If you have ever wondered what is going on inside one of those infernal kwarts thingamabobs, this article might be of interest.
https://zeptobars.com/en/read/Luch-quartz-wristwatch-IC-at-sc-tuning-fork
The full article is here -> https://3.14.by/en/read/quartz-wristwatch-watch-ic-decapsulation#fun
One point he skips over is the "16-stage divider", this doesn't divide by 16, it divides by 2^16 (or 32768) to give us our one second time reference.
I still prefer a well engineered mechanical watch, but you have got to admit, there is something quite captivating about that die shot.
I was thinking about that.
2^16 = 65536Hz ---> 32768Hz/65536Hz = 0.5Hz as time signal reference ,tick tock twice = 1s.
Magic smoke, and angry pixies. That's what makes all electrickery work.
BTW If you want to see one of these IC's yourself, you don't actually need fuming nitric acid to decap them (assuming you have no intention of ever getting the thing working again, and are not intent on probing signals or whatever).
The epoxy blob they sit under burns quite nicely, and silicon dies are pretty resilient to high temperature (within reason), so why not grab your microscope and indulge your inner pyromaniac. After all, who secretly doesn't desire to consign at least one of those annoying faulty cheap Chinese kwarts movements to a fiery end.
Drat, you spotted my error. I think you are correct, the movement may well both tick, and tock. I guess that is what all that other circuitry is for. You need to drive the stepper motor, and presumably that needs phase shifted signals, so my statement is slightly misleading.
Edited by AndyHull
  "electrickery" i like that.  how about digittrickery?  vin
If you look at the die, things are slightly more complicated than just divide by 2, 16 times, there seem to be more than 16 division stages, and a tap off the ladder part way down... or maybe I am over thinking the problem. :D
Externally, of course things are pretty simple. The chip drives a small magnetic coil, the oscillating field of which in turn causes a rotor to turn, (normally in the correct direction, and very precisely at the correct speed, except when subjected to the kind of torture shown above) which turns a gear.. and then the hip bone is then connected to the thigh bone etc in the manner of a conventional mechanical watch.
The trick is getting it all to work while sipping microscopic amounts of energy from the battery. If the battery voltage drops, either because it is getting exhausted and near the end of its useful life or because of corrosion on the contacts, or high resistance shorts on the PCB, or if the capacitance of the legs of the crystal oscillator are disturbed, again possibly due to dirt, corrosion, cracked PCB tracks, or other environmental screwups, then the precision of the oscillator will be affected, and the watch will run slow, fast, or not at all.
The low voltages involved, mean that relatively small amounts of corrosion, damp and dirt can have a relatively large effect.
So in summary, if it aint running, clean everything, and tidy up any dodgy looking solder joints and try again.
.. oh.. one final point. In your enthusiasm to fiddle, poke and generally clean things, don't break the wires to the coil, they are a right pain the tail to fix back on, assuming there is enough wire left to actually re-connect them.
If you have managed to break a family heirloom in this way, I wish you good luck trying to repair. You can possibly get away with sacrificing a turn or two of the wire on the coil since there are quite a lot of turns, and the precision comes from the quartz oscillator, not the coil. The wire is enamel coated, so scrape the ends gently with fine emery paper or a very sharp blade, then flux them before attempting to  re-attach to the PCB. On the other hand, a lot of quartz movements are not worth the angst of even attempting to repair, so replace it, get out the blow torch, and proceed as shown above, to assign the offending item to the flames (for educational purposes of course).
Edited by AndyHull
I’m not really a quartz fan, but respect their place in horological history.
A couple of years back I restored a 1980 ish Citizen / Bulova movement, which was wirth it because of the 9ct case it came in. The movement had a small potentiometer adjuste to tweak the calibration. Now I understand that any calibration errors are adjusted by changing data in an EEPROM - presumably those horrifically expensive Witchi machines have that capability built in.
The clever bit though is that whilst the crystal oscillates at 32767 Hz, you would think that calibration could be achieved by stepping the motor after one more or one less count of the crystal, but assuming the watch steps once per second, multiplying up, this would mean the adjustment could only be done in steps of 2.6 seconds per day.  So the calibration adjustment is typically set up to only affect one second in each minute - giving an adjustability of 1.3 seconds per month. More accurate watches use other tricks to give finer adjustment.
I’m writing this from memory, so if I have any details wrong, please forgive, but the concept surpiised me when I first read about it, and it is for this reason that a seemingly very accurate quartz watch must be used with geat care and averaged over a long period if you want to use the tick from it to calibrate a timing machine.
