Replace lead gasket
Welcome to the forum. Are they the same movement?
By rottobotics · Posted
Thank you both. Out of curiosity, what are the conditions for each post to not need approval by a moderator? I've been on the forum about 5 months, started 2-3 topics, and have 14 posts. -
I appreciate the suggestions. The o ring was hardened and Cousins would have cost $13 shipped, so I ended up sanding and filing a 2mm ID, 4mm OD down to size that I had around. The washer wasn't going to stay in place on it's own, so soldered it. I hadn't thought of that before, so thanks for mentioning it. If this fix doesn't work out, it looks I should probably just replace the whole crown. -
Dear sirs, I have an Omega pocket watch with movement serial number 4480628 and the balance spring became torn as the picture included below. I've got a similar movement for spare parts but it is from the next series (5023967). Do you think the spring might be compatible? Thank you for your help! Best regards, gerardo.
