But you are all missing the point. The final mark of quality is that the blades should be dressed with the Horotec or Bergeon twin roller sharpener that produces parallel faces at the blade end. $$$$$
It does make a lovely job Colin, but not required unless you just have to have hollow ground blades.
Geo, didn't you notice the touch of irony?
I find that with a little care on a single round-section stone, dressing each side in turn, I can do the job just as well for twopence.
Colin.
As others have said, it's the quality of the blades that's the most important factor.
However, I decided to treat myself to a recent birthday present with a set of VOH screwdrivers, they are an absolute pleasure to use (and have a nicer feel than any Bergeon, Horotec or AF that I've used).
post-1141-0-93290200-1446762517_thumb.jp
But I also use various other screwdrivers where one of the VOHs isn't suitable, these are mostly tailored and dressed for individual tasks, here are about half of them  :biggrin:
And also as others have said, shaping and finishing the blades is critical to maintaining good tools and reducing the risk of damage to scres and other delicate bits.
post-1141-0-25424600-1446762709_thumb.jp
Edited by JimInOz
Hi guys! Does anybody know were I can buy VOH screwdrivers in the uk?
I've tried all over but I've had no joy!
I'm looking for the 2.5mm screwdriver,
Cheers guys [emoji2]
Hi clockboy, I'm just trying to complete my set I bought a couple of years ago off swisswatchtool the screwdrivers are fantastic mate! I just need the 2.5mm to complete the set!
I suppose this is a "sentimental" 2.5 mm screwdriver issue, otherwise I would get a different brand, readily available from your preferred -- read expensive -- brands, whichever one you choose. The nice thing about screwdrivers is that there are tips available separately so maybe, just maybe a VOH for say, 2.0mm tips, with a little elbow grease may "host" a 2.5mm tip...of course the color code will be screwed up...pardon the pun.  :)
In any case, I hope you find what you are looking for.
Cheers,
Bob
Thanks Bob, I'll keep looking for now mate! I've just been looking at the bergeon 30081-250 nice screwdriver at a good price! [emoji2]
Sorry to tell you bosstaki, "good price" and "bergeon" are mutually exclusive words! :) I wish you luck in your search, if I find something I'll post it here.
Cheers,
Bob
They are as good as Bergeon and the tips fit each other. Some people are partial to them rather than Bergeon. Also they offer different models just like most everybody else. Honestly, I made my set a little bit of everyone so I could compare and am using mostly the cheaper Bergeon one (about $100 set of 9). All that said, it is mostly out of habit rather than because of niceties. The rubber covered ones are probably better to my taste but somehow they still get second choice. Go figure! In the end it just a matter of habit and individual preferences...at that level of quality.
Hope it helps your decision,
Cheers,
Bob
I'd hold out for a VOH and only get a cheapy if you really need a 250.
I think it would make you grit your teeth every time you saw the **BLEEP** child among your VOH beauties.
I know it would me.
Best of luck with your hunt.
Cheers
Jim
post-1141-0-21308000-1447717269_thumb.jp
    • Thank you. No value to me, and I guess not much value to anyone else either - just practice fodder as far as I see them. Ingersoll might make a nice watch to wear if I manage to service it. Benrus, I suspect, is too far gone in terms of case and dial - no cheap ways of getting them to decent looking condition? I wonder how these old movements compare to modern Chinese ones? Probably not favourably, even if there's nothing broken in them? Progress moves on? I've got an old Slava that I'm quite attached to, so I won't be learning on that one.
    • Welcome to the forum. You're best starting with something that you know runs well and keeps good time. That way when you've stripped and service it, any problems are due to something you've done.
    • Welcome to the WRT-Forum! Sorry to say it, but you’re very likely to break or lose something when servicing a wristwatch for the first time — I’ve been there! So, if these watches have any value to you, don’t attempt to service them as a beginner.
    • In writing "shimming the staff" I was alluding to the idea trailed in the above referenced thread of inserting a hair along the staff which, as the discussion there covered,  could result in some eccentricity. By making a (more or less) complete cylinder I was hoping to avoid that problem. Don't tell anyone, but needing a very ductile metal to do this by manipulation at such a small scale, I used a piece of an empty Tomato pureé tube! It occurred to me that the material's ductility(?) would also put less stress on the RT in forming a sufficiently tight seal. Anyway, that's how I avoided the temptation to use glue. No doubt your punctuational response to this confession will be "!!!" !
    • Hi All. I would appreciate some advice for a complete newbie on getting into watch servicing - nothing serious,  just as a fun project. I've got a thing for hand-wound watches and would like to bring an old watch (or two) back to life, so looking to learn to do a strip-clean-oil-assemble cycle.   I've toyed with this idea in the past (years ago) and picked up a couple candidates to learn on, but never found the time for them.  One is an old Ingersoll, swiss-made 17 jewels. It seems to wind and tick. Casing, dial, glass are in great shape, so looks like a good candidate to me for the first service. The other is a Benrus DR23. It winds and makes a few reluctant ticks, but then seems to stop. Casing looks like a complete gonner, and the dial is in pretty poor shape too. If the movement is not broken and just needs a service, I wonder if there's any possibility of getting a cheapo Chinese casing & dial to fit this movement in, or is it extremely unlikely to be the right size?   For a start, I want to strip & assemble a movement, perhaps a dozen times to build up the basic parts handling skills. I see that online advice is to buy a Chinese-made ST36 for this purpose. Can I just go at the Benrus or Ingersoll instead, or does it make more sense to get a cheap ST for this? Thank you.
