Well if that should happen I would take the bridge off and apply more. I dont remember that ever happening to me though. I always apply a big o heap. Hard to imagine the space between the jewels ever running out for how much ever you can fit in the concave before running off to the side.
You probably have a really good technique. In my experience, filling the sink doesn't come close to making the right sized circle under the cap jewel. If it works it works!
On 8/3/2019 at 6:16 PM, nickelsilver said:
There's a commercially made "oil pusher
Oh, now I understand! I bought that thinking that it was to drop a precise amount to the end stone, Incablock specifically. When I found that it does not drag any oil I almost wanted to feature it on my topic of  tools for laugh. Happy that I didn't, because I would have been the tool to laugh at!
  • 2 years later...
On 9/15/2018 at 4:46 AM, JohnR725 said:
jewels like this are used to reduce friction. I have an image where you can see the side view Then for lubrication you can try to put a small drop on the cap and carefully put it back in place without moving it around but that usually isn't the best way.I also have an image showing how to do that. then at other option for lubrication is a automatic oiler. You can insert it through the whole from the backside the oil will flow out.
Can I ask for the source of this oiling graphic? Is this from a book or a file, I got really interested to it.
Edited by ColdWind
They are two separate PDFs.. One of them is an ancient Omega document that I scanned to a PDF which covers really quite a bit of what you need to know to lubricate the watch Then the other comes from a  document by Seitz Just can't quite remember which one I got it from so I'm attaching something that has the equivalent..
667675573_OilingOmegawatches1957.PDF Seitz book.pdf
