My first Anniversary clock!
Mattaphysics
A good point (and I do now feel as if I could put the movement back together in my sleep).
One final (?) hurdle passed tonight, which means I can hand responsibility back to its owner later this week.
The clock was running impossibly slow, losing 10 minutes an hour, even with the weights at their full inward setting.  That sent me back to looking up info on the web, which went on about pendulum weights, length of spring, frictional losses, and spring gauge.
Fortunately, I'd ordered new Horolovar 0.004" springs, which I knew were correct for this clock so before doing anything else I thought I'd fit one on the off-chance.  What a difference it made.  Clearly, the spring that came with the clock and otherwise looked perfectly fine was anything but.  There was an instant turnaround of 15 mins an hour and, with plenty of adjustment still to go at, I'm now down to sorting out an minute or so per hour.
I think that can wait until tomorrow, but it does make me wonder what other insults could have been done to this poor clock by its previous owner/repairer(s) that they hadn't done already.
When ever you get one of these clocks to repair it is good practise to always re-place the s/spring with a new Horolovar one.
I don't know if you have the book on these clocks but it is a must for all who repair these clocks. Don't know what happend here with it all in red, I just copied and paste.
This is the one you want. here is a link http://stores.thehorolovarcompany.com/horolovar-400-day-clock-repair-guide/
Horolovar 400 Day Clock Repair Guide
Thanks, I received a copy of the 10th edition through the post on Friday and very good it is too.
As a tailpiece, over the weekend I came across an empty cardboard Horolovar spring label in amongst the packing the clock was sent to me in the other week.  It had .0037" -  .094mm stamped on it.  I'm assuming this was the packet from which the spring I've just discarded came from, which would confirm that was weaker than the .004" recommended.
The strength of the suspension springs is critical a touch too strong or weak and you will run out of adjustment. I have in the past, thinned a suspension spring to reduce the strength just a touch.
  • 4 weeks later...
Be aware that the Horolovar 400 Day Clock Repair Guide, has some clocks wrongly identified.
Mostly, back plates attributed Phillipp Haas, were actually made by Philip Hauck, a different firm altogether.
The newer clocks, the information is good, it came from the manufactures mainly in the 1950's.  Pre war and earlier information is researched, and as new information comes to light, then corrections have to be made.
But the service and set up information is the best available.
Don't touch either the pallets (if adjustable) or the Eccentric nut, unless all else has failed.
Bod
(Who has a Hauck clock)
Thanks for that, Bod.
Having done one torsion clock (see thread above) a friend then popped out of the woodwork with another.
I got the clock to go but it wouldn't keep time, no matter how the weights etc. were adjusted, so I had to do what Clockboy suggested earlier and thin the spring down a shade.  That was 3 weeks ago and it's been fine since, so I'm hoping any problems are permanently cured.
I'm currently doing a BHA/Becker, but this time for myself.  The movement's been fine but a lot of cleaning's been needed to get it looking anything like it should.
I'm afraid rightly or wrongly I've now set my heart on a JLC Atmos clock and I think I'm going to have to save up hard for one.  They're priced quite reasonably in the US (because a lot more were exported there?) but on this side of the pond, where I'd avoid hideous postage costs and import duties from UK customs, they're at least a couple of times dearer.
Decisions, decisions ……...
Edited by 2131tom
2131tom, be very careful buying an Atmos clock, they are very prone to bad handling, by anyone who doesn't know them.
My neighbour had one, it cost a fortune to have it put right,after a house move by professional house removals company.
The clocks need to be locked correctly before any movement,  I refused to even do the summer/winter time changes on it, she understood!
Goodness knows what damage the house clearance people did to it in the end....
Bod
They may seem cheap in America but if they require a service or replacement parts the cost of ownership can be horrendous, I sent mine for a service about 15 years ago no replacement parts where needed but Jaeger charged £475.00 at the time and the clock was gone for 7 months, cheap Atmos clocks are usually cheap for a reason and non of them good for the wallet.
Thanks for the good advice.  I was already hesitating because of the reputation the clock has if it's not in 100% order and, if I was to buy, I was thinking I probably buy from an established dealer in the UK who would give a guarantee, and I could at least go back to in person if needed.
Thanks for the info Bod I have used the "Horolovar 400 Day Clock Repair Guide" as my bible for many years. As yet it has not failed me but there is always a first time for anything. I suppose providing it is still giving the correct suspension spring length and strength then the maker will be of little consequence for most.
Having bought a 400 day clock at a car boot, because I liked the disc pendulum, the learning curve started!
The suspension wire was missing, but that was it, so I thought.
Investigating the clock, through luck and a charity shop, the Horolovar book was found.
The clock was a P Haas, missing the top suspension gimbal, (always lost) rare as hens teeth apparently.
Found one in Australia, via e-bay described as Haas/Hauck.  Fork and bottom block from India, American suspension wire,  to fit a German clock in the UK.
Found the NAWCC website.  https://mb.nawcc.org/forums/400-day-atmos.15/
Gradually after much reading all was revealed, Haas never made Torsion clocks, confirmed by a Haas family member, after Terwilligers death, so was not included in the 10th edition.
As far as I can gather, there are very few other problems with the book, mainly misidentification of back plates, although the information regarding suspensions for these plates is correct.
I shall soon start a new topic asking for opinions on what I've got.  It's been through clock repairers at least twice, going by the marks under the pendulum, and has some "interesting" modifications.  But runs reliably slowly.
Bod
  • 1 year later...
Hi   I have Terwilligers 400th edition and a look at it, there are many Kundo 400 days  The best thing is if you can post a clear picture of the back plate we can hopefully identify the type from that and then scan the relavent page for you.  hope that is helpfull for you      cheers
Hi, aww... I forgot to click on the "follow button" so I have not received a notification about your post and just opened a new topic for it: kundo Thank you for the offer, I believe I have the same movement as Mattaphysics:
    • Got it thank you! I'll steer clear of the lower jewel count movements until my skills are a bit better. I'm literally brand new to this
    • Depends where you are with repairing, watches like you have just mentioned  the Smiths, Ingersolls, Services are often pin pallet watches with low jewel counts, not impossible to fix but often quite difficult due to having more wear than a fairly standard 15 or 17 jewel movement. Saying that you may be lucky and pick one up that was never used much. As an example i spent a few weeks on and off getting the most i could from an old Smiths Empire, that did actually finish at within 2 minutes per week that could be improved further now i know it is fairly precise but not quite accurate . Sekondas are good practice pieces at around a tenner, though some folk call them rough but robust.
    • Hello people , this is maybe a question that the moderators can answer.  Can seperate posts be unmerged from each other. Sometimes posts are missed by others because of a continuation of them . Even when answering seperate people the posts are grouped together as one. Maybe it saves message board space ?
    • Just got these good quality diamond files from the bay for Just a fiver, we all love a bargain dont we. Brand names are J.K.Smit  and Triefus, two old diamond tool makers so not cheap crap.
    • Its a touch under ive just remeasured it and added a wrist shot. Unbelievably it was £13  plus 3 postage. You dont find watches that nice for that money every day of the week. Maybe removing the epilame in the oil region improves the purpose of it. We may know very soon as i emailed Episurf 4 hours ago to ask that exact question. 🤞they are happy to provide an answer for us. How do you fancy trying a stearic acid vapour treatment experiment  H .  Shall i have a go this afternoon ? Stearic acid experiment underway,  its started to melt at around  65° C. The idea is to find a large cap jewel to suspend over the vapour release.
