There's not too much to fret over if you've done a regular 7750 before. There are two wire click springs on the calendar plate that can jump, and 4 jumpers. Two use springs mounted on the plate, and two the wire springs shared with the moonphase advance lever and corrector. The jumpers for the date and year look identical, and they are, in spite of the manual showing different part numbers, so don't worry about mixing them up.
If you've done a 7750 then you are already familiar with the spring for the hour counter hammer and zero lever, that one is always fun to put in place. There is a flat wire spring for the day corrector here, which is easy to overlook or think that it's secured in the plate, but it comes right out. The manual makes it clear how to orient it when reinstalling. The date advance wheel doesn't need to be oriented like the pair of wheels in a regular 7750 day-date, it advances everything in order without any fuss. Pay attention to the minute wheel- it has a little cap on the pinion which needs to go over the hour wheel teeth. This is easy to miss and will lock things up if not installed correctly. Normal 7750 doesn't have this.
Otherwise just follow the (very good) manual for lubrication and assembly. They say not to service the barrel but of course you can and should if not replacing it. On a watch this old it might be a good idea to replace it along with the cannon pinion and reverser for the automatic and possibly the rotor bearing. Do the adjustments for the moonphase corrector (again well explained in the manual), the difference between locking up and not working at all is a very small adjustment.
