Hi I’ve a breitling superocean auto keeps time while it’s on my arm but at night it stops as I wear it all the time with a shake it starts I don’t have loads of money so dose anyone no what it may be and cost ? The watch hasn’t been worn for along time maybe it just needs a good wind ?
If your watch is authentic it may be worth few thousands, so it makes sense to have it repaired and serviced by a reputable professional, as periodically needed with mechanical mov.ts.
Otherwise you can leave it aside for a different, honest watch that runs reliably.
Well, the automatic winding is supposed to keep the watch running for 40 hours or so, clearly it's not working so you need to bring it in for repair. Of course if you're OK with manually winding it all the the, that's your decision. I hope that answers your question.
1 minute ago, Craiguk said:
So why dose it run ok when I wear it ? It must be holding a little power ?
Evidently produces little winding power, not enough to last a night.
The auto rotor is enough to keep it running while you’re moving but seldom enough it actually charge it, unless you’re very active during the day. All my autos require winding once a week...
So it could just need a good winding ? It’s not been worn for awhile how much is a good winding ? Daft question I no ?
It's free, as mentioned above you can wind it as you want, anytime.
However, when you run a watch with dried oil it wears pivots and jewels. At that point the repair will be much more expensive that the regular servicing.
Should be a few hundred dollars for this kind of watch. Or pounds.
If it only needs a servicing then it should be upwards of 200 GBP.
I would factor in the region of around £500 for a service, thats the price you pay a luxery marque im afraid, can you manually wind the watch with the stem or is it like a seiko where you can only wind it by the auto winder? My old seikos will start with a shake as im putting them on, ill then shake my wrist for about 5 seconds and fter that if worn all day will keep time, and when taken off at night will keep time all night and the rest of the day of left sitting in the watch box.
If yours isn't able to do this after say 2 days of constant wear then its a trip to the AD to book a service im afraid, or see if a reputable independent will service it for ptobably half the price, but be aware if not a recognised brietling service centre they might find it hard to come by certain spare parts ok.
My guess is that the auto side of your watch is not functioning correctly. Normally this is due to dirt and lack of lubrication. Your watch needs a full service.
Hi, Try to wind fully and listen for possible mainspring's sudden discharge. If fully winds, in effort to find symptoms, make a note of how long it runs and the hour/min the hands stop on, after stopping, shake quick to kick restart and note how long it runs afterwards, repeat the whole proceedure over to ses if some pattern is observable, your data may just provide a clue to a master watch repairman.
I would ask repair shop for description of the problem and the reason for repair on repair order sheet.
Hopefully it is a several hundered euro question, just a fault at a point, since the general weardown throughout the entire movement's train can cost more to fix.
Please do let us know of the final results.
Regards joe
I,ll work with you to narrow down and hopefully find the solution.
If you got the basic tools, screwdriver, tweezers and wrench to remove the back if neccesary.
Appearantly the watch holds about 3 to six hours of power, starts with a shake. How long after the shake dose it run?
  • Confused 1
If you want to "work with the OP" please use PM. The correct  answer has been given already, this expensive watch needs a full service by a professional, no repair is possible or advisable by the owner with just basic tools.
Topic locked, it can be reopened for updates by the OP.
  • jdm locked this topic
This topic is now closed to further replies.
    • You're asking a pretty broad question and you didn't specify the machine but yes it's simple especially if you have the right machine. The question has problems but I'll take it as it is. Is it really that simple yes especially if you have the right machine. So in the video below he's making a screw and yes it really is that simple but pay attention to the machine it is not simple at all probably wasn't cheap but it is small it will probably fit in your garage. Unfortunately wouldn't fit in my garage as it's far too cluttered up with things. In the video he talks about making a screw and pay attention to the machine. The machine has lots and lots and lots of cutters and lots of things to do lots of machining all-in-one machine conceivably one step after another all programmable. If you look at his channel lots of CNC's stuff and there are several other videos related to this machine. He goes to the factory where they talk about it and show all the other machines they make in Switzerland.  I did look up the specifications the machine I don't recall the price it's not going to cut wheels I think it has a maximum diameter around 11 mm basically it's really good for making small diameter watch parts. Then in one of the other videos he goes to a factory that used to make parts with waterpowered machinery been in business for 100 years and everything they now make is made with CNC machines including this one. What was interesting with the factory photo was that when they make some parts they can put them on a optical comparator comparator compares with whatever the reference is and the machine can be programmed to adjust its cutting to make sure everything is actually being made to specifications. Oh and then somewhere in all of this there was at least one picture of a balance staff can't have a CNC Swiss machine without making balance staffs.   It would be really nice if we had pictures of the machine. Then yes if you look at the page for wheel cutting you can enter parameters and it will generate a G code but he left out things? Notice he has a picture of a complete wheel but the G code isn't making a complete wheel it's only cutting the gear teeth I don't see whereas the program for crossing out the spokes? Typically when you see people cutting gears once the teeth are cut most the time the spokes are cut by hand. Occasionally someone will mill them out but typically not with the program which seems strange if you have CNC capability for instance one of my friends fill it used to design assembly line equipment or things to make things. So his hobby was to continue to make tools to make things like clocks. Very interesting and clever clocks but his true fund was making the machines to make the clocks. Then machine is not controlled by G code like we would typically find today as the stepping motor controller he has was made a long time ago and the individual controllers used a textbased program. So the company had a editor you could write a program to cause each the stepping motors to do something. So basically once you figure out how to cut a gear he would just change the parameters for different size gears so here's an example of a gear as you can see we have the teeth and the spokes. Then we have a picture the machine which sucks because it would've been so much nicer if I could've taken a picture when it was cutting a gears so we can see things better. Then yes there is a worm gear stepping motor indexing this is a mini lathe and the indexing is at the end of the lathe head hiding. The basic operation of this machine would be brass sheet not cut to a specific diameter size not even round mounted on the machine. Then it turns and a milling cutter will cut the diameter. Then the gear would be cut with a gear cutter. The same mill cutter for the diameter although conceivably change the size I don't know but basically the same milling for cutting the outer diameter would be used to cut the spokes. I really can't remember how he did the center hole but whatever it was was very precise.
