Proper technique for removing crown from stem?
By Terrinecold · Posted
Yes but my own pc is a desktop in a different room. I have a work laptop but that is work only. -
Did the balance run good with the old cock? if not, 1-Check if the roller table rubs on fork horns, in case you can,t verify anything visually, remove the fork . 2. Check end shake on balance. 3. See if H/S rubs on balance spokes or on underside of the cock or the coil fouls itself. Once you had the balance detached from the cock, you had a chance to check pivots for shortness or bent or chipped pivots? You ought to check these now. Are you sure jewels in the setting are clean & fault free? Good luck
Wasn’t sure where to put this but Because of the problem I have with my hands ( gout in both )I have trouble holding things especially torsion clock hands to remove them, I have tried the usual tools but not impressed with them but to be fair one was for watch hands anyway I see an antique one on eBay so put a bid on it needless to say I was out bid but decided I could make something similar and I must say it works a treat, I decided to thread my one but it looks like the one on eBay was a push operation . Dell
Wearing a big lump of a watch today. Feels like i have a kettlebell on my wrist. Aw no and i promised no more bare leg shots 🤷♂️ , good god our lass needs her legs shaving and before anyone asks no she didn't lay the watch on top of my head and take a picture 😅 -
I have a Bergeon set, a Chinese set, and and anonymous set (in aluminium), and all of the handles and winders are interchangeable. There are slight variations in the fit but essentially they all fit and work.
