Vintage Omega help
I have two pieces I would like some advice on. New to the forum, and am looking forward to the knowledge this group brings to the discussion. I have owned/own vintage pieces, and am considering these as projects. The first piece is a Cal 352 Ref. 2577/2520 in 18k. I’m very fearful of water damage and rust in the movement. Also, the dial seems to have some water damage as well. But please tell me if I’m wrong! https://imgur.com/a/YFBGUnb
The next piece is a good clean example. Not sure Ref. As I haven’t seen the movement. The issue is. Fairly bent lug. It seems to hold a spring bar in place, but if the case has any weakening or micro fractures I would be weary of purchase. https://imgur.com/a/pGHaATO
Thanks a lot!
Couldn,t open the links.
Extent of water damage can only be guessed, untill all movement is stripped..
Should you like to post the pic on forum or if otherwise make available, so to get  more opinion
I hate to be the one to say this, water is a leukimia to movement., replating...,.etc
It will never bethe jewel it was before water, immediate cleaning helps a lot..In case of unavailability of immediate cleaning nor the back removal, depending on the qualiy inside the case, I would go as far as to recommend braking the crystal to place the watch under the sun light for evaporation..
Regards joe
Hello @Chefbengates! Welcome to the forum. You have two great time pieces there. I am partial to the Omega Seamaster Chronometer, so let's start there. I am including some screen shots of your photos for convenience of others that want to see the movement. Aside from oxidation on the plates, the stem and underneath the oscillating weight, and the oscillating weight bridge itself are areas where I see evidence of some corrosion--probably moisture coming into the case through the crown? How do the bumper springs look? The dial looks OK, but the condition of the movement leads me to think there might be some rust under the dial especially the keyless works. How is it winding and setting? I case back markings lets me know the watch has seen lots of hands, and someone replaced the original sweep hand and the crown. The watch is certainly worthy of getting a good cleaning and thorough inspection.
The Seamaster automatic is in better condition cosmetically, and I see the dial is re-done, and the small seconds hand and the crown have been replaced at some point. Straightening the lugs requires a professional with specific tools, and I had some proficient work done for one of my watches by someone. I could give you specifics if you're interested.
436213592_ScreenShot2018-10-15at10_41_54AM.png.968601adbd5dff8cabd7b1c8df5d412c.png652683580_ScreenShot2018-10-15at10_42_41AM.png.b92f95d434de3e4cb9a40845a83d3ef0.png
Edited by noirrac1j
That Turler-badged one is beatuful. Completely filthy, but doesn't look rusty. Those movements are not too hard to find, so I'd be more concerned about the dial which looks nice to me.
The second dial looks re-painted to me, and that's a non-no for me.
Water is a killer of movements especially if allowed to dry out over a long period.  I wish I could be as optimistic as rodabod regarding the Turner Omega, but I fear you will find some considerable damage when you strip it.  These bumper movements are up there with some of the best for time keeping, so I sincerely hope I am wrong about the possible damage.
Have a look at this, it will give you an idea of how to tackle the job:
    • It looks like the canon pinion function is part of this great wheel. The pinion nearest the clip runs the minute wheel on the dual side. The pinion nearest the wheel is driven by a small wheel from under the setting lever cover plate that engages in hand setting position.    So when assembled the crown was driving the whole great train. Does this mean the pinions are too tight? Should I attempt to disassemble this great wheel and lubricants?
    • Picking up this side-tracked post again as I just removed a balance staff of a 1920's Omega (35,5L-T1) I was impressed by the way @Delgetti had his setup when he had to change out a balance-staff (https://www.watchrepairtalk.com/topic/28854-new-balance-staff-not-riveting-to-balance/page/2/#comment-244054 Not only that, but also the idea of removing the seat first before punching the staff out from the seat-side, avoiding the whole discussion of the rivet yes/no enlarging the hole. I didn't have the fancy clamps & tools Delgetti has, so I used my screw-head polishing tool. Initially I used #1500 grit diamond paste on the steel wheel, which kinda worked, but very slow. I changed to #800 grit diamond paste, which worked better, but still slow. Then I glued #240 sanding paper to the steel disk; That worked and the disk was hand-driven. Once close to the balance wheel, I took the sanding paper off and continued with #800 diamond paste. One can only do this when the balance wheel sits true on the staff and has no "wobble". I went on grinding until I saw some diamond paste on the rim of the balance wheel. This was as far as I could grind and it seemed that there wasn't much left of the seat. Carefully, with my staking set, I knocked the staff from the seat-side out. Turns out that the thickness of the seat left, now a small ring, was only 0.1mm. The balance wheel hole is in perfect shape and no damage done to the wheel at all. Of course, if the wheel has a "wobble" or isn't seated true on the balance staff, you can't get as close and there will be more left of the seat. In my case, it worked perfect 🙂 I'm very happy how this method worked out ! 😊
    • As is tradition, one step forward, two steps back. Got the board populated and soldered into place without any issues.   But no hum. So I started testing the coils with an ohmmeter. I got 5.84k ohms across D1 (from red to red in the picture below), which is as expected. But I'm getting an open circuit for the other drive coil and feedback coil, D2 and F1 (from green to each of the two yellows).   Since the movement was working with my breadboard setup, it implies I somehow broke the connection between the coils and the solder lugs. They're all the way at the bottom of the lugs, but maybe the heat migrated down and broke the connections? I guess it's possible it happened while cleaning the flux off, but I used a soft artist's brush and isopropyl alcohol. I did a lot of high magnification examination, and I don't see any issues, but let me know if you see anything I missed or if you can think of anything else I should check.
    • 1947 NOS Ambassador 'C'. Actually, the case came without the movement so the movement isn't NOS, but she sure is pretty.
    • Hi attached is the AS 20XX. Service sheet although there is no 2063 mentioned it may be of some use to you AS_AS 2060,1,2,6,4,6.pdf
