Dirty Mainspring (not for the faint hearted)
clockboy
56 minutes ago, clockboy said:
Bad news my repair did not work while pinning the dial the bezel to the case the hinge has come adrift. I will have to come up with a different method.<_<
How about leaving more solder on the repair. The more you remove the weaker it will become.
The problem I have the solder will not attach to the dial. I am considering tapping the hinge and then attaching it with with micro screws. I will investigate when time (family commitments). I do have a new bezel & dial complete that fits but the dial is white. If I run out of ideas I will offer this option to the customer. I have spent a lot of time on this job already and I have a couple of watches on my bench waiting for a service.
16 minutes ago, Lenj said:
Shame about the hinge coming apart. Did it come apart clean with the epoxy resin? two part should have done the job on it's own probably did not stick to the solder??
It came clean away looking at it closely it appears that when the bezel it is opened it has levering action. So I will have to investigate more closely. I have ordered some super strength epoxy glue that is sold as liquid metal. However it may just need the dial lifting away from the case a tiny amount but still not sure. The biggest problem I now have is time as I have a lot of family issues at present and I also have few horological jobs pending.
    • It started well. Got the clip off, cleaned in B-dip, bit of grease, then ping 😫. Lost the clip trying to refit it.    I'll get a replacement from eBay.
    • I used Google Lens on the pic and it suggested "motorcyle belt punch". And googling pics of that does show very similar tools. The end on mine is sharp, and does look suitable for punching holes in leather. I've no idea what belts on motorcyles would need piercing? The hole is about 1/4", so I cannot see a use in watchmaking. So, why have we both found one in a collection of watchmaking tools?
    • You often see the term used on old watch part boxes.  Staffs for bracelet watches, timing washers for bracelet wstches etc.
    • The Boro has changed quite a lot over the last 20 years, and not for the better. I actually moved out of the town 15 years ago to a small village not far away. Thanks for the pdf! Looks a great read. I'll get it printed today and put it on my work bench!
    • Not having all the fancy equipment, this is a way I came up with. I never said it was the best, the most ideal or the safest way. Working on balances is always a delicate task whereby full concentration & common sense should prevail. I was well aware of the "dangers" / short comings involved, hence my "warnings", as quoted above. The balance wheel of the Omega was nice true, flat and one could clearly see how much gap there was left before the grinding wheel would touch the balance wheel. I stopped when the generously applied diamond paste started to touch the rim of the balance wheel, which turned out to be with a seat thickness left of 0.1mm. Tapping the remainder of the staff out went easy and flawless. My idea of penning this article was to show/share a way which, in my case, perfectly succeeded. If deemed to risky, or if the balance wheel is not true or has a wobble, other methods have to be followed.
