How should I bent this hairspring?
dieale2
Hello folks. I been working on this Elgin watch. A few days ago I asked about the trains seizing and now I am working on this hairspring.
I have been messing with it for a couple hours and now I am kinda stuck on what to do. The inner coils are messed up but I am having a super hard time seeing them. Should I try to get finer tweezers? Right now they are bigger the space between the coils.
I have seen a technique where one gets a copy/image of the spring printed out and then places the bent spring over top of it pinning it through the collet to some cork board or similar material and then manipulating to match the printed template. You should be able to find the spring model somewhere and if you can find an image adjust it to size and see if that might help. You could try a crude drawing of the spring as well as a starting point. Good luck let us know howz it goin'. My least favorite thing to do, I should add.
It looks stuck or magnetized on one side. Take it off the balance staff and clean it in One Dip or naphtha or lighter fluid. Then demagnetize it. It should go back to shape. Then reinstall it on the balance and make sure the collet is directly over the upper balance jewel: off to any side will cause it to be less perfectly spiral. It may be fine after that.
    • I was pleased to pick up a selection of some tools on ebay (v cheap 🤣), and they've just arrived,  I've been looking for a crystal press for a while, and this one is ideal But in the selection is this thing - what is it for?  (it's about 3" long) Something to do with stem tubes?
    • You'll have to strip it back anyway.
    • I think I've heard that more than from just Alex. That doesn't make it right though, but I'm convinced i saw some literature diagram explaining why to do that. There must be good info here in the archives, I'll have to have a dig around.
    • That will mean dismantling the gear train, which with 5 pivots to align was a pain. Probably going to have to though. I'm convinced it's something to do with the great wheel.
    • As far as I know, the only time an epilame treatment has potential drawbacks is when something is rubbing on the treated part w/o lubrication in between creating abrasive dust. That is, I don't believe in the method of "running the watch to make a groove through it first in the pallet stones where the lubrication is then placed". So, I think the rule would be; do not epilame treat parts where rubbing is going on without lubrication. Other than that I don't think we have anything to worry about. That said, I'm not an expert, and I'm always happy to learn more. Has any other repairer than Alex suggested or explained the "making-a-groove" method? My impression is that it's just something he constructed in his mind. I have not perceived it as a generally practiced method. Again, I could be wrong!
