My first Anniversary clock!
Mattaphysics
A good point (and I do now feel as if I could put the movement back together in my sleep).
One final (?) hurdle passed tonight, which means I can hand responsibility back to its owner later this week.
The clock was running impossibly slow, losing 10 minutes an hour, even with the weights at their full inward setting.  That sent me back to looking up info on the web, which went on about pendulum weights, length of spring, frictional losses, and spring gauge.
Fortunately, I'd ordered new Horolovar 0.004" springs, which I knew were correct for this clock so before doing anything else I thought I'd fit one on the off-chance.  What a difference it made.  Clearly, the spring that came with the clock and otherwise looked perfectly fine was anything but.  There was an instant turnaround of 15 mins an hour and, with plenty of adjustment still to go at, I'm now down to sorting out an minute or so per hour.
I think that can wait until tomorrow, but it does make me wonder what other insults could have been done to this poor clock by its previous owner/repairer(s) that they hadn't done already.
When ever you get one of these clocks to repair it is good practise to always re-place the s/spring with a new Horolovar one.
I don't know if you have the book on these clocks but it is a must for all who repair these clocks. Don't know what happend here with it all in red, I just copied and paste.
This is the one you want. here is a link http://stores.thehorolovarcompany.com/horolovar-400-day-clock-repair-guide/
Horolovar 400 Day Clock Repair Guide
Thanks, I received a copy of the 10th edition through the post on Friday and very good it is too.
As a tailpiece, over the weekend I came across an empty cardboard Horolovar spring label in amongst the packing the clock was sent to me in the other week.  It had .0037" -  .094mm stamped on it.  I'm assuming this was the packet from which the spring I've just discarded came from, which would confirm that was weaker than the .004" recommended.
The strength of the suspension springs is critical a touch too strong or weak and you will run out of adjustment. I have in the past, thinned a suspension spring to reduce the strength just a touch.
  • 4 weeks later...
Be aware that the Horolovar 400 Day Clock Repair Guide, has some clocks wrongly identified.
Mostly, back plates attributed Phillipp Haas, were actually made by Philip Hauck, a different firm altogether.
The newer clocks, the information is good, it came from the manufactures mainly in the 1950's.  Pre war and earlier information is researched, and as new information comes to light, then corrections have to be made.
But the service and set up information is the best available.
Don't touch either the pallets (if adjustable) or the Eccentric nut, unless all else has failed.
Bod
(Who has a Hauck clock)
Thanks for that, Bod.
Having done one torsion clock (see thread above) a friend then popped out of the woodwork with another.
I got the clock to go but it wouldn't keep time, no matter how the weights etc. were adjusted, so I had to do what Clockboy suggested earlier and thin the spring down a shade.  That was 3 weeks ago and it's been fine since, so I'm hoping any problems are permanently cured.
I'm currently doing a BHA/Becker, but this time for myself.  The movement's been fine but a lot of cleaning's been needed to get it looking anything like it should.
I'm afraid rightly or wrongly I've now set my heart on a JLC Atmos clock and I think I'm going to have to save up hard for one.  They're priced quite reasonably in the US (because a lot more were exported there?) but on this side of the pond, where I'd avoid hideous postage costs and import duties from UK customs, they're at least a couple of times dearer.
Decisions, decisions ……...
Edited by 2131tom
2131tom, be very careful buying an Atmos clock, they are very prone to bad handling, by anyone who doesn't know them.
My neighbour had one, it cost a fortune to have it put right,after a house move by professional house removals company.
The clocks need to be locked correctly before any movement,  I refused to even do the summer/winter time changes on it, she understood!
Goodness knows what damage the house clearance people did to it in the end....
Bod
They may seem cheap in America but if they require a service or replacement parts the cost of ownership can be horrendous, I sent mine for a service about 15 years ago no replacement parts where needed but Jaeger charged £475.00 at the time and the clock was gone for 7 months, cheap Atmos clocks are usually cheap for a reason and non of them good for the wallet.
Thanks for the good advice.  I was already hesitating because of the reputation the clock has if it's not in 100% order and, if I was to buy, I was thinking I probably buy from an established dealer in the UK who would give a guarantee, and I could at least go back to in person if needed.
Thanks for the info Bod I have used the "Horolovar 400 Day Clock Repair Guide" as my bible for many years. As yet it has not failed me but there is always a first time for anything. I suppose providing it is still giving the correct suspension spring length and strength then the maker will be of little consequence for most.
Having bought a 400 day clock at a car boot, because I liked the disc pendulum, the learning curve started!
The suspension wire was missing, but that was it, so I thought.
Investigating the clock, through luck and a charity shop, the Horolovar book was found.
The clock was a P Haas, missing the top suspension gimbal, (always lost) rare as hens teeth apparently.
Found one in Australia, via e-bay described as Haas/Hauck.  Fork and bottom block from India, American suspension wire,  to fit a German clock in the UK.
