Cheers Mates!
Im working on a Tag Heuer 1000, and when was done fixing the watch. It would not start again when putting in battery. Are there a reset thing with these movement. Somebody know??
It was going just fine before I took out the battery.
14 minutes ago, arkobugg said:
Cheers Mates!
I have to add to this case, that I had to go in an do an correction because this lever her was misplaced?? see photo: So I placed in the slot to the clutch wheel. I hope that was right??
Edited by arkobugg
Did you cover up the gold negative tab with the orange insulator by accident? It has to be showing with the little tab on the insulator under the metal terminal tab. Steve
Sent from my iPad using Tapatalk Pro
That is correct. Hope that would solve the problem and that the movement will work again. They are not that common this days and aren't cheap to replace.
Edited by rogart63
Pls explain more what you mean ? Do not  understand ....
In the area of the top right of the orange insulator where it has a tab going up into a channel, there is supposed to be a gold metal springy tab sticking out and above the insulator. That is what the battery makes contact with on the negative button. The insulator is there to prevent the battery from shorting out to the body which is positive when the battery is in. I can’t see the metal tab at all and assumed it was under the insulator, but I don’t really even see it there, looking through the insulator. It is possible it is completely broken off, which happens all too often if battery acid corroded it. Pull the insulator out and look for it underneath. It should be obvious if it is there. Steve
Gpsluvr points out that the small negative battery terminal appears to be underneath the orange coloured insulator !. The gold terminal should be visible on top of the insulator !.
Okay, than I will check that... thanks to all..
The negative battery terminal  sits  on the circuit so that is not under the orange insulator. The plus is over the battery. So as far as i can see everything is okay. I can't see if it's there on the first picture.
That is beacuse the minus tab is fastened on th print board that I have taken of the movment in the first movment. So the minus tab is laying nice an fine on this photo.
But that I also need an answer on, is this lever suppose to be in the grove to the clutch wheel ?  See red circle!
Edited by arkobugg
That lever is the yoke. It also has two additional legs: one inhibits the circuit when the crown is pulled out, and the other jams (hacks) the wheel in the centre.
Using a loupe, look into the movement and pull the stem in and out. You should see the hack lever touch one of the wheels, but only when the crown is out.
Also make sure that you did not scratch the coil when changing the battery. That’s a common fault.
13 hours ago, JohnR725 said:
did you ever get your watch running?
Nope, It started with that setting lever was stock in outer posision, so I had to go in via the calender work to get to keyless work, but when I was putting things togheter, I noticed that the clutch wheel could not move along the stem, somthing in brass was jamming the clutch wheel. So I had to take out the print board, and the I found out that the yoke not was in the grove in the clutch wheel. So I placed that right and put things togheter the same way. After that the watch would not start...But I have a friend that are an expert on quartz Tags, so he can fix this. Im more into mechanical watc myself...
one of the things really important when asking questions is to give a proper description of the problem?  In other words  I see that you took the battery out  you put the battery back in it was running before and now it's not running? But  you also indicated you are fixing a problem in the original question you didn't explain what you are doing?
Then your photograph and your better description of what you did.. The photograph  it appears to be a crown gasket has failed  and rust is migrated down the stem.. The one plate screw in the photograph has the same discoloration like the stem.. This indicates that moisture has  entered the movement. This very likely cause the original setting problem. Then no watch likes rust quartz watches are we way more sensitive. The gear train just has no power for anything that's  going to cause a friction and that includes rusty pivots and the oil going bad. then the photograph of the seconds stop lever the part that goes into the clutch wheel doesn't look quite right in the photograph? It might just be an optical illusion in the photograph.
So if you have a friend who is an expert on quartz watches it's time to visit your friend..  The other problem with quartz and electric watches are  you need test equipment to figure out what the circuitry is doing whether it's working or not  whether the current consumption is too high or whether the coil.is open because it got scratched or bumped.
