Wyler Vetta High dome crystal
AlexeiJ1
Hi Everyone,
I was recently given a Wyler Vetta (ETA 32) watch with a stuffed movement and ratty case + crystal.
I've since serviced it and de-rusted it, waiting on some lume for the hands, cleaned up the case.
The man who gave it to me is dying from cancer, and it means a lot to me to fix it as he is like a grandfather to me (I'm only 25 in this hobby).
My dillemma is the crystal!
I've ordered a 32mm GHD crystal for $30 with postage and it turned out to be to small on the inner edge but too large on the outer.
Can anyone advise based off the measurements?
The inner diameter of the crystal was 30.6mm
Outer diameter is 31.85mm or so.
The inner bezel ring sits just on the dial, so that makes no difference.
The tension ring inner diameter is approximately 31.9
The crystal I got was from tiptopcrystals:
https://www.ebay.com.au/itm/G-S-XHD-EXTRA-HI-DOME-18-35-24-1mm-35-2mm-Round-Extra-High-Dome-Watch-Crystal/191801252753?ssPageName=STRK%3AMEBIDX%3AIT&var=490828457029&_trksid=p2060353.m2749.l2649
It was the 32mm GS XHD 30.1/2
Should I go for a slighly larger from same seller or ATG Sternkreuz from cousins? Can anyone suggest sizes.
I tried milling down the tip top crystal with a scalpel however ended up wrecking both he sent me.
you need the   proper wyler crtstal.     they may not be available.   try to find a watchmaker [or a forum member] who has the right one.     it can be chucked in a lathe to cut the edge inner dia. for the ring + clearence.  vin
You're not alone in having issues with fitting crystals. I guess that's why jewelers/watchmakers generally have a good assortment to chose from. I've had good luck most of the time by measuring many times to be sure, but I did recently buy the wrong size and type for a forties Perregaux. Going trial-and-error can be costly with $30 crystals. You might consider sending it to a specialty crystal replacement service if you can't find the Wyler product.
BTW: If you find the Wyler crystal, you might try to get two. :-)
Oh, and vinn3, that's interesting about the lathe use for adjusting the edge thickness. Would you use a bezel-chuck?  I ask because that happens to be one that I have. Thanks.
Edited by MrRoundel
The type of crystal you need is one that sits on top of the rehuat and is held in place by the bezel , like the Rolex Oyster .
The Sternkreuz crystal for this type of fitment is the ST or XS type , but unfortunately i can't see one in the sizes you mention.
Have you measured the external diameter of the rehuat and the inner diameter of the bezel ?
Edited by Andyclient
I have a selection of aftermarket crystals - all high dome.  I have a plastic 4 jaw chuck to turn them.  Wyler is a problem,  also Ernest Borel.   these are among the VINTAGE  watches that need a factory crystal.  I think they all are in private hands.  vin
On ‎1‎/‎22‎/‎2018 at 9:34 PM, MrRoundel said:
Gotcha. That's too bad. I hope that one turns up. Good luck.
And thanks for the clarification on the type of lathe tool you used for the crystal adjusting. I've never seen a plastic 4-jaw. Granted, I don't have much experience such things. Cheers.
its just like a steel 4 jaw,  but its a bit loose and flexible.  when I find it, ill post it.  vin
Thanks, vinn3. Yes, I do know what a 4-jaw chuck is. I have a 3-jaw for a Unimat lathe that I've had for a while. I believe the 4-jaw is the same, but with 4 jaws that allow for more precise centering. I got the 3-jaw because it's a bit easier to use for the newbie.
A plastic 4-jaw does sound like a good way to go for adjusting crystal thickness at the seat. I'll keep my eye out for an image. Thanks again. Cheers.
15 minutes ago, MrRoundel said:
Perhaps the 4-jaw is better than the 3-jaw because you can center non-round work as well?
right you are.   a new uniat lathe would come with both chucks.  its a 1/2 x 24 thread i believe.  a used unimat may have a drill chuck.   i am using a 6 " lathe.   it takes years to master the 4 jaw.   a 3 is darned fine if you are cutting larger stock.   the hunt goes on for my plastic 4 jaw.  vin
  • 2 years later...
If anyone is interested, I found the original crystal 2 years ago on ebay. I found it by searching the dimensions and brand name "wyler".
I also got the dial refinished last week, looks a lot better.
The font is gone, but the memory is forever.
My good friend died shortly after I found the crystal, but I will keep the watch hopefully forever.
    • The Boro has changed quite a lot over the last 20 years, and not for the better. I actually moved out of the town 15 years ago to a small village not far away. Thanks for the pdf! Looks a great read. I'll get it printed today and put it on my work bench!
    • Not having all the fancy equipment, this is a way I came up with. I never said it was the best, the most ideal or the safest way. Working on balances is always a delicate task whereby full concentration & common sense should prevail. I was well aware of the "dangers" / short comings involved, hence my "warnings", as quoted above. The balance wheel of the Omega was nice true, flat and one could clearly see how much gap there was left before the grinding wheel would touch the balance wheel. I stopped when the generously applied diamond paste started to touch the rim of the balance wheel, which turned out to be with a seat thickness left of 0.1mm. Tapping the remainder of the staff out went easy and flawless. My idea of penning this article was to show/share a way which, in my case, perfectly succeeded. If deemed to risky, or if the balance wheel is not true or has a wobble, other methods have to be followed.
    • I loved his explanation of a teardown 😅 Ex military Richard Perrett, pretty knowledgeable guy.
    • I also see a bit of danger for the wheel, at least you have to keep away from it and may get a too thick rest ring. My rest rings are about 0.05 mm. Better way would be a grinding wheel touching the staff with its circumference. Frank
    • Not easy to find this one everywhere,  so it depends where you are located. Joining it back together might be possible, i have silver soldered mild steel before even with traditional plumbers lead and its a pretty strong joint, but bere in mind this is only 1mm diameter.  The join would need to be very accurate,  it not something i have heard of anyone trying before. The part no 401 is the swiss code number and relates to watch winding stems in general