Found the NAWCC website.  https://mb.nawcc.org/forums/400-day-atmos.15/
Gradually after much reading all was revealed, Haas never made Torsion clocks, confirmed by a Haas family member, after Terwilligers death, so was not included in the 10th edition.
As far as I can gather, there are very few other problems with the book, mainly misidentification of back plates, although the information regarding suspensions for these plates is correct.
I shall soon start a new topic asking for opinions on what I've got.  It's been through clock repairers at least twice, going by the marks under the pendulum, and has some "interesting" modifications.  But runs reliably slowly.
Bod
  • 1 year later...
Hi   I have Terwilligers 400th edition and a look at it, there are many Kundo 400 days  The best thing is if you can post a clear picture of the back plate we can hopefully identify the type from that and then scan the relavent page for you.  hope that is helpfull for you      cheers
Hi, aww... I forgot to click on the "follow button" so I have not received a notification about your post and just opened a new topic for it: kundo Thank you for the offer, I believe I have the same movement as Mattaphysics:
    • Even for myself who only started getting into watch repair/servicing during COVID I have seen a huge jump in watch prices - we have a 404 channel on this forum. When I started you could relatively easily find a watch on eBay to restore and put onto the channel, however this is now almost impossible and the only feasible solution is to buy a job lot with an average price <4.04. Even watches sold for parts/spares are 3 or four times the price of only a few years ago. Why - Either Demand must have increased in order to push up the price, or supply is reduced. I think it is a little of both, I think that most watches in the UK/US may have been picked over, which agrees with most of what @Neverenoughwatches says so supply of all kinds of vintage watches, including tat is dwindling. As a double whammy I think that more people are wanting watches, either to work on, or as a way to differentiate themselves from the Apple Watch and FitBit crowd. The upshot is that half decent watches that require restoration are now $500 instead of $100 and cheaper watches (Seiko 5 etc) are now $50 instead of $10, and even Mumbai Specials and garbage are now pushing $50 each. When - how long will this last, I think that most of the people who are returning to mechanical watches are those that have previously experienced life without them and want to return to something with a bit of personality that doesn't buzz every 10 seconds on your wrist and tell you how many steps you have done today. i.e. the 30-40+ generation. My son who is 17 has several mechanical watches but only wears one on a special occasion and is obviously only aware of them at all in part due to my hobby. I asked him the other day how many of his friends wear a watch and he told me that some use a smart watch but most just use their phones. So as I see it, demand will start to fall once the sub-thirty crowd start becoming the majority and/or the older amongst us stop buying watches and switch our attention to mobility scooters and trying to remember our bank password. Price - I think this is here to stay, even if demand does start to drop as the older generation becomes to decrepit and stops buying and the younger generation isn't interested in buying, supply will become progressively less as time goes on as more vintage watches become lost or broken beyond repair. I think the prices will plateau at some point as an equilibrium is reached as reduced demand is balanced with reduced supply, i.e. less and less people buying less and less watches. Sorry for the long ramble!
    • Hi. Use a PVA based glue, gorilla glue it dries transparent then do as advised by Old Hippy, smoothe down using very fine  0000 wire wool and either French polish or beeswax for a finish.
    • Hello and welcome to the forum.    Enjoy
    • The problem with oil in particular 9010 is it likes to spread. This is why you're supposed to use epilam anywhere it's used to keep the oil in place. Then you want to splurge on money you could buy 941 it's actually an oil that existed before 9415. Then the problem with the grease yes it stays in place but if you have too much you lose amplitude. Then if you get really obsessed with this he would follow Omega's recommendation for escapement lubrication. One of the problems with internal documents of the watch companies is typically are never going to see Them.But a few of them out in the wild for instance at this link Below I searched for the keyword of working. In particular working instructions of the Omega watch company for which there is way more than This but this is all they have. So you want to download number 40 as were going to talk about that and also download Number 81. Plus anything else that looks interesting https://www.cousinsuk.com/document/search?SearchString=Working Then number 40 covers lubrication of the watch. Most interesting is lubrication of the lever escapement under three different conditions with Lubrifar Which you probably no longer have has been washed off without which is what you have and then a course with epilam. Notice how they go supers super minimalistic with the 9415 because if it's too heavy you lose amplitude. Then if you lose amplitude the group will be disappointed with you and the end of the world will come.
    • You would always get an answer John, you dont need to be dramatic or humerous to get one, but it was appreciated anyway 🙂 Kind of, for those of us that wish to stay in touch and continue to learn from each other in case the forum ever dissappears then yes i suppose so . I  hope that you would also count yourself in , what we learn from you is invaluable,  how you benefit from that exactly I'm not sure, being able to teach ? I did say is it ok to ask mark for some input John and suggested that he might read the thread that explains how some of us feel. I dont see how its really discussing forum policy, but in all honesty i wish i had never even bothered now.
