Showing content with the highest reputation on 08/04/18 in all areas
Hi guys.. I don't really like working on quartz watches but I do make an exception for the Seiko 7548. I came across this at a flea-market for MYR20 (USD5) so I figured I'd try to get it working. Its actually a 7546 but theres not much difference. The 7548 has five jewels and the 7546 has to make do with only four. The hands have the usual black stuff which is what remains of the original lume. First thing I checked is if the hands set, unfortunately it only does part of the way. Forwards the minute hand sticks at the 50 minute mark and backwards it gets stuck around the hour mark. Day date sets ok. Typically grotty caseback. This is a 7546-7130 It has a full length bracelet.. that's good! What's not so good is the amount of dirt. Those with a weak stomach should look away now. I finally open the caseback and look inside.... what I see is usually enough to throw it into the bin. The battery needs to be physically pried off as the corrosion has made it stick to the movement. Once removed I find this. The corrosion is pretty bad but I've seen worse. In this case the two contacts for the battery are still present and stand up to the prods from my tweezer. Sometimes they are corroded beyond use and break off. The dial resembles a starry night sky. You'd pay a lot of money if this was a high end swiss watch but this is bassically a reaction from the cases released when the battery acid oxidises. That sh\t wont buff out. The stuff under the dial is the same as on the 6309 automatic movement. Looks good so far. But the hour wheel was stuck to the cannon pinion and thats was what made setting the hands impossible. When this happens the keyless works usually suffer broken/worn teeth as people try to force the crown around. Those parts on this watch look ok. Here we have a picture of the underside of the date advance. The date advance is made of plastic so its in pretty ok condition but the mainplate has a lot of corrosion. Next off is the circuit block. More corrosion (the black stuff).. it can be scraped off with pegwood. And the coil is carefully lifted out and put away safely. Here we can see the effect of the battery juices on the watch mainplate. train bridge is heavily discoloured and most likely the pivots as well but its in the battery cavity that the corrosion is heaviest. The (+) contact (held by screw) shows sign of corrosion. If this breaks off the movement is not worth repairing. but luckily it comes off in one piece. I finally remove the train bridge and lift it off. I made a mistake here as the stem is out and the movement is 'hacked' with the hacking part contacting the wheel. Mot really a problem but more important to remember this for the assembly. The wheels are stuck in the pivots so thats not good. Need to inspect them carefully to see if they are reusable. Reference pic to show how the various wheels go together. Bare mainplate ready for cleaning So is the watch worth fixing? Frankly no. The dial is beyond salvage, the damage to the wheel pivots may affect the performance of the watch (surprisingly the pivots look good at high magnification) but the most important issue is the coil and circuit board. They are no longer available from Seiko and this particular watch is never going to be worth the money to source one from other sources. Having said that.. I will check the coil and circuit board and if they are in working condition then I will re-install it and use the watch for a while. Even if I do get the watch to work, I foresee that the eventual fate of the movement will be as a donor for a 7548 diver watch as this seems to be the only quartz watch still in demand. Will post updates.1 point
It’s a high grade movement and very good they are. It could just be down to you servicing it. I know it all sound backwards, might be the oil to much or too little. I would say is one of life’s little mystery’s1 point
Yes , frequency F is a function of L the hairspring's length, (inversly proportional) F=f(1/L) Shortening the hairspring length increses the frequency . Runs faster. But as oldhippy stated " if it is the hairspring " If the problem turned out to be none other than the length of hairspring.1 point
I thought I’d show you this clock that is on ebay. I happen to like this, unusual colour with a nice dial, fits perfectly into the case. Good fusee strike movement. All in good condition. https://www.ebay.co.uk/itm/Rare-Antique-18thc-English-Green-Lacquered-Bronze-Twin-Fusee-Bracket-Clock/173435121142?_trkparms=aid%3D111001%26algo%3DREC.SEED%26ao%3D1%26asc%3D53380%26meid%3D3af6c854d54544f5905279e8b5b886a0%26pid%3D100033%26rk%3D3%26rkt%3D8%26mehot%3Dpp%26sd%3D372383999711%26itm%3D173435121142&_trksid=p2045573.c100033.m20421 point
Thanks@jdm and be sure to keep posting, I always appreciate your suggestions when I’m stuck with something. Sent from my iPad using Tapatalk1 point
Being a mod is a thankless task. I helped mod a forum on toy steam engines for around 10 years, and although a small number of members realise just how much you do, many see you as 'the forum police' there to ruin everyone's fun, so fully understand stepping back to being just a member. Thanks for the work you did during your time as a mod1 point
Sorry to hear that. I hope you will carry on posting so all on here can read you input.1 point
If it is the hairspring that is at fault you need to shorten the h/s a little and re-pin it. You will then need to set it in beat.1 point
