Tools for trimming stems
Davey57
I have fitted a couple of new stems recently but they were from ladies watches and the finished length was only about 10mm. I cut them near enough with a pair of decent small pliers and gradually finished them off on some fine grit wet and dry. Worked ok but, it was difficult to hold the stem in my fingers securely when doing the final adjustments using the fine grit paper. Larger ones aren’t too bad but what can I use in future to grip these tiny stems? Been looking at pin vices but I’m not sure if they would hold a stem without fear of snapping it whilst working on it. Also any suggestions for some cutters intended for trimming stems? Don’t want to pay the earth as it’s not something I do that often.
2 hours ago, Davey57 said:
Thanks for your tips and recommendations folks. Cousins have an Eclipse single ended pin vice,  0-1.0mm. That should cover most situations shouldn’t it?
I have the cheap dual-sided one and it works OK. But to be honest, grabbing/cutting/refinishing a stem is easy enough to be doable without a pin vise.
The new Eclipse pin vices are not as good as the originals, possibly due to not using Sheffield steel. However, they’ll still be better than Indian or Chinese monkey metal.
Using a pin vice for cutting is handy because it helps you get a consistent angle on the end of the stem when chamfering the edge (if you do this). I usually make a 45 degree chamfer to make the stem thread nicely into the crown.
We've ended up with lots of Eclipse tools over here, excellent stuff.  At one point they had a line that was almost as extensive as Starrett's plus things like mag chucks.  Sorry to hear the new stuff isn't made as well - did they start outsourcing or open a plant in China?
Edited by measuretwice
They got bought over by Spear And Jackson who are another quality tool manufacturer. I’m not sure if the new pin vices are made in England or not. The UK hasn’t protected many of its industries, especially steel, so we make less tools now. The stuff we do still make is probably up there with American tool quality.
    • I am having some trouble learning how your website works.  I couldn't get any text in with the pictures.  Some of the pictures look a little brown, rusty.  Actually they are all bright steel.  The color is some artifact I didn't have time to figure out the cause.  I hadn't used my camera for several years so the battery was down.  I may have lost some settings.
    • This is a picture of the watch with the back removed. The seal ring is in place as I think it may go.This picture shows the seal ring removed.This is a blowup with seal ring removed.This is one side of the seal ring.This is the other side.
    • The nut is more of a fine tuning alignment that you don't quite get with the front to back movement of the anvil. When tightening the anvil it can want to pull itself central to the tapered head pin in the middle, though you do get a little front to back play, just not always enough if the frame isn't perfectly in lline or has had a knock. Not sure about the stake friction adjustment I haven't come across that before.
    • 40 pounds sounds like too much I got one last week for $30 shipped from AliExpress. Keep us updated with the result.  I also just started and have 3 ST36, one I broke and two I am practicing with.  For one of those two I have ordered a wristwatch case+dial and hands but I though it would be nice to use the other one as a pocket watch but I found another thread here saying it may be difficult to fix it in the case due to the lack of tabs for it.  However on the pictures (I am not at home close to the movement) I see some holes where the screws holding the movement in your case seem to be.
    • John I have seen the information of the internet regarding Arnex https://theoldtimey.com/arnex-pocket-watch/#Arnex Watch Value https://adelstein-workshop.com/arnex-watches/ Very interesting. oldttimey estimates a value of £75, if everything is original.  Can't find an original movement as a donor. Silly prices wanted for a full donor watch. I can get an st3600 6497 for £40. Owner is more concerned wit the 'look'.  What I am pleased about is that by learning from others, I have been able to rebuild to the point where I was able to understand why it would not work. I know that I am not very good with describing my work. But achieving the outcome has been good for my ego. Know what the problems were. Know my limitations. Chuffed.
