones. So time for a disassemble to clean the escape wheel and pallet fork and try again.
I have the red and black dip oilers. Which one should I use for oiling? Also how to get a tiny amount of oil on the stones?
To oil or not to oil!
I'we begun to oil the pallet stones, it actually says synthetic grease on the little bottle of Moebius 9415 not oil but in the oiling sheet from ETA it says oil.
But to oil the pivots of the pallet fork with let's say Moebius 9010 wouldn't be a very good Idea. It's to runny and will find its way to the gap between the pallet cock and the fork.
Since the power here isn't very big it will cause loss of amplitude or bring the movement to a total halt.
I have tried to apply just a thin film of 9415 on the pivots before installing the fork and that seems to work and makes the friction even less than without lubricant. As for the need of a lubricant here the question is already answered. No.
Found this article on the AWCI site about lubricating the pallet stones.
https://www.awci.com/watchmaking-excellen/lubrication/
There seems to be some confusion about oiling a watch escapement.
Use the finest oiler
The pallet stones are to be oiled. Never oil the pallet pivots and never oil the pallet fork.
Oil the escape wheel pivots.
Oil the balance pivots
You do not need to oil the teeth of the escape wheel, the oil on the pallet stones will do this by the rotation of the escape wheel and its coming into contact with the pallet stones.
So, oldhippy, are you saying that it's inadvisable to oil the pallet pivots on larger pocket watches? I'm just curious. I never had noticeable ill effects from doing so on 12-18s movements. I only had issues once I started working on wrist watches and carried that technique over.
Regarding oiling the stones and not the escape wheel:  that's interesting, but I like it. It seems virtually impossible to get the right amount on the teeth on the escape wheel without it spreading too far. Thanks for sharing your learned experience. Cheers.
I have a few of these.I would tell you that they are more reliable than they are accurate.Fifty years old and more they may have quite a bit of wear.I think that they also suffer from hasty assembly.They seem to show more than a bit of beat error,within a minute or two a day is about the best you can expect.
    • Hi, Is there a spell check function available when you are posting ? Regards CJ
    • Hi John I just did a Seiko Lord-Matic a front loader without a split stem, I used a crystal lift to remove it, although I had to have it that tight I though I was going to break the lift before the crystal would budge. So I decided that the press would be a better option as I think crystals with tension rings resist a lot of compressing. I used a crystal press to repalce it and the bezel with no issues, obviuosly a different watch to the Omega. I just took my time and kept inspecting the installation progress bit by bit Regards CJ
    • Hello All, I’m replacing the crystal in an Omega Dynamic, # 165.039, which houses a cal 552, installed through the front of the case. The replacement Sterncreuz crystal is, like the original, with tension ring. I removed the crystal using a compressed air technique to pop it out.  (I have a crystal lift, but I’m always fearful of marking the crystal edges and so avoid using it as much as possible). Now to the replacement -  any tips on putting the crystal back in?  Am I obliged to using my dreaded crystal lift to complete the task, or how about a crystal press?  I’ve put lots of crystals in using a press, but never with the movement in the watch. The thought of using one with a front-loader makes me very nervous, with the fully assembled watch sitting under the press. How would more experienced folks proceed here? Any advice, gratefully received… John Down Under…
    • No thats straight out of the watch as i found it the balance wheel is almost as bad. I've never seen so much material removed.