Not to put too fine a point on the operation but actually, the 'divider' is a frequency counter or as I was taught when I received my US Navy electronics training back when knights still wore armor, a ring counter. Why was it called that? Because it literally counts every every frequency vibration and then overflows to the next counter in a ring pattern. It is a 16 position counter but the 16th position is the output so it's actually 2 ^15  which equals 32678. When the 15th register fills up, it sends the next pulse to the 16th position which sets a 1 and feeds it to an amplifier that drives the stepping motor one notch and zeroes the counter for the next cycle to begin all over again.
One of the inventions which made modern miniaturized quartz watch circuits possible was the invention of SMT (surface mount technology) 16 position ring counters. You are correct in that it is much more common (read less costly to manufacture) in a modern watch to find a circuit without a trimmer capacitor. The crystal instead is usually set to operate slightly higher than 32678 hz, then inhibit pulses are programmed from the cpu to delay the stepping motor thus correcting the accuracy.
Quartz watches can get a bit technical where the electronics are concerned but they are truly marvels of engineering and inventive designs every bit as much as mechanical watches. Constant temperature helps immensely when it comes to stabilizing the frequency of a quartz oscillator. That's the main reason why the more you wear a quartz watch, the more accurate it becomes. Your body heat is the stabilizing, temperature compensation.
On 1/13/2019 at 4:12 AM, jdrichard said:
Hey thanks. Figured with the amount of travel I do, I need to track at least 2 time zones at once.
Good excuse...I will try it out on the wife
    • By coned do you mean it sits proud of the barrel before you fit the lid?
    • Hi all, Might a posit a theory and people can chime in and tell me if I'm barking up the wrong sycamore: If a mainspring is a bit coned and returned to its barrel for reuse, is it less likely to slip when the spring gets to fully wound?  For a bit of background: Slava 2427, barrel walls greased with 8217, six dots evenly spaced around each of the barrel walls, then smeared/ spread along the wall before popping the springs in.
    • Always in love with watches since I was a kid and with fixing things as I grew up. 10 years ago I bought my first mechanical watch, the Invicta Pro Diver 8926. Recently it started not keeping time at all and when I made an attempt to regulating it I messed up the balance spring. So I decided to go for it and do the following: replace the NH35 movement in it and get the parts to try to fix the original movement. Turns out I should have gone for the balance complete, I just purchased 2 balance wheels. The first one was a disaster, the second one I was able to attach to the stud holder and even install in the watch, but I was definitely doing something wrong as the hairspring got tangled and bent out of place by too much. But by now I know how to install the balance complete. Also decided to change the bezel insert for a green one to freshen it up. But now I'm thinking about either going back to the old danged up insert or keep replacing parts (sapphire glass and another dial, since I lost the "Invicta" letters while cleaning the dial from dust). The invicta has actually sentimental value due to it having seen me go through shit in my life, I'm never going to part from it. I am just debating whether continue freshing it up or putting it back to it's "original" status with all the scars of the old bezel. Parallel to that I made a "build" (watch on the right), putting together a NH34, dial, hands and putting it in a case. It was actually my practice watch for the hand setting. The seconds hand was a terrible nightmare, when I finally got to insert it then the watch wouldn't start. Turns out that the paint job was a bit too thick, shaved a lump with a razor blade and it solved it. Installing the invicta hands on the other movement was a walk in the park in comparison, I'm very happy I practiced with an "aliexpress watch" first. But the thing is that I got it down to around 0.5ms beat error and +6 s/d, so I'll probably gift it to a dear friend as a "tool watch don't baby it at all". Anyhow, cheers to you all!
    • What kind of screwplate are you using? The old Martin ones commonly came in B and L variants. The thread pitch is slightly different between the two, and the full thread diameters tend to be a little off from metric nominal, but the B plates are close enough to metric that they work most of the time. The numbering follows (pretty much) the numbering for stems- at least how stems threads are commonly called out. So a "tap 12" would be 0.70mm. (I can only guess the "tap" size for stems comes from these old plates)   These old plates tend to cut some and also form the thread by displacing metal. I think in part because they are low-tech, and also generally a bit worn. So it's good to start quite undersize with your initial diameter, and work up to something that gives a full thread form. There are variances plate to plate too, most likely a combination of manufacturing differences and wear.   I haven't tried any modern screw plates, I think they are of questionable origin, and even if marked in metric, probably merit some experimentation like the antique ones to find a good starting diameter.
    • Exactly. As Richard says, all good - I helped you by splitting your comment made on an old topic into a new topic of your own in order to help with clarity 🙂 Welcome to the forum by the way 👍
