my friend gave me a rotary to look at.he has had the battery changed by a jeweler? and it stopped after a day.the problem i have is getting the caseback off! there is a arrow > opposite the crown and a little indentation but i cannot get anything to purchase a grip.i have tried all sorts of tools to no avail and i am frightened of scratching the case. any suggestions? kind ones preferably! thanks B.
2 hours ago, berniethebolt said:
where did you obtain that beast?
I purchased this tool a few years ago. i think at the time Cousins was selling them. I have seen them on ebay. If you want a more slick tool and have a bigger budget horotec do this.
found the black one at red rooster £20,so will go for that and hope i need it again! thanks clockboy.B.
On 11/13/2018 at 6:54 PM, clockboy said:
I may be wrong but I did one of those last year. The case back was incredibly tight and I had to use one of these.
bought one of these(above) and struggled a bit until i took the blade off and used that on its own and hey presto it opened.next shock; there was no battery in the movement(?) my mate said he paid a jeweler friend £9 to fix it! i think he needs a visit!! could be he got confused.i will find out.any way the problem is now sorted for a couple of  quid:mad::woohoo-jumping-smiley-emoticon:
Edited by berniethebolt
missed word
On 11/23/2018 at 1:10 PM, berniethebolt said:
i see you edited your post,but i saw it first in my e-mail box! it is a ronda movement.thanks.B.
Ah yes, edited because I re-read your post and realised it was now working.
Didn't know Rotary used Ronda. Is it a recent model? The ones we have in the family are all Miyota but about 7 to 10 years old.
it looks pretty recent but i cant find it on the rotary website !
    • Hi not found one either yet,  close relative is the 436 and 4361 according to ranff.db.   It gives quire a lot of detail but not as good as the old site.      RANFF.DB.
    • No problem to replace the setting with the staking set. Press the new setting from inside, use flat face punch with hole. The punch must be wider than the setting, the hole to be as not to press at the stone, but only on the bush. Press by hand until the setting gets flush with the plate surface, so the punch must rest on it.
    • Yes, the arbor usually makes about 3 to 3.5 turns. But usually spring takes 2/3 to 3/4 of the free space in barrel, not 1/2, so take it for the calcullations. This way the change in torque is smaller. I have a picture for You, this one is little older, but no mater
    • I overhauled a ladies Rolex and noticed erratic performance so I stripped in down again and did fault finding. This is what I saw. The lower jewel (the one in the plate) is cracked and the hole is too big. Before discovering this, I stripped down and re-cleaned the main-plate (and parts) by hand with a fine natural fiber brush. I somehow missed the fault the first time and cannot understand how it was still running. Perhaps re-cleaning it dislodged some pieces of the jewel widening the hole? I don't know. Now I need to replace the jewel but don't have a Seitz tool. The Rolex part is 2130-0913 and the top and bottom are the same. The part comes complete in brass setting with KIF elastor spring and cap jewel. Note: I have never replaced a jewel. I do have a good vintage stacking set that I've used quite a bit.  Can I replace using a stacking set? Any suggestions would be greatly appreciated.
