amplitude problem
watchweasol
Hi Guys watch weasol here from  St Combs Scotland. been repairing clocks and watches for many a year, now retired and still at it
but now I have a problem on a Omega 522 It had a broken  mainspring  which was replaced (GR) and re assembled problem is that
I cant get the amplitude up to 250 deg it is around 160 deg and running fast. I have cleaned the watch removed and cleaned balance
jewels and run up using a Horotec timer Lift angle = 49   Beat error = 1ms,   Any ideas or pointers would be appreiated.
thanks   Weasol
Hi Weasol, I had a similar problem a little while ago with low amplitude on an old Everite watch. I re-cleaned the pallets and pallet bearings in Acetone to completely remove all oil and re-assembled with NO lubrication to the pallet arbors. Result was a further approx 60deg balance amplitude. Old Hippy advised me to do this. I used 9010 the first time and I think that it is a bit sticky !!. Just saying.
I've said this many times, but those later Omegas (500 series onwards) have finer pivots are are more susceptible to suffering from the effects of dirty jewels as there is less torque going through the train.
However, you mentioned it runs fast, so I would also look very closely at the action of the hairspring to look for any irregularities. Could be bent or magnetised.
Is the amplitude the same DU and DD?
I can confirm this - see the thread "Omega 613 low amplitude solved. Don't forget to check this jewel is you have low amplitude".
A dirty balance hole jewel was enough to knock the amplitude down from 270 to 190 deg.
BTW there's no listing for 522 on Ranfft - do you mean 552 ?
Cheers guys food for thought there, I changed the balance complete in an effort to isolate the problem
and got the same result, maybe have a closer look at the pallet and jewels. sorry for the typo I meant a 552.  good advice as always will let you know the results when I get down to it got a few jobs to do. by the way its the same DU or DD. The finer pivots may be better running without oil, just a thought.
thanks   Weasol
Hi, it’s running fast because the amplitude is so low...
Cheers Kaz
There are so many possible causes, can you give any more info? Does the train have backlash with the pallet fork removed? Did you peg the jewels, especially the escape wheel and pallet fork jewels? With the fork out, does the balance oscillate freely and for some time? Are you sure you put the right mainspring in? Try removing the tension spring for the sweep seconds and see if amp goes up to eliminate that.
Hi Guys  Right got back to the job , removed the oscillator weight and associated bridge leaving a basic watch. remove the balance and pallet cleaned and reassembled dry (no lube) amplitude has increased
 but watch o scope reports a loss rating even though the regulator is fully advaned. The oscillations of the balance look good and again watch o scope reports 250deg. My horotec sensor wire broke so have no recourse to back checking  (Gremlins).
The train seems clear enough and has some reverse movement when manually operated . the mainspring was a GR from cousins for the 500 series omega so should be ok..
Will have to repair the sensor or get another.  happy days.  thanks for guide lines guys.
cheers  weasol
    • does anyone knows what type of battery this digital Watch takes?
    • Hello good watch folk ,I  just fancied a light hearted discussion after my head was starting to spin over Epilame 😅. Specifically I'm meaning the sale of vintage watches, say nothing past the 1980s market. The stuff we see on ebay and other similar sites and found at carboots, curio shops etc. And are  we thinking its reaching a peak volume ?  Younger generations clearing out passed parents and grandparents possessions.  The younger folk are not as sentimental as the old fogies ( I'm now nearly at an age that i used to think was old fogie age ). When might it have started ?  i often wish i discovered the hobby much much sooner when selling your grandfathers pocket watch at a boot sale for a few quid was just a way to offload some tat. And when might it slow down. Thoughts anyone ?
    • Yes i did eventually realise that the oil will act as a barrier, I'm sure the discussion will continue. Ive had two oleophobic coffees ( added coconut ) and in the meantime i have this just delivered to take my mind off epilame for the time being. My favourite type of dial, its a beautiful looking watch traditional English made and it runs,  the ticktock is phenomenal,  i can hear it across my living room .  You wont believe how much it was. Thats interesting about synthetic oils , i thought the same, going from a 2 year service to 5 years is a big drop in income for service folk.  I expect some did well when they embraced the use of synthetic,  probably drawing in more customers than those that didn't use the new fangled substances , i bet fairly short lived though. The more frequent service makes more sense to me, not for just the service but for the regular check up inspections that might pick up impending faults. As far as epilame goes, wouldn't it be great to be able to fumigate the complete movement in a sealed jar of heated stearic acid, 🤔 now theres a thought 😅.
    • Imm going to close the discussion by attaching the photo of my super-titanium after several vicissitudes finally working. Purchased as not working I replaced the battery and for a stroke of luck I found its semi-new solar panel which, having verified its operation, seems to recharge the accumulator perfectly. I had taken this watch almost by bet, with 40 euros I brought it back to life. The initial half idea was to resell it to finance another purchase, but.. it's definitely a nice item. It would need to check the impermeability but it's a pleasure to see it on the wrist 😃
    • In fact the secret is to go gently and find the way without forcing, and the movement enters without problems
