Help Cutting Threads on Stem
jdrichard
I am making a watch stem and am at the final step of cutting the threads. So I have a Swiss (probably Chinese) die plate and clamped the part in my lathe. The die did not cut the material AT ALL. So the stem is made of blue steel. Do I need to soften the blue steel before i cut the thread? I also just bought another die plate just in cast the one I have is dull.
I do this with blue pivot steel. First annealing the steel to make it easier to turn and cut the thread.
https://www.watchrepairlessons.com/2011/07/17/vintage-rotary-repair-making-a-new-winder-stem/
I think you'll need more heat than that. A small butane torch should do the trick....
What colour do I need the steel to get and do I just let it cool down at its own pace. Then once I cut the threads, do I reheat it to blue and quench it quickly in water. I think I only need to do the threaded area of the stem, correct. Have never done this before.
Annealing requires you to hold at the critical temp for a minute or two (for small parts) then a slow cool for a full anneal.  Overnight in ashes is ideal, shorter may work but for a full anneal it needs a very slow cool, so I've always done the box of ashes thing.  To heat treat it again, heat to critical temp (1450), hold for a bit then quench in appropriate fluid (will depend on the steel).  After quenching, heat to the desired tempering temp to 'let the steel down" - this reduces the hardness a bit but also reduces the brittleness.  The following colour chart is based being viewed in sunlight, ie they'll all seem brighter with the lights out.  The right temp is often called bright cherry red, which I always thought was a poor description given the ripe ones are lot darker than you want the steel
http://www.stormthecastle.com/blacksmithing/images/color-of-steel/forging-and-tempering-colors.jpg
Edited by measuretwice
I'm not an expert in this by far but red hot at least for both annealing and hardening, let cool for anneal and quench for hardening. The exact temperature depends on the material, and that's the hard part. There's a ton of information on the web about it, YouTube especially. I have a feeling your die may be at fault also, if it's anything like my die plate (again probably chinese) it's not good for much besides re-threading a buggered thread. Finding actual quality dies for our work seems to be one of the very hardest things to come by. Sorry I can't be of more help.
 Cherry red for a couple of minutes should do it. Taper the very end of the stem so that it can reach into the die plate.
Turn the stem by hand whilst it’s clamped in a lathe collet. Use an empty tailstock to push against the die plate so that it’s perfectly perpendicular to the stem.
Harden the stem to straw (or whatever hardness you prefer) and then polish.
see post above.....a slow cool means a slow cool - like overnight.  less will work, but a complete anneal is hours and hours of ramp down.  Just heating it up and letting it air cool is essentially air quenching it.   Google O1 heat treat cycles and note the ramp times.  Heat it up bright red, hold it there and drop it in a box of ashes is how I do it
edit window closed and I miss a bit....I'm giving the way to anneal carbon steel.  A shorter, simpler cycle might anneal it enough, but the point is if its not working its because you are either not getting it to the critical temperature, or more likely its not being cooled slowly enough.  A BIG advantage to to doing a full normalizing (think slow and full anneal) is that the stresses are removed.  Without that, there is an increased chance of cracking at the stress riser (ie bottom of the V thread) when you do the quench to heat treat after machining
The metric HSS set I suggested recently in the other tap and die set is great. It’s the 31 piece set which comes under various brands. Don’t bother with the shitty Indian die plates. Though a Martin Swiss die plate should work well if you can find one.
For annealing small parts like this, you need to keep heating as you cool it down to bring the temp down gradually. I found that you don’t need to do that for long - say one minute of gradual cooling.
Bargain! I paid £40 odd in the UK. Mine was branded Tool Station or something like that. It’s  a nice quality piece of kit.
Same manufacturer in china. Check out aliexpress app and buy from them first, free shipping as well, mist of the time.
On 1/29/2018 at 8:32 PM, rodabod said:
I've had the same set for years. Pretty much hit-and-miss when it comes to quality. I've bought a few separate dies and taps for the smallest three sizes, also on ebay. Even though more expensive, these were not necessarily any better, sigh.
Just need to find a reasonable priced professional tap and die set for us watch guys
Sent from my GT-N5110 using Tapatalk
    • The wheels turned fine. I set the escape wheel in the epoxy when it had just ‘skinned’ and wasn’t set, made sure it spun with the 4th wheel, and let it set.    After cleaning I assembled the barrel and wheel train - all fine. Moving the barrel the escape wheel spun freely. I put a bit of 9010 in my epoxy setting.    It went wrong when I put the pallet fork in. It wasn’t seated right (no jewels) and the escape wheel  knocked a pallet jewel out. I have no idea how to reset a pallet jewel - epoxy again? I’m not spending any more time on this one - it’s missing hands and the front half of the case anyway, and I have more watches ready to put on the bench.
    • No John, we don't want Mark to change anything, we are just scared of losing a brilliant forum and losing contact with each other.  As pointed out, this forum is full of knowledge and I for one,  consider the regulars friends. I would hate to lose contact with you and the others.   PS, this forum is really important to me.
    • one little minor problem with your chemistry experiment here which is what exactly is epilam? In other words is it an exact substance with the chemical you specify or is it a term? For instance originally it was steric acid either dissolved in some sort of solvent or it was applied by vaporizing it. Then now it's all kinds of different things the watch companies all have different ideas there's a whole bunch of patents. So is not always an exact substance.   let me snip out a image from the patent that I attached up above. Notice I highlighted something it seems to disagree with your evaluation.
    • I guess You had to try, as it would be hard to sleep without that try, but, I know the result before the experiment... As I told before, the friction will be so big that the wheel will not turn. The pivots have to be thin and polished - the bigger the number of the wheel (2th, 3gh, 4th...), the thinner the pivot. What You are trying to do is possible, but forming the new thin pivot must be done on lathe. Thus the wheel will get shorter, but can have new pivot without the drilling for normal standard repivoting. Then piece of brass can be soldered under the pivot hole in the bridge and new hole drilled in it to form the new bearing.  Well, this way is not the recommended one, not quite correct, but it is possible to do for the excersize... When I say lathe, lathe may be verry simple, someting like turns, but made of what one has in reach of his hands. If You want to try, I will try to guide
    • yes by all means let's gather up our weapons tar feathers find the nearest tree in case Mark is not agreeable to our terms on our demands and storm his Castle. I don't quite understand what you're trying to do here? In other words you want Mark to somehow guarantee that the group will live on forever no matter what? You want Mark to somehow change his business model of what is trying to do or should we just take the group away from him? oh and is quite possible that Mark never realized that his discussion group would take on a life of its own. That the members of the group would like to continue on forever.
