Seikos
It maybe worth a message to them to see if they'd just supply the part you need. You'll also need to confirm the thread size to check it matches your crown.
By watchweasol · Posted
Hi you might consider the courses run by Mark our founder. They are on the watch fix site and from all accounts Well worth the effort. -
I don't know the details of their production set-up, but for small batch production 50 USD seems not unreasonable for the set. The photos are excellent. The parts appear to be very well made. It should be clear now how they all work together.
So how would that give you the end play from the screw down crown? That is a bit on the pricey side. I wonder if it's possible to drill the second hole yourself in a normal split stem?
