Waltham A11 8 Day aircraft clock
Tmuir
You know how it is, its late at night, you have had a couple of whiskeys you are browsing ebay and you see something, you place an impulse bid and wake up in the morning to find you have won it.....
ACtually quite pleased, its a bit rough but price was good, hopefully when it arrives it will be in a state worth restoring.
I like military clocks, I've got a couple of Russian MIG clocks, a Russian Tank Clock, an American Seth Thomas Navy Deck clock and now a Waltham aircraft clock.
Just need to get myself some British ones now....
It will be a couple of weeks before it arrives, but there are a couple of taster photos of it on ebay.
No idea of its exact age yet other than it cant be later than the 1950s, but if I am lucky will be of WWII vintage
https://www.ebay.com.au/itm/VINTAGE-WALTHAM-8-DAY-A-11-MILITARY-AIRCRAFT-AVIATION-CLOCK-/382333164905?_trksid=p2047675.l2557&ssPageName=STRK%3AMEBIDX%3AIT&nma=true&si=oZxjZV%2BqZEhnkGjEDMhqfs0Js7M%3D&orig_cvip=true&rt=nc
good show.  had any ships clocks apart?  Vinn
I just can't help myself.
Was trawling ebay again and found an Elgin Pioneer aircraft clock for sale in Australia.
I do know this model of clock was used in some Australian made aircraft and what was very interesting about this clock is it has scratched on the back of it A20-343, this is the service number for a Wirraway Aircraft that was made during the war in Australia.
Only 15 Wirraway aircraft still survive out of the 755 built.
I've not managed to confirm that this model of clocks were used on Wirraways yet, but if so its very exciting.
Anyhow enjoy a couple of photos of it, it is not working and judging by the rust on the screws it could be in a bad state, but we will see.
  • 7 months later...
I posted in the clock forum but I'm excited I found this thread again as this is what led me to the site to begin with!
My clock looks very similar to your aircraft clock. Do you know if this one is also an aircraft clock? Thanks in advance for your help!
    • Might that be the viscous nature of oil resisting gravity H  ,  we have been comparing water and hydrophobic surfaces which are similar in principle but water is much less viscous than oil. I guess what we trying to discover is if epilame also has an adhesive trait as well as being oleophobic.
    • But it also makes it seem less susceptible to gravity. If you place a droplet of oil on an epilame-treated surface the droplet of oil will still stay in place even if you then flip the surface from a horizontal to a vertical position. That is, the oil droplet remains anchored, and that's the purpose of epilame. If it was just a matter of creating an oleophobic surface we could probably use other, less expensive, methods!? I don't know @Waggy but my gut feeling tells me you're spot on (pun intended!). I believe the oleophobic property is a side effect of epilame which is designed to keep the oil anchored.
    • Saturday morning 27/4 Sunday evening 28/4 Monday evening 29/4 Floor has a drain in the middle so I am hoping that there is very little fall on it, if any. Room is about 2.5 x 2.5 metres square. Can only use about 1/2 of one wall on the right of the pictures which has a sliding glass door in it. And only about 3/4 of the wall to the left of the pictures as it has the door to the house in it. Progress. 🙂
    • This makes much more sense now, the oil is withdrawing itself to make as little contact with the epilame as possible. Same principle as wax on a car creates a hyrophobic surface that makes the cohesive properties of water molecules pull together.  The water beads run off only when under the influence of gravity but still remain cohesively beaded up. And as mentioned earlier a pivot would keep the oil in place on a cap jewel.  Epilame on an escapement would be a different scenario, there is nothing to hold the oil in position if gravity tugs at the bead to move, plus the escape teeth pull the oil about Maybe this is why its suggested to run the watch for a short while to remove the epilame to make two oleophobic surfaces either side of the oil, creating a ring of fire 🔥 around it 😅 The oil is repelled by every surface of the epilame even that which it sits upon. So the oil pulls together to make as little contact with it as possible, but the oil cant float above that area, it can only sit there on top of it. Under gravity the oil could potentially run away as an oil bead, unless the epilame has an adhesive property which i dont think it does ? So something else keeps it in position ie a pivot under a cap jewel . But that isn't the case in a pallet jewel situation.
    • As with every skill it watchmaking, it takes practice. Notice at the top of the document it says, "Practical work - 40 hours".  I can get the balance wheels 'close enough' to flat, but never seem to get them perfect. Same with gear wheels. Guess I need more practice.