Hello JohnR725
I appreciate very mutch all the good help I have got during this watch repair!   But that is why I usual stick to mechanical watches, and that this was just for a really good friend. And that I usually dont do quartz.     Thanks to ya all...    :-)
JohnR725
    • Dr ranfft sees no difference between venus 180, 181 & 182, and  other calibs of same family are highly likely to  fit. @donutdan  Go on to the link below to see all related calibs, of all them you might find one to buy. https://ranfft.org/caliber/10591-Venus-180  A venus movement  is a terrible thing to deprive of TLC. Good luck
    • Hi John, I didn‘t adress you or your statement, just grabbed a fitting quote 🙂. Maybe it‘s me, but always getting a bit nervous reading about „parts swapping“. How often did we read here that swapping back and forth didn’t help? Why not try to advance with someone‘s skill and do repair. Frank
    • Yet another Rolex has landed on my bench — this time a Sea-Dweller, ref. 16600, equipped with the trusty calibre 3135, the same calibre as the last one I worked on. The time and date settings are completely dead. I guess the yoke has slipped out of engagement with the sliding pinion. It remains to be investigated. If that is the case, it certainly makes you wonder how it can occur, considering the outstanding quality of these movements. Perhaps it was subjected to trauma? Perhaps a sloppy assembly of the keyless works? However, it is running very well. A you can see, the maximum delta is seven seconds. The maximum acceptable delta for this movement, as specified by Rolex, is 10 seconds. The average rate fully wound in five positions (crown down, left, up, dial up, and dial down) is 1.8 seconds per day. The rate tolerance as specified by Rolex is -2/+4 s/d. So it's all looking pretty perfect. What's very strange, though, and something I can't get my head around, is that the first time I measured it on my timing machine, fully wound (I could hear the mainspring slip in small steps while being wound), it performed quite poorly. The rates and beat errors were fine, but the horizontal amplitudes were around 235°, and the vertical amplitudes were all below 200°, which is the minimum amplitude as specified by Rolex after 24h. Performing that poorly, being fully wound, I felt it wasn't much use to measure it again after 24h. However, to be thorough, I nevertheless did and to my astonishment, I got the results as seen in the table above - "Fully wound minus 24h (Not Serviced)" - At that point, I decided to give the watch another full wind and take another measurement, and I got the results as seen in the above table - "Fully wound (Not Serviced)". If anyone has any idea about why I got such a poor performance the first time around, please let me know! As can be seen, the oil beneath the cap jewel is noticeably depleting. If it wasn't for the faulty date and time setting, I think this amazing watch could have been left alone for another year or two, but considering it has to be repaired, why not service it as well? Especially considering the funny behaviour in amplitude I described in the previous paragraph. What do you think? All opinions are appreciated, but if one of our much-appreciated pros, such as  @Jon, @JohnR725, @nickelsilver, or @nevenbekriev could weigh in, I'm sure it would be appreciated by many. The fit between the bracelet ends and the lugs was very tight, and I couldn't get the bracelet out by simply pressing the spring bar from one side through the drilled lugs. I'm sure there's an original Rolex tool for it unavailable to enthusiasts, and even so would cost a small fortune. During the years, I've bought a small fortune worth of tools. Some of those tools have been a complete disappointment and a waste of money, such as the spring bar tool in the picture, which I've never used and have been meaning to resell for a long time. However, as I couldn't get the bracelet out, I came to think of it, and cut myself two pieces of brass rod, deburred and polished the ends, bent them and inserted them in the tool. It worked like a charm. I’ve got to say, I’m kind of proud of this little bit of brilliance. If I’d read something like this when I was just starting, eight or nine years ago, I would’ve been super impressed. Especially considering I could barely tell which end of a screwdriver to use back then. Okay, maybe I’m exaggerating a bit, but you get the gist! I just hate it when you can't unscrew the case back by using a rubber ball. Is it really necessary to screw the case back on so hard? It's a sincere question. Maybe it is necessary for a true diver's watch like this Sea-Dweller. Fortunately, I had the right size, a number five Rolex die in my set. Getting the case back off, I had to bring out the "Big Gun". Even so, I had to apply what felt like an insane amount of force. I actually worried the tool might break, and it was not a pleasant experience. So, two thumbs down for the previous repairer, who... ...also decided it was necessary to scratch up the inside of the case back lid, which likely halves its market value. I wouldn't be surprised if the same guy caused the setting problems by being sloppy while assembling the keyless works. We shall see! I’m really looking forward to hearing your thoughts on my questions and musings!
    • I find myself in a frustrating situation, and if I have learned anything yet it's that there might be a specific old tool to get me out of it. I am rebuilding an early grade Elgin 18 size full plate movement, just restaffed and installed a new roller jewel. Next I found that the pallet stones were loose and added shellac to them, reassembled but the watch does not run. Observing the escapement through the holes, it is clear the entry stone needs to move in slightly. So I know what I need to do at this stage, but I fully expect to need a few adjustments of one or both stones. I don't want to move the banking pins because it did want to tick before I noticed the pallets were not secure. Question is, on a full plate movement this is incredibly inconvenient to make a change, let the shellac harden, and reassemble the entire full plate watch in order to observe the escapement action.  It can only be seen from the dial side through the small holes in the pillar plate, so even the balance must be installed in order to manually operate it from the back. Anyone know how this was done 120 years ago? Is there a tool or fixture that can be used for the job outside the watch? Depthing tool maybe? You all like pictures, so here are some. Final cleaning has not happened yet, thus the dirt and oil on the 4th wheel jewel.
    • Okay,   I will try to help if I have enough knowledge to write a reply to someone or if I have information to share. Thank you so much for writing a reply. Have a nice day.
