Can this be fixed? (A visit from the fairy)
p2n
1 hour ago, rogart63 said:
Depends on how hard it's stuck. If the plate is made from brass and you have no other steel parts on it? You could remove it with Alum.
Search the forum. Lot of info about that.
Thanks. The plate is all brass so will get some Alum and give it ago.
Any suggestions on where to get a replacement screw? What is the correct name for the gear/screw concerned?
36 minutes ago, rogart63 said:
That was a little much for one screw?
Yes lol. The whole watch only cost £5.50 on fleabay. I'm keeping to the cheap ones until I know how to keep the fairy at bay.
All I know about the movement is it's an "Oris". There doesn't seem to be any other identifying marks on it. I need to dissolve the stub out with some Alum and then clean it. I'll add some photos when I reassemble it.
Have some boxes with screws from both pocket watches and normal watches. If you have the sizes of the screw i can have a look if i have anything that could work?
If you buy the box of 100 screws from cousinsuk it's no  guarantee that there is one screw that would work in that lot.
The alum works - been soaking for a few days and been placing the pot in a saucepan of boiling water on the evenings for 30 mins or so.
Still needs a little more time as I think I can see a few remnants of the threads.
The only problem now is finding a replacement...
It's all back together save for the crown wheel. Winding it direct it ticks so pleased with that.
The actual screw is
Head 3.2mm
Barrel(?) 2.3mm
Thread ~ 1mm
My vernier calipers are not the most expensive so these measurements may be out a little (and its all a little small for them...)
They sell a pack of these on cousins for £20 +VAT & P+P but the watch only cost fiver so I'm reluctant to spend that much!
So until then I'll be keeping an eye of fleabay for a job lot :)
17 hours ago, p2n said:
That looks to be the almost the same mechanism!
Got any spare screws? ;)
No extra screws. have a couple of baumgartner movement also. They look the same. I have been through  my box of screws without any luck. Where do you live p2n ? Could send you some screws if you like.
Measured the barrel and it's about 1,9 mm in diameter. Both on the baumgartner and the brac. thread is 1 mm . So that could work.
I can measure the crown wheel .
Sharpen some peg wood and screw it into the hole.
Then you can use thread gauges to get an idea of the TPI or metric equivalent.
Then comes the fun job of working out what thread it is.
@rogart63 This made me chuckle - we forgot to check scale....
Out of the screws there were two types with the same thread. The problem is the shoulder, one too small and one too big.
Original in the middle:
I haven't got an broaches only needle files - what are the chances of being able to open the hole to accept the larger shoulder?
    • Hello good watch folk ,I  just fancied a light hearted discussion after my head was starting to spin over Epilame 😅. Specifically I'm meaning the sale of vintage watches, say nothing past the 1980s market. The stuff we see on ebay and other similar sites and found at carboots, curio shops etc. And are  we thinking its reaching a peak volume ?  Younger generations clearing out passed parents and grandparents possessions.  The younger folk are not as sentimental as the old fogies ( I'm now nearly at an age that i used to think was old fogie age ). When might it have started ?  i often wish i discovered the hobby much much sooner when selling your grandfathers pocket watch at a boot sale for a few quid was just a way to offload some tat. And when might it slow down. Thoughts anyone ?
    • Yes i did eventually realise that the oil will act as a barrier, I'm sure the discussion will continue. Ive had two oleophobic coffees ( added coconut ) and in the meantime i have this just delivered to take my mind off epilame for the time being. My favourite type of dial, its a beautiful looking watch traditional English made and it runs,  the ticktock is phenomenal,  i can hear it across my living room .  You wont believe how much it was. Thats interesting about synthetic oils , i thought the same, going from a 2 year service to 5 years is a big drop in income for service folk.  I expect some did well when they embraced the use of synthetic,  probably drawing in more customers than those that didn't use the new fangled substances , i bet fairly short lived though. The more frequent service makes more sense to me, not for just the service but for the regular check up inspections that might pick up impending faults. As far as epilame goes, wouldn't it be great to be able to fumigate the complete movement in a sealed jar of heated stearic acid, 🤔 now theres a thought 😅.
    • Imm going to close the discussion by attaching the photo of my super-titanium after several vicissitudes finally working. Purchased as not working I replaced the battery and for a stroke of luck I found its semi-new solar panel which, having verified its operation, seems to recharge the accumulator perfectly. I had taken this watch almost by bet, with 40 euros I brought it back to life. The initial half idea was to resell it to finance another purchase, but.. it's definitely a nice item. It would need to check the impermeability but it's a pleasure to see it on the wrist 😃
    • In fact the secret is to go gently and find the way without forcing, and the movement enters without problems
    • Yea a have given it a full service this movement is chinese 2813 whats the lift angle for this movement does anyone knows  and how  do a remove the default  of 52 degrees on my timegrapher?   Hi you said my lift angle is default how do a remove this from my timegrapher?
