Ok Guys, what is this for
jdrichard
More pictures would be helpful? It looks like a lathe attachment But can't quite see the rest of it to see what it might be used for other than it looks like it has at least one pulley. Then the three things that are hidden in the slots those it be interesting to see.
That’s all I got, but think it is a pivot polisher.
John, I too thought it looked like an attachment for a lathe.
It could possibly be a powered milling/drilling unit for machining watch plates that are held on a face plate in a lockable/ indexable  headstock.
I'm attaching an image I'm guessing that the shaft with the pulley on the end goes into the hole of the main unit. I got the idea for this from the catalog found at the link below. You can download a nice PDF a little light reading. Unfortunately I did not see the same tool in the catalog.
Then in one of the other books I have that lists tools it does resemble a pivot polisher. But the strange part is currently it has a centering piece in their which doesn't quite seem right for pivot polisher? Centering piece would be more for drilling holes except with all the adjustments this is way too fancy for drilling holes.
https://archive.org/details/20thcenturycatal00purd/page/n5
    • I was pleased to pick up a selection of some tools on ebay (v cheap 🤣), and they've just arrived,  I've been looking for a crystal press for a while, and this one is ideal But in the selection is this thing - what is it for?  (it's about 3" long) Something to do with stem tubes?
    • You'll have to strip it back anyway.
    • I think I've heard that more than from just Alex. That doesn't make it right though, but I'm convinced i saw some literature diagram explaining why to do that. There must be good info here in the archives, I'll have to have a dig around.
    • That will mean dismantling the gear train, which with 5 pivots to align was a pain. Probably going to have to though. I'm convinced it's something to do with the great wheel.
    • As far as I know, the only time an epilame treatment has potential drawbacks is when something is rubbing on the treated part w/o lubrication in between creating abrasive dust. That is, I don't believe in the method of "running the watch to make a groove through it first in the pallet stones where the lubrication is then placed". So, I think the rule would be; do not epilame treat parts where rubbing is going on without lubrication. Other than that I don't think we have anything to worry about. That said, I'm not an expert, and I'm always happy to learn more. Has any other repairer than Alex suggested or explained the "making-a-groove" method? My impression is that it's just something he constructed in his mind. I have not perceived it as a generally practiced method. Again, I could be wrong!
